Question about Vehicle Parts & Accessories
2001 toyota celica gts with security system how do you reset after replacing dead battery?
I have a 2001 Toyota Celica GTS the dead battery was just replaced in and now the car won't start. Thinking it may be due to the theft deterrent system. How do I reset it?
SOURCE: 2001 Toyota Celica GTS Clutch
i paid a friend to do it because it's a lot of work! if you haven't already treid to or got it done just know that when my friend did it; it took him like 8 hours (he'd never done one on a celica, but had done them on american cars) so if your not familiar with it... not a good idea to do alone. I watched him do most, but i'm not the best to talk to about it.(plus i have a 2000GT) Some of the parts that i can remember that he took out to get to the clutch were the front driver's side tire, the axel on the same side, ....some other parts in there....and ALSO parts on top...the intake also had to be taken out just to have enough room to do the job. parts are cheap...just ask for a clutch kit at auto zone or whatever. around $150. another random tid bit that might help is make sure to tighten the engine mounts really good afterwards or else it will jump around in there when you turn it on and cut it off. buy gear oil before you start as well because you will need to put some in after the new clutch is in. i will need to put the car on a real lift... you need a lot of space underneath and on top to work. and most likely two people. well hope some of this helped.
Posted on Sep 06, 2008
  • 69 Answers
SOURCE: want to install a fusion f 2000 car alarm system
heres some links to the wiring info you requested
http://img.photobucket.com/albums/v249/2fas4u/f2004.jpg
http://img.photobucket.com/albums/v249/2fas4u/f2003.jpg
http://img.photobucket.com/albums/v249/2fas4u/f2002.jpg
http://img.photobucket.com/albums/v249/2fas4u/f2000.jpg
heres the wiring info for your car also. as always, double check with a DDM before connecting
Battery WHITE (+) IGNITION SWITCH HARNESS ico_question_mark.gif Ignition 1 BLUE/RED (+) IGNITION SWITCH HARNESS ico_question_mark.gif Starter 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS ico_question_mark.gif All Door Trigger RED/WHITE (-) DRIVER'S KICK PANEL ico_question_mark.gif Trunk Trigger RED/WHITE (-) AT TRUNK LIGHT "HB WORKS WITH DOME LIGHT ico_question_mark.gif Hood Trigger N/A ico_question_mark.gif Alarm Disarm N/A ico_question_mark.gif Parking Lights DARK GREEN (+) DRIVER'S KICK PANEL
hope that helps:D
Posted on Sep 15, 2009
  • 1509 Answers
SOURCE: alarm needs to be reset
Many cars, Maybe not yours can be tricked into thinking that they've never been tripped to begin with. This procedure needs to be done carefully as inpresicsness can mess the car up. With the battery fully charged. ( not jumped, ran the car for awhile, Charged, the battery charger says so) and the cables clean ( they don't just look clean, cause you cleaned them anyway) disconnect the battery and come back later ( 10 MInutes ) Connect the cables to each other ( not the battery ) Hold em there ( 1 Minute ) Connect the positive and let the neg hang free. Turn the key to the run position. everything else off. Connect the neg cable like you mean it ( don't bump it skip it fool with it, Get it on tight in one move). Start the car. The security system never knew it was off and it'll start as if it were already on. Being you didn't tell what kind or year of car or truck you have it'll work on most and it won't hurt the others. It's hard to fix vehicals with out knowing the year model as the rules change with each model year.
Posted on Sep 19, 2009
c17hydro
  • 2984 Answers
SOURCE: How to instal serpentine belt Toyota celica 2001
Removal & Installation
  1. Remove the right hand cover under the engine.
  2. Turn the drive belt tensioner clockwise to relieve tension on the belt.
  3. Remove the fan and generator V belt.
  4. Return the tensioner to the unloaded position.
    NOTE When retracting the tensioner, turn it clockwise slowly in 3 sec. or more. Be sure not to apply force rapidly. After the tensioner is retracted all the way, do not apply force any more than necessary.
To install:
  1. Turn the drive belt tensioner clockwise
  2. Install the belt.
  3. Install the right hand cover under the engine.
Posted on Feb 27, 2010
  • 733 Answers
SOURCE: anti theft light came on, car would not start,
the manual says to put the key in the ignition, turn on all the way, but don't start the car and leave for 10 minutes until the theft light stops flashing. turn off all the way and star it up. good luck.
Posted on Mar 18, 2010
What's mean late valve timing in toyota Celica 97 1.8L I have this problem.
Toyota Celica - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Toyota_Celica
WikipediaVariable Valve Timing came in certain Japanese models starting in December 1997, and became standard in all models from 2000-on. Through seven ...
1970 - 2006 Toyota Celica History ' car review @ Top Speedwww.topspeed.com > Toyota > CelicaReview by Blas Nicusor - ‎Nov 28, 2006Nov 28, 2006 - 1970 nbsp - nbsp 2006 toyota celica history - DOC113627 ... The second generation Celica was released in 1978,(production began in late 1977) and ....the GT powered by an economical 1.8 L 4-cylinder 140 hp engine and the ... Toyota's signature VVT-i (Variable Valve Timing with Intelligence) system, ...Toyota Celica GTS (2003) - NetCarShow.com
Jan 30, 2016 | Toyota Cars & Trucks
Good alternator not charging battery in my 1984 toyota celica gts
How do you know the alternator is good?
You need a digital multimeter to check.
With car off check DC voltage of battery, should be over 12 volts dc.
Start car and measure again.
If alternator is good, dc volts should now be over original reading, if alternator is faulty battery is not charging.
If alternator is good you may have a dead cell in your battery, if so replace.
A give away of a dead cell, is that your original reading of dc volts is under 12V.
May 16, 2014 | 1984 Toyota Celica
Toyota Celica gts 2000 blowing cold air when heater is on.
nothing try back flushing heater core, they clog up due to litle water preasure,you might want to flush cooling system if you already havent, hope this hleps.
Oct 06, 2009 | 2000 Toyota Celica
1985 toyota celica gts idle when starting
it may be one of the water temp. sensors at the thermostat housing.
also check the plug, wires,distributer cap and rotor.
good luck
22re owner
Jun 24, 2009 | 1985 Toyota Celica
Where is the cigarette lighter fuse in a Toyota Celica?
There are 2 possible areas. 1 is the fuse box beside your left foot. 2 would be in the engine compatment on the right.
Jun 06, 2009 | 2001 Toyota Celica
2000 toy celica gts
you're talking trash
Aug 18, 2008 | 2001 Toyota Celica
Vehicle Parts & Accessories Logo
21 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
