Question about Electrical Supplies
Craftsman genpower 55 - Electrical Supplies
I have a Brigg and Stratton GenPower 10.0 portable generator. i noticed an oil leak and when i inspected the situation i found that there is gasoline where i fill the oil. Is this usual?
if what your saying is it seems like there might be gas mixed in with the oil that is not good but its not unusual for your oil to smell like gas a little
Oct 13, 2016 | Electrical Supplies
What kind of gas to used on lawn mower 55 158 cc craftman
Ori Hi, most lawnmowers use regular unleaded petrol now. If you have somewhere that oil goes into your mower then it will be normal unleaded but if on the fuel cap it has an oil can picture you need to mix it with two stroke oil.
Sep 07, 2013 | Craftsman 55 Torque 158cc 22" Push Lawn...
Oil coming from my oil filler tube craftsman mower model 917-376572
There will be an o ring on the bottom of the dip stick tube to seal it to the crankcase, i think this is leaking due to age or has split, remove the screw securing the tube remove it and replace the o ring.
Oct 07, 2012 | Craftsman 55 Torque 158cc 22" Push Lawn...
Oil to used for a briggs and stratton genpower 305 10hp ohv engine
Hi Jim, sae 30 mineral oil for all Briggs engines. Regards Phil.
Sep 24, 2011 | Coleman Powermate Powermate 5000W...
Need a manual for a #55-5919-6
you can try going to "managemyhome.com" but it doesn't appear that you have enough number for the model. let me know if you need more assistance
Jan 08, 2011 | Craftsman Drills
Briggs and Stratton GenPower 11 generator cover plate ???
I have a Briggs & Stratton GENPOWER 11 generator that is electric start. The electric start will not start the motor or ever turn it over. I can turn the key on and jump across the terminals on the starter and it will run only if I continue to squirt starter fluid in the carb. My question is, if the ignition switch is bad, could that be the reason it will not stay running. My only guess is if the ignition switch is bad, the motor thinks it is in the off position at all times. Thanks, R Ray
Jul 16, 2010 | Coleman Powermate Premium Plus 6250W...
Lawnmower runs for 2 or 3 minutes then stops running craftsman 6.5 hp push mower
Sounds like you might have a fuel flow restriction, maybe an in line filter?
Apr 27, 2010 | Craftsman 55 Torque 158cc 22" Push Lawn...
Electrical Supplies Logo
78 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
