I have messed about with my eurovox box and messed it all up. now i havno transponder to scan. can uyou help me to get mey box back to tv mode
  • 3 Answers
If you take the top off inside is a reset button right hand side switch off at mains now hold down reset button and switch mains on box should now reboot try a few times hope this works make sure all leads connected proper
Posted on May 09, 2009
Lost most channels any new codes please
Hi if you do a factory reset then turn off the box leave it off for about 30 seconds. turn it back on and do an automatic scan make sure your emu key is on and it should be working, thats what i did with mine.
Hope this helps.
Apr 29, 2010 | StarTech.com StarView SV211K 2-port KVM...
Tip
Box t eurovox or digivox
firstly be more helpfull on the type of box you have if you have loaded the latest firmware or not is it a cable box terrestrial box or sattelite box this info is most helpfull when trying to answer these questions step 1 you must first down load the latest firmware for the box you have if you download the wrong firmware you will corrupt the box or what they term as brick it step 2 after you have down loaded the firmware connect the box to your tv set and aerial/cable/dish these are connected with what are commonly known as F fittings step 3 scan your box you should have a manuall to explain how to do this for the box you are useing step 4 after you have completed the scan you must turn the emu on .on the box you are scanning step5 example if it is the boxT you scanned go to menu press 1570 this then opens a hidden menu on the very bottom you will see key emu left or right press on the > < to turn the emu on after you turn the emu on press exit exit back to main screen you should at this stage have everything working if not redo step 2 on again HINT if you cannot access the hidden menu then you have not installed the latest firmware you cannot access the emu without the firmware been loaded first right hopefully you have all this done and you have your channels happy viewing last hints for you BOX T access code is 1570 .. EUROVOX access code is 1969 ...DIGIVOX code is 1004 now hope this helps
on Apr 25, 2010 | Audio Players & Recorders
I need the eurovox codes 5A 01 TELEWEST/VIRGIN AREA
T.W V.M. CODES
00 CF 53 OC 33 79 61 71 85
01 52 5E 8D 45 FC 75 F6 4A
UPDATED 12/10/09.
Dec 06, 2009 | StarTech.com StarView SV211K 2-port KVM...
I have a eurovox, i recently lost sky sports 2 and 3 in Ireland
First call and make sure they are not having technical difficulties on their end. That could be the issue.
Sep 15, 2009 | Televison & Video
No transponder to scan eurovox max v
If you are in the UK then just factory reset and rescan if you are in ROI then you have to wait for new firmware as encryption has moved from Nagra1 to nagra2.
Some are saying the older boxes will not be supported it's a matter of wait and see.
Aug 25, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox - setanta channels
try this it should help you get channels back.
Try and determine the lowest transponder frequency that you can get a signal on.
Look at the frequencies you already have on the channels saved so far and choose the lowest.
Then in the installation menu select MANUAL SCAN and set that as the frequency.
Make sure you can see a signal and scroll down to Network scan and change to ENABLE with the Right arrow.
While still highlighted, click OK.
Scanning should then begin. It will say 1/1 to start with but should then jump up to 1/?? (the ?? being 2 digits).
Using this method indicated it scanned 56/56 transponder frequencies as opposed to 48 in Auto scan on one main provider.
Dec 10, 2008 | StarTech.com StarView SV211K 2-port KVM...
Cant get sentanta on pure ntl eurovox
try this it might help it not let me know .
Scanning should then begin. It will say 1/1 to start with but should then jump up to 1/?? the ?? being 2 digits.
fergusrb
Dec 09, 2008 | StarTech.com StarView SV211K 2-port KVM...
I reset my eurovox to factory settings and cant update
it looks like you will have to reflash you box. the firmware and how to do this is on here. hope it is of help to you.
http://forums.afterdawn.com/thread_view.cfm/531363
Dec 07, 2008 | StarTech.com StarView SV211K 2-port KVM...
Euromax codes
what to press to start putting the code on eurovox
Aug 17, 2008 | StarTech.com StarView SV211K 2-port KVM...
Connection
The Eurovox should be connected to your TV with the Virgin box tucked away in a cupboard somewhere!
A Eurovox is a cable receiver used instead of a Virgin or NTL box, usually to obtain access to unsubscribed channels.
What are you trying to do, perhaps I can assist with more information.
Good luck.
Jul 20, 2008 | Audio Players & Recorders
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Electro Med Services...
