Question about Brother Personal FAX-275 Roll paper Thermal
HOW I DO TO REPLACE TONER OF BROTHER FAX 236S
  • 42 Answers
SOURCE: poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Posted on Mar 17, 2008
bowdo
  • 78 Answers
SOURCE: very poor printing
If the prints are light or have white lines it will be related to the laser unit. There is a strip of glass that sits above the drum inside the machine. Clean it. If there is toner on it will cause this problem. Otherwise the laser unit has failed.
If you have dark marks, blotches or reprinting (part of the image repeating lighter down the page). It will be build up on the fuser rollers. Remove the drum/toner and look at the rollers behind, they will look dirty. The only way to resolve this is to replace the fuser unit as it is worn out.
The only other possibility is that the drum contact on the sides of the machine are deformed or out of position. Its hard to tell and fairly unlikely in this model.
Posted on Apr 17, 2008
  • 320 Answers
SOURCE: need to replace toner cartridge,
take the drum unit out which contains the toner cartridge, buy new brother toner cartridge and reinsert it in to the drum unit and then put it back into the machine and you will be good to go
Posted on Jan 16, 2009
  • 215 Answers
SOURCE: change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Posted on Jan 28, 2009
iservice
  • 318 Answers
SOURCE: can't reset "change drum soon" message Brother Fax 2820
Open the front cover and press and hold -stop,reset button
Posted on Sep 15, 2009
Brother fax 236s My fax machine display cannot be seen when i look it directly. Characters can be seen lower and high positions. How do i adjust display contrast?
That's quite unusual. It should really be in reverse and it should be dark when looking directly and feint when at angles. I suspect you have a light in the room that is bouncing off the display. Try it in another room and I bet it will be ok. By the way there is no adjustment as its a low end unit.
Feb 08, 2015 | Brother Office Equipment & Supplies
Brother intellifax 4100 e display says to replace toner but cartridge is not empty. Is there a reset for the toner?
There is no reset for the toner. It uses an optical system where light shines through the toner. Shake the cartridge gently left to right to even out the toner and try again.
Jul 01, 2011 | Brother IntelliFax-4100e Fax
How to replace in k
Your machine is a laser type fac (not inkjet). It does,t use ink, but toner. To learn how to replace the toner cartridge you should read the User's Guide.
You can download it from here: Brother FAX-2920 User's Guide
manual.
Look for section "Troubleshooting and routine
maintenance" / Replace the Toner Cartridge / How to replace the toner cartridge and Replacing the Drum Unit (pags. 112 and following of the User's Guide).
Oct 02, 2010 | Brother FAX-2920 Plain Paper Laser
I have a Brother fax and copy machine and have just replaced toner with a brother TN 350 cartridge and still getting message that toner is low
You didn't include the model, but here are instructions for the Fax-2820; it should work for any of the models that use the TN-350 toner:
  1. With the power on, open the front cover.
  2. Press the Options key. The display will read "Change Drum?"
  3. Press Start.
  4. Press 1 0.
  5. The display reads "Accepted" for about 2 seconds, then change to "Cover Open."
  6. Close cover. The "Replace toner" message should be cleared.
Normally, inserting a new cartridge (with the power on) will reset the toner counter, and you won't have to do any of this.
Dec 21, 2009 | Brother IntelliFax-2820 Laser Fax
Toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
Jul 03, 2009 | Brother FAX-2920 Plain Paper Laser
Change toner error brother 2820 mach has new brother toner ctg
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Need to replace toner cartridge, in brother 2850 laser fax
Dec 30, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother TN350 - Toner Problem
The toner is n/g. replace it if it leaks.Lawrence
Sep 25, 2007 | Office Equipment & Supplies
Brother Personal FAX-275 Roll paper Thermal Logo
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
