FixYa.com
Tags:
Toshiba SD-KT50 System
Sd 43ht toshiba (by 3 users)
posted by alomo on Oct 11, 2007
i got an sd 43ht toshiba home theater, every  time i turn it on shows a message "protection" "good Bye" and turns it off, how can i fix the problem.
tnxs
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Apr 08, 2008
my toshiba sd-kt50 has been working fine for at least a year. today, when you turn it on it says protection then goodbye and turns off. Everything is connected right
Comment by Guest, posted on Mar 06, 2008
my cooling fan is makeing noise. i need to replace it . where can i get the parts.. is there a part list
Best Solution
posted on Oct 11, 2007
Helpful (85)
dukic
Rank:Wiz Wiz
Rating: 83%, 101 votes
In most cases "PROTECTION" message appears when something is improperly connected to system. Try to disconnect everything, and reconnect it step by step.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 04, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Call Toshiba and they will help you, they know about the problem Call 1-877-290-6064 Hope it helps.
Can you Help with these Home Theater Systems problems?
Speaker Wires
I need the wires for three of... Answer This...
my system stopped wroking with...
Toshiba SD-KT50 System my dvd... Answer This...
Unable to set FM radio in INDIA
I purchased Toshiba SD-KT50 in... Answer This...
TOSHIBA SD-KT50
My Toshiba Home Theater System... Answer This...
how i can fix my mpeg on my...
i can see the picture of the... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
