Question about Denon AVR 1312
Denon AVR 1312 green light flashes then a click is heard then the red light start flashing. What do I do to fixed it
SOURCE: denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Posted on Jul 06, 2008
Foxyjay
  • 13 Answers
SOURCE: Denon AVR-1508
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
  • 3 Answers
SOURCE: Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Posted on Jan 05, 2009
localwonder
  • 6784 Answers
SOURCE: shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
Posted on May 21, 2009
  • 163 Answers
SOURCE: my denon AVR 1707 has flashing red light
Only what you can do is to bring the receiver into repair shop. The receiver has a hardware problem.
You can repair here
Posted on Jul 16, 2010
Denon AVR-1312 turns on displays for a second switches off and the red light starts to flash
you most likely have a shortedchannel in the amp that would need to be repaired
Jul 31, 2014 | Denon AVR1312 51 Channels Receiver
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Denon avr 1312 green power flashing green 7 times
Sounds like a bad power transformer. Would need to go in for repairs.
Jan 09, 2013 | Denon AVR 1312
My denon avr 1312 does not start. the power butten is red but not flashing. display off. no reaction whatsoever. any ideas?
unplugged the unit and do these reset
if these have already been done, and symptoms persist
the unit needs servicing.
Aug 20, 2012 | Denon Avr-1312 Home Theater Av A/v...
Denon avr-1506 will turn on then flash red and turn off... how do i make it stop or fix it??
In most AV receivers if the standby light flashes after turning on and you don't hear the regular click of the relay engaging after 4 seconds, indicates an output short or amplifier failure. The protection circuit prevents any further damage by not turning on system.
You will need professional help to fix this problem because even to a electronic enthusiast the construction of a typical AVR is not service friendly.
Jul 01, 2011 | Denon AVR-1506 Receiver
The green light flashes when power is turned on and then flashes red and turns off. Can this be reset ?
what do i do when my DENON AVR-1506 turns on then flashes red and turns off?
Mar 08, 2011 | Denon AVR-1506 Receiver
My denon AVR 1707 has flashing red light have disconected all speakers and it still flashes red is there anything else i can do.
You can repair here
Jul 14, 2010 | Denon AVR-1707 Receiver
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
Denon avr-2106 problem!!!
Mar 06, 2008 | Denon AVR-2106 Receiver
Denon AVR 1312 Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
