hi i am working on panasonic copiers.E4-02 this code shows there is some problem in fuser unit
1.pull out side fuser unit from copier
2.check it is movig easily
3.check all gears
4.check thermostate and thermistor
5.bearings and seals
6.for to reset heater codes press function, orginal size,3.F1 will display press 9 ,06(ram initialize) sub code 04 start .fuser code will bi reset.
was it helpful .not forget to rate me .MIAN AKHLAQ
I was trying to run a pdf document of 600 pages. It printed first two pages and then stopped( on the...
(More)
I was trying to run a pdf document of 600 pages. It printed first two pages and then stopped( on the machine's screen it was repeating a message recieving data for about 45 minutes or so). i went ahead and cancelled the print queue then switched the machine off and on. then i resent the document. same way first two pages got printed and that's it. Iwent ahead and connected the machine into a different computer, loaded the drivers, ran a test copy on the system, it says that the document is failed to print.
