Question about Dryers
How to seperate a Kenmore dryer from the washer under it?
I am trying to remove my Kenmore 417 90142000 dryer from the washer so that I can replace the washer.  They are seperate but stackable units. There is a connecting kit of some sort holding them together and I can't figure out how it works.  It looks as if the dryer has been secured by placing it over some metel tabs that are screwed to the washer, but I can't pry the dryer up and off.  I saw a picture of Dryer Stacking Kit #638304 and it looks similar, from what little I can see. I have to get the dryer off by Tuesday, October 16!  That's when the new dryer comes, and the sales person told me that the installers will not lift the dryer off.  Thanks for any info.
Robin
Thank you, thank you. 1 1/2 years after this posting I found it and it solved my problem with a Frigidaire washer/dryer. Couldn't find the solution anyway elee!
Bea, Fernandina Beach FL
Posted on May 10, 2009
    Problem Solver:
  • 11 Answers
This is probably a model that has two access holes at the bottom front of the dryer -about 4-5" from each side- usually closed off with plastic discs. Just an inch up from the washing machine.  Pry out the plastic discs with a flat screwdriver and you should see a screw inside each of the two openings.  Remove the screws and you will be able to tip the dryer up and slide it back a few inches to detatch from the back.
Use two people to lift the dryer down as it is bulky but not too heavy.
Posted on Oct 12, 2007
  • paul witort Oct 14, 2007
    Let me know how the above procedure worked in case another approach is needed... the 16th is coming soon  :)
SOURCE:
How do i remove the agitator on my kenmore elite washer
See if the top of the adgitator is removable, there is a bolt way down under the liquid fabric softener and top lid. And possibly a top sealed cover as well...
Aug 02, 2014 | Kenmore 4.3 cu. ft. High-Efficiency...
I need to unstack my kenmore washer/dryer
On the model posted this style does not come apart. Only on the front load style can you seperate them.
let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Kenmore 98702 Stacked Washer/Dryer
How do i replace the heating element on my kenmore stackable washer dryer 98702 machine
Could you please post the model number of the unit? It will be under the washer lid, in the dryer door, on the top, or the side of your unit.
Dec 25, 2010 | Kenmore Washing Machines
Need to disassemble a kenmore elite oasis dryer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
Replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Washing Machines
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Kenmore 3394715 stackable washer/dryer
Go to sears parts direct .com. You can pull down a schematic on how its put together.
May 06, 2008 | Kenmore 98702 Stacked Washer/Dryer
Blue dye under three seperators inside dryer drum.
ok " you would have to pull the drum to get at those screws
what I would do is use a tooth brush with some bleach
that should take care of it.
Jan 23, 2008 | Dryers
Dryers Logo
221 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
