Question about Astro 3/16" Air / Hydraulic Riveter
Jaws and housing broken - need parts?
The jaw and jaw housing are broken. This is and older model #HH6-A on parts diagram but box says PR-2?
  • 79 Answers
Contact Astro Pneumatics direct at this address; customerservice@astrotools.com
Posted on Jan 15, 2010
I have dremel 4200 ezchange bit broke inside collet how do i take collet out
remove the collet nut
use pliers or the like and pull the collet from the shaft jaws
remove the broken bit
put the collet back in the jaws and refit the nut
Oct 22, 2016 | Dremel Tools & Hardware - Others
How do i remove the clutch drum?
it is pressed into the upper bearing of the shaft housing
remove the shaft housing and place the clutch case in side the jaws of a vice with the housing resting on the vice jaws
gently tap the shaft out of the bearing
May 01, 2015 | Garden
Replacing bearinon spindle housing
Remove deck and place on two boxes or saw horses so that you can access both top and bottom of bolts holding spindle housing. Remove drive pulley from spindle. Remove cutting blade. Remove four bolts holding spindle housing to deck frame, noting which way grease nipple is pointing. Take spindle housing off and scrub deck frame clean of rust etc and also clean housing with wire brush. To remove bearings, look for retainers such as nuts or circlips. Remove these and ensure that the shaft is clean so bearing can be slid off. Apply CRC or light oil to assist bearing removal. Use a vise and set jaws wide enough that the bearing outside can fit between. This is usually 45 to 50mm. [1 3/4" to 2"] Place a hard wood block [or something that will not bruise the thread such as solid nylon] and screw nut well on to thread but make sure there is space for movement between nut and bearing. Firmly tap spindle end. Shaft should go down into top bearing and bottom bearing should start to emerge between vice jaws. Make sure that there is always space between nut and bearing before knocking end of shaft again. To knock top bearing out, place it on bottom over vise jaws and take a length of wood such as a section of broom handle and knock it out. Normally there should be no seals on the inside of these spindle bearings as they are greased from a grease gun thru the grease nipple.
Sep 26, 2014 | Garden
Ja
Ja -
Are you trying to make a model or mini-sized "Jaws of life" or the real thing?
Mar 23, 2014 | Hurst Jaws Of Life / Vetter Vehicle Parts...
My son needs to make jaws of life out of syringes, tubing and cardboard. How on earth do i do that
THE syringes act as the teeth of the jaws of life, the surgical tubing is used to hinge the jaws....fabricate some scissor like cardboard I am done with handles and there you have your Mock jaws of life
Mar 14, 2014 | Vehicle Parts & Accessories
Shredder No Longer Does
Office shredders, even the heavy-duty ones, tend to jam up over time and have to be cleaned up to restore operation. If you have removed all jammed paper bits and still get erratic operation, the shredding process may have bent or broken some internal parts. It is not economically practical to try to repair. Better to buy a replacement.
Dec 27, 2013 | Royal Jaws Shredder
Can a dentist treat a broken jaw?
There are some less severe cases of broken jaws that most dentists can treat although in most cases you will need to visit the emergency room of your nearby hospital.
Feb 03, 2013 | Health & Beauty
The chuck wont tighten
The outer sheath of the chuck turns a thread on the back of the jaws in the chuck and it it is not tightening correctly then the jaw threads have been broken/cracked or the jaws have been stressed out of alignment and are not longer closing in a parallel manner. Best replace the chuck as they are generally not repairable.
Nov 08, 2012 | Black & Decker Compact Power Screwdriver
Jaws of my Hitachi 18V cordless drill are locked shut
Other than two quick squirts of WD40 and nice new chuck key?
Apr 07, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
How are the jaws replaced in a keyless chuck?
They are not, you need to buy a new chuck. The tolerance is so close on the collar that you can't repair it. On some of the older keyed chucks you could but the jaws cost about as much as a new one.
Feb 19, 2009 | Dewalt 18 Volt Compact Drill Kit
Astro 3/16" Air / Hydraulic Riveter Logo
118 people viewed this question
Top Astro Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Astro Air Tool and Compressor Expert? Answer questions, earn points and help others
