Question about Hardware & Accessories
Utilitech 0154182 Can utlilteeh timer, 0154182, be located at ground level and must it be in an upright position?
4 Suggested Answers
  • 10 Answers
SOURCE: Can you please provide instructions
What you are describing is a wall electrical box for a "Wwitch Loop". What this means is that the power source (Hot and Neutral) go to the light first. What the electrician has done is run a wire from the light in which one wire is the hot leg from the source and the other one is the "switched leg" which runs back to the light as controled on-off power to it. The only legitimate way to use this timer would be to replace the wire from the wall switch to the light with a 3 conductor cable (3 current carrying wires and a bare ground or green wire). This would allow you to bring the hot and neutral along with the controlled "switched leg" as this time requires a constant source of power for the timer itself. Don't be tempted to let someone tell you to use the ground wire as a neutral. It is not safe to do that.
Posted on Sep 30, 2010
SOURCE: I put in a Utilitech
Open following link for programming and wiring instructions:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Yes, the timer can be programmed to turn on at 6am and off at 9pm all days of week.
The ground is not necessary for timer to function, however other wiring has to be correct, and white wire connects to neutral, black wire connects to Hot, and red wire connects to wire going to switch.
Timer replaces single-pole light switch only and cannot be used for 3-way switching.
Posted on Jul 19, 2011
SOURCE: I have an Aube 3
Utilitec can only replace single-pole switch.
Open following link for typical Utilitec single-pole wiring:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Aube timer has internal battery that runs clock mechanism and does not require neutral wire.
The Aube battery lets timer replace single-pole or 3-way switch.
Utilitec timer does not have battery, so clock mechanism requires neutral wire, just like plugging in electric clock.
Without battery, timers like Utilitec can only replace single-pole switch.
Open following link to see list of timers that can be used for 3-way:
http://waterheatertimer.org/Aube-timers.html#3-way
When installing 3-way timer, the timer replaces one 3-way switch but other 3-way switch remains.
The remaining 3-way is rewired to accommodate the specific timer being used.
SOME brands of timer cannot replace either 3-way switch, but instead can only replace the 3-way that receives hot wire from breaker: Read manual before selecting timer.
Note: Battery-operated timers can be used for 3-way application, but cannot operate in cold environment.
Posted on Aug 14, 2011
Utilitech digital timer
The timer could have been miswired.
Mar 12, 2014 | Hardware & Accessories
Can utilitech timer, 0154182, be located at ground level and must it be in an upright position?
Don't put timer at ground level where it can get wet of covered with snow.
Otherwise will work in any position as long as photoeye turned away from lights.
http://waterheatertimer.org/Woods-timers-and-manuals.html#photo-eye
Gene
h
Nov 27, 2013 | Intermatic Inc. ST01C Digital In-Wall...
Connecting utilitech 141224 to light switch
Utilitec timer require neutral wire, or ground wire.
Copy following link for instructions:
http://waterheatertimer.org/How-to-wire-timers.html
Jul 24, 2012 | Hardware & Accessories
I have an utilitech outlet timer #tmo1dhbl and I am having a problem with setting the time can you tell me what to do? Thanks
My files show Intermatic TM01DHBL is 24-hour analog dial timer with 1 grounded outlet, and a switch located on top of timer.
http://waterheatertimer.org/images/Woods-59366-image-500.jpg
This timer has segments that raise up:
http://waterheatertimer.org/images/Raise-segments-240.jpg
Open following link for setting information:
http://waterheatertimer.org/How-to-set-timers.html
If this is not your timer, then add a comment with clear description of timer.
Aug 12, 2011 | Hardware & Accessories
I have tried to install the Utilitech timer but am having trouble. I have a ground, black, and red wire that were previously wired to a switch that controlled my outdoor garage lights. I tried to hook red...
Sounds like this was probably a three-way switch you are replacing as there is no neutral (white) wire in the box. If so, you can splice the white wire to the green wire in other three-way switch box; then hook the green wire in the box you are placing the timer to the white wire of the Utilitech timer.
Apr 17, 2011 | Intermatic & Self-Adjusting Wall Switch...
How do I program a Utilitech 0148297 timer?
See following link to identify your timer with instructions:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59419
Rotate dial until current time lines up with arrowhead; when plugged in, dial rotates
48 segments located on dial; each segment is 1/2 hour
Segment pulled up = lights OFF
Segment down = lights ON
Override switch located top of timer, move switch to TIMER
If you do not want additional free help, take advantage of fixya phone support.
For a price, fixya expert speaks to you via phone while you set timer.
Dec 30, 2010 | Woods 59200 Lamp and Appliance Timer with...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
