Question about Sewing Machines
Singer sewing machine 5528
How to set bottom tension?
SOURCE: How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Posted on Sep 17, 2008
Mimito7
  • 128 Answers
SOURCE: No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
Posted on Apr 19, 2009
Zenqi
  • 208 Answers
SOURCE: Singer Featherweight tension assembly
Putting this back together is a thirty second job if you have done it a hundred times. If you have never done it but have mechanical aptitude, it may be a challenge.
Whatever you do, don't bend the check spring out of shape!
Below is a link to the Singer site with the schematic for reassembly. When placing the check spring back in place, place it in about the 6 o'clock position with no tension so that it has a fair amount of check before pulling it up in place..
When setting the tension, at a setting of "1" the tension disks should just be slightly compressing the beehive spring. "0" is almost no tension at all. Normal sewing is 5.
Get all of the parts together and push in the cup with the numbers while screwing on the knurled nut taking care to get the pin in one of the holes.
http://www.parts.singerco.com/CPpartCharts/2_2999/221-1_221K1_221K4_221K5.pdf
Posted on Jun 19, 2009
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
  • 40 Answers
SOURCE: how do i set the tension on my brother xl-3010
I don't have this machine, but the tension on the bobbin is usually set by the tiny screw on the bobbin case. insert the bobbin into the case so that the thread unrolls counter clockwise. Make sure that there is no lint in the bobbin area.
Posted on Jun 01, 2010
How do I fix the looping under the material when I sew?
the looping on the bottom usually is a tension problem, the top & bottom tension are unequal usually fixed by adjusting the top tension.
some people that I've talked with have had success with changing to a different size needle ( depends what type of thread is being used).
when the machine is threaded the foot needs to be up ( this releases tension on the thread), when the foot is lowered it the tension is set on the thread. if the material being sewed is too thick it raises the foot too high & releases tension on the thread ( the material has to be really thick to do this).
if there a piece of thread or lint in or around the tensioner or bobbin area it could cause trouble.
other wise if you've tried everything you can think of, take it back th the store & have them try it & tell you what is wrong.
also this machine has bad reviews (i'll provide a link so you can read them), people having the same problems as you are. the newer singers just don't seem to be the same quality tha the older ones were.
all bad reviews
http://www.amazon.com/Singer-5400-60-stitch-Sewing-Machine/product-reviews/B007ZG9DTQ/ref=cm_cr_pr_btm_link_1?ie=UTF8&showViewpoints=0&sortBy=byRankDescending
mixed reviews
http://reviews.walmart.com/1336/20573406/singer-5400-sew-mate-60-stitch-sewing-machine-5400-reviews/reviews.htm
Aug 26, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
No, sewing machines that use bobbins don't have an adapter like that. It would be difficult to get the bottom tension right working off the spool. The best solution is to fill several bobbins in your thread color before starting to sew. Then when you run out, swap in a new bobbin.
Some advanced machines will warn you when the bobbin runs low. (I've seen the feature on the machines with touch-screens.)
I wish that I had better news for you. A serger might be a an option to consider. They don't use a bobbin and can be used for some sewing projects. You can still run out of thread on one cone before the others run out. (Those machines use 3-4 threads at a time for the basic stitches. The knife can be lowered if you don't want to trim your fabric while stitching.)
(I've got a Singer Touch and Sew and usually don't run out of bobbin during a seam. I will swap bobbins when they are still 1/4 full at times if I get concerned about the bobbin running out.)
May 04, 2013 | Sewing Machines
Singer 5528...help please!
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 5528) & click search
and it will bring up the manuals that are available
try checking the bobbin case for burrs & make sure the the small bar on the bobbin case is not bent
make sure the bobbin case is in correctly
Feb 03, 2012 | Singer Sewing Machines
Bottom tension too loose.
Is it looping on the bottom of the fabric? If so this is a top tension issue, you need to check some things,
-make sure you thread the machine with the pressure foot up ( this allows the tension discs to open up so you can pull the fabric away from the machine with the foot up and allows the thread to get to bottom of the tension discs)
-make sure your tension settings are set to the medium setting. (Usually 4 or 5)
If this still does not help, then turn the top tension knob up (from 5 to 6,7,8,9....)
-If that still doesn't do it, your probably need the tensions reset. Let me know if you need more help.
-Chris
Jun 05, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
Thread bunces up on the bottom causing machine to
I would start by looking for a problem with the bobbin tension. Do you have the bobbin threaded through the case correctly? Is the the bobbin tension set to loose? Another thing that can cause it to spool up on the bottom is if it sews a bunch of stitches all in the same spot or real close, do you have the presser foot tension to loose?
May 23, 2010 | Singer 2263 Mechanical Sewing Machine
Thread bunches up underneath cloth when sewing then machines stalls
check bottom tension...but first make sure your threading machine correctly
either bottom first or top tension....top tension should be set to 4-5 bottom should feel when pulling about the same tension
Nov 24, 2009 | Singer 3116 Simple
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
