Question about RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor
Duralast gold jump starter charger adapter volts and amps
5 Suggested Answers
SOURCE: I have a duralast jump
Adaptor for DURALAST BP-DL
Model HB-208b
Input AC 120V 60Hz
Output DC 12V 450mA
Posted on Jan 17, 2009
  • 23 Answers
SOURCE: My Duralast jump starter is dead and when I tried
It will not charge without an adapter suitable for the rated charging amperage. Also,
it must have a ground.
Posted on Dec 18, 2010
SOURCE: I have a Duralast Gold Jump Starter.I charged the
I had the same problem today and I found out that is the battery itself causing the problem. It's actually the connection. So disconnect the battery and scratch the battery pins and connect them again. If you can dip them in soda water (no sugar in it!) that would be better.
This problem starts as the battery beggins to get old and combined with cold weather outside becaomes a receipe for disaster. Anyway, if you can't afford a new battery at the moment remove your battery from your car (but first try and drain it totally...leave a light on or something) and recharge it (fully) with the duralast (havbe the duralst plugget into a outlet). It will have your battery working for couple of weeks.
Posted on Jan 21, 2011
archaeology
  • 662 Answers
SOURCE: My Duralast Gold Jump Starter does not take a
There is a battery inside which may need to be replaced. To check, run the compressor (it runs off
the battery) - if the compressor dies quickly, then the battery has failed to charge and would
need to be replaced. You may want to check your Warranty Management software (or
shoebox) to see if your Starter/Air Compressor is still under warranty - if so, replace it.
Duralast products are carried exclusively by AutoZone, Inc.
The Duralast web site: www.duralastparts.com is useless - it only shows automotive parts,
and I cannot find the product at www.autozone.com, so it seems that AutoZone fails to support this
product with replacement batteries or other replacement parts (or even an online Users manual).
Posted on Feb 21, 2011
I have a duralast gold jump starter, but it will not charge.
then the internal battery has given up it's life . cost more to repair than a new one will cost .
Apr 27, 2015 | Cars & Trucks
Can a Duralast jump starter kit start a car while plugged into an outlet?
The charger to a Jumpstart charges at a low rate (300mA to 500mA) and will not push enough current to start a car. Best to have Jumpstarts recharged every 6 months to be ready for emergency.
Nov 26, 2012 | RoadPro Road Pro 12 Volt Dc Portable...
My Duralast Gold Jump Starter does not take a charge when I plug it in to the wall socket. While the charger is connected to it, it will show the green light. But when I remove the charger, after...
Feb 20, 2011 | RoadPro Road Pro 12 Volt Dc Portable...
I have a duralast jump starter BP-DLG. i cannot get it charged. i have pluged it to a standard electrical outlet and now it is dead. i have used it in the past and it worked very well. i mis-laid my...
My Duralast Gold Jump Starter Model BP-DLG will not take a charge. When it is plugged into the charger it shows fully charged; when I unplug it it goes dead, will not start and the red light shows. I have used it about 4 times in less than two years.
I have a Duralast Gold Jump Starter.I charged the battery green light is on but when I try to start a car engine it looks like the jump starter does not have enough power to do the job. Note.- I acquire...
Dec 03, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Need a charger to charge my Jump Starter BP-DLG
Need confirmation that the AC adaptor for Duralast jump start model BP-DLG is a 12volt 450ma. Is this correct or do I need something else?
Nov 06, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Hello. I have a duralast jumpstart kit. After
Hi, usually after you drain the unit down it will take up to 4 hours for it to charge up 100%. but do not leave it on the charger all the time when not in use because this decreases battery life.
May 23, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor Logo
20 people viewed this question
Top RoadPro Air Tools & Compressors Experts
Lawrence Oravetz
ray gallant
 Bob Oppenheimer
Bob Oppenheimer
Level 1 Expert
Are you a RoadPro Air Tool and Compressor Expert? Answer questions, earn points and help others
