Question about Dell W2600 26 in. LCD Television
W2600 when first tried will turn on after few seconds can not turn off no front switches work must pull plug to shut off.
    Problem Solver:
  • 7 Answers
You are out of luck.
You have a bad main module. Parts for Dell TV's are not available.
Craig
Posted on May 08, 2009
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
My furnace stopped working. It'd start up shut down start up shut down all in the matter of seconds. Then would fire up and work. it did this maybe once every couple days then it stopped all together. ...
Replace pressure switch. If you blow any air into the pressure switch it has been damaged,check air ports for debris by looking never ,never blow on air switch they work on a very small pressure or vaccum,where your breath is to much pressure and also loaded with unwanted humidity.
boilerman56
Mar 04, 2011 | Goodman GMS90703BXA Heater
I bought the tv new 2-3 years ago and used to work great but now I can't get it to turn on.
Are you trying to turn it on via the remote control? If so, turn the T.V. off at the set, and even go as far as pulling the plug. Wait half an hour, then plug in and switch on - I hope it works. For some reason, T.V's tend to "forget" their internal programming sometimes, and you have to completely switch them off for their memories to be reset. Good luck.
Feb 02, 2011 | Dell W2600 26 in. LCD Television
Dell w2600 tv does not switch on. No audio or video
dell t.v does not turn on. plug is fine. no light;nothing come on what should i do
Jun 24, 2010 | Dell W2600 26 in. LCD Television
Ps3 won't work after pulling out the power cord
Plug it in and turn it on with the switch in the back. Hold the ON button in the front for about 10 seconds. Its gonna beep a few times
That should reset the play station. Game On.
May 06, 2010 | Sony Playstation 3 (PS3) Console
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
Fail to back on
Yes,Ur power ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Dell W2600 26 in. LCD Television
Dell w2600 wont turn
Same problem, this is my solution. The system will start everytime if starting from power off one starts from sleep. Thus the trick is to use sleep mode to shut it down. I do not use the sleep function on the remote (it would be worth a try, let me know if you do that), but rather I have chose VGA as the entry signal ad have hooked the TV to my PC, and then I put the PC in sleep mode. The TV will do the same. When it is in sleep mode through the PC, the system cvomes back to life if the remote from the cable is used to change channels.
Feb 28, 2009 | Dell W2600 26 in. LCD Television
27f400t
this is the EPROM chip or a controling circut on the board
Oct 09, 2008 | RCA P60828 TV
Dell W2600 26 in. LCD Television Logo
130 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
