Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
MY TRACTOR STARTED MISSING AND I CHECKED THE OIL AND IT SEEMS TO HAVE GAS IN THE OIL.....WHAT CAN I DO TO FIX THE PROBLEM?
  • 41 Answers
Replace carb. and that should solve your problem.Most of the time carb. kits won't work.
Posted on May 08, 2009
Getting gas in my oil. How do I fix?
does the fuel pump get air for the pulse pressure off the side of the engine ? check the pump diaphram isnt leaking fuel as this is a common fault ! or the carb is flooding so check the float needle isnt worn !
May 28, 2014 | Murray Feiss Murray 42" Side Discharge...
Yard tractor has 145 hours ran 2 weeks ago but was missing ,it had backfired,changaed plugs,fuel pump works,seems to get spark,won't start even eith gas put into cylinders
You may possibly need to adjust the overhead valves in the engine. Your owners manual should have the steps included in it (under maintenance) to do this. This is quite possibly the problem. The valves should be checked and adjusted once a season just to be sure.
Aug 12, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Lack of power
Yes FUEL, the Motor is NOT getting enough. Things to check, Gas, Float valve, float bowl, Mixture, Spark Plug, Spark Plug Lead, & ends. Check for any clogged fuel filters.
www.m-and-d.com/helpfaq.html
www.ehow.com/how_6129297_troubleshoot-husqvarna-mower-kawasaki-engine.html - United State
http://outdoorpowerinfo.com/repairs/
OK links above will assist in fixing your problems.
Apr 15, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Looking for some help. I've got a Toro Z4200,
there is only one way gas can get into the oil. if someone is pouring it into the crankcase...good luck
Apr 05, 2010 | Garden
Engine starts, runs rough (like cylinder missing), after a minute will run smooth a few seconds, then back to rough idle. new gas, new oil, gas filter seems clear. What else to check?
Establish which is the 'lazy' cylinder (touch the exhaust pipe header with a WET finger). There will be a marked difference in temperature. Change the plug on the 'lazy' side. If no better, check for a good spark - with engine running on the good cylinder, connect the other plug lead to a spare plug and grund the plug body. A weak/internittant spark will be readily apparant.
If there is a spark problem, replace the coil on the dud side. If not, check for equal compresion on both cylinders.
Mar 09, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Engine won't Start
If you have 3 qts. of oil in your mower, drain it immediately. It only holds 3 PINTS or 48 ozs or 1 1/2 qts. Next, remove your spark plug and put the end away from the hole (to prevent possible arching and fire) and crank the engine over. Probably, a lot of oil/gas will blow out, clearing your cylinder. Clean the plug and try to restart. If it still reaches a point where the engine will not turn past while trying to crank, the valves need to be readjusted. Also check by smelling the dipstick that there is no gas mixed in the oil. That would mean your carb needle and seat are leaking.
May 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
6yr old Craftsman Lawn Tractor - Koehler 18 HP Auto. Sputter&Dies
Try running it again and when it starts to die remove the gas cap and see if it starts to run better. It's possible that the gas tank isn't venting correctly. If that doesn't work post back and we'll try to come up with some other solutions.
Apr 22, 2009 | Craftsman Garden
Oil leaking way to much
It is a leaking valve cover gasket (easy fix) or the gasket between the head and crankcase ( most likely but much harder to replace). Check the valve cover gasket first.
Mar 16, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Hard starting smokes white like gas is getting into cylinders
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
89 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
