Question about Konica Minolta Office Equipment & Supplies
C-d282 code c-d282 presents
TRUCK WONT START
the P1693 is a companion code ,not a big deal as for not starting are you getting fuel to the injectors prime your filter and try this
I'm going to point out to everyone there is NO WAY to have just a P1693 code present during error code dumping. Yes the P1693 is a companion code and has no really meaning but...
"This code indicates there is more code present in the other computer" So if the P1693 is in the P PCU that means there is more codes present in the P ECU. So if there is a P1693 in the P ECU that means there is more codes present in the P PCU. Then even in rare cases seeing the P1693 code in both computers pointing out that both computers have codes. But there is NO WAY for the P1693 to be the only codes present during error code dump. It's totally impossible!
The reason I'm posting this is because it seem like everyone is cancelling out at the first P DONE thinking its done. WRONG! There is TWO computers in the truck .
P PCU = Powertrain Controller Unit (Passenger side firewall)
P ECU = Engine Controller Unit (Driver side of engine block)
You should always see both P PCU and P ECU displayed and 2 P DONE's in the display. If you want to see a video of this and how to properly do it please reffer to my web site and watch the video I produced so you can give us acurrate information on your problems your having with your truck.As worded by my Cummins certified friend., try http://igotacummins.com/showthread.php/178-P1693-my-trucks-at-it-again-i-think-my-luck-just-ran-out site too ,
Mar 07, 2015 | Cars & Trucks
Error code d282
Communication abnormality between the overall control board
(OACB) and the scanner drive board (SDB). When the power switch (SW2) turns on, there is no SDB response.
Check the connection between these two boards or one is bad! Have tech check it out
Jun 25, 2014 | Konica Minolta Bizhub 500...
Error code d282 bizhub 420
communication error between the main control board and the scanner control board the scanner is that what is below the big glass particularly the mirrors and exposure lamp (Bright light) something is not talking!!!!
Jun 25, 2014 | Konica Minolta bizhub 420
P1740 code on 2001 ram 1500 tcc-overdrive solenoid . how to test & replace
there is a total of 27 diagnostic steps to follow, but here is some info for you:
SYMPTOM
P1740-TCC O/D SOL PERFORMANCE
WHEN MONITORED
The Torque Convertor Clutch (TCC) and Overdrive Clutch (O/D) will be tested each time the PCM requests TCC engagement in 3rd gear and O/D.
SET CONDITION
The code will set if the expected RPM drop is not achieved while attempting to engage TCC or O/D. This indicates a malfunctioning torque convertor or overdrive clutch.
POSSIBLE CAUSES
- Camshaft DTC present
- Engine RPM DTC present
- Fuel level low
- Misfire DTC present
- Output speed DTC present
- P1765 DTC present
- Park/Neutral DTC present
- PTO engaged (if equipped)
- Torque converter clutch DTC present
- TPS DTC present
- Transfer case in low range (if equipped)
- Transmission Relay DTC present
- Transmission temperature too cold
- Intermittent
- Check transmission fluid-debris
- Check transmission fluid-stall
- 3-4 Shift Solenoid
- Oil Pan contains excessive debris
- Shaft or seal damage
- TCC solenoid
- Torque converter
var classElements = new Array(); var node = document; var tag = 'a'; var els = node.getElementsByTagName(tag); var elsLen = els.length; var pattern = new RegExp("(^'\\s)specs_note(\\s'$)"); for (i = 0, j = 0; i
Jun 03, 2011 | Dodge Ram 1500 Cars & Trucks
I have a 2000 dodge durango with a trouble code p1740 what does it mean
SYMPTOM
WHEN MONITORED
SET CONDITION
POSSIBLE CAUSES
Camshaft DTC Present
Fuel level low
Misfire DTC present
P1765 DTC present
Park/neutral DTC present
TPS DTC present
Transmission relay DTC present
Intermittent
3-4 shift solenoid
Oil pan contains excessive debris
TCC solenoid
Torque converter
Aug 15, 2010 | Dodge Durango Cars & Trucks
What is trouble codes present: p1404
a professional chilton or motor manual would have the code translations. some code readers will translate codes automatically.
Apr 25, 2010 | 1998 Saturn SL
3 codes present on my 2002 Envoy. p0172, p0420, and p0340,
Track the p0340 first camshaft timing is very important and could possibly cayse your other codes,Call your local GMC dealer I think I remember a bulletin about this code.
Aug 21, 2009 | 2004 GMC Envoy
77 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
