Question about Air Tools & Compressors
Fix a firing pin on a leinad model dd - Air Tools & Compressors
Fires once, then why doesn't the firing pin return to fire again?
It could be one or both of the return springs are damaged (this typically happens when you fire the gun without it being against timber, had a young apprentice firing across a worksite for fun which wrecked the springs), could also be that the firing pin is bent or there is an obstruction in the cylinder preventing the pin which is fixed to piston from returning correctly.
Jun 08, 2015 | Tools & Hardware - Others
I need to fix the direct drive record player on my Electro Brand Retro Cd Am/fm With Turntable 45rpm, 78rpm, Built - In Speakers Model 9263, I dont have the manual and can not find it online.
Are you certain it's a direct drive model, because DD models with 78 speed are not common at all? If it is a DD model then you need to check that power is getting to the motor. There could be a switch that's not turning it on somewhere inside the unit.
May 15, 2015 | Drive Audio Players & Recorders
My 597 22 rifle only every other round will fired. How do I fix it?
Couple of things could be happening:
dirty firing pin channel
Bad lot of ammunition.
Light/broken hammer spring.
Clean it thoroughly and shoot it again.
Mar 19, 2014 | Remington Model 597 .22 Long Rifle 16.5...
Firing pin not hitting primer in center of round, several miss fires.
A .22 long rifle is a RIMFIRE round. The firing pin should hit the cartridge on the rim. If the firing pin energy is too light, it will not fire. Cleaning the bolt/firing pin slot should help.
Aug 13, 2013 | Savage Arms Model 64 Package .22 Long...
Diagram of a model 70 bolt- how to take the bolt apart to change firing pin
Compress the spring. Remove the C Clip. Remove the spring. Remove the firing pin & cocking piece from the shroud. Drive out the retaining pin in the cocking piece. Unscrew the pin. Reinstall in reverse order.
Oct 26, 2012 | Winchester Optics
How to fix firing pin from sticking after each shot?
you might have to clean the firing pin, it may be covered with powder residue..
Mar 18, 2012 | RTO Paslode 902000 IM250 Ii Cordless 16...
I have a daisy model #111 that does not fire
It sounds like the sear pin spring has broken. If it's as old as mine is (very near 40 years old), it would be no wonder! You'll have to carefully open the mechanism and check it. Springs are made that will perfectly replace a broken one; other parts for this particular model are extremely scarce. Good luck with the repairs.
Jul 09, 2009 | Daisy Toys
Winchester model 100 semi-auto 308 cal. how to disassemble?
IMPORTANT Recall info:
WINCHESTER MODEL 100 FIRING PIN RECALL - A notice dated 7-1990 relates the following
“PRODUCT SAFETY WARNING AND REPLACEMENT NOTICE. Attention owners of Winchester model 100
rifles and carbines please read this notice. In July of 1990 the following product safety
warning was issued by Winchester. It has come to our attention that the firing pin in the
Winchester Model 100 Rifle or Carbine may break due to use and metal fatigue and become
lodged in the breech bolt face. If this occurs, the firearm may fire before the action is
locked causing severe damage to the firearm and possibly injury or death to the shooter
and bystander.
WARNING DO NOT SHOOT YOUR WINCHESTER MODEL 100 RIFLE OR CARBINE. Repair and replacement.
A new firing pin has been designed to replace the firing pin originally made for the
Winchester Model 100 Rifle and Carbine. The new firing pins will be available in April
1991. If you own a Winchester Model 100 Rifle or Carbine, please send your firearm to one
of the authorized Winchester Model 100 Firing Pin Replacement Centers indicated below.
Your Winchester Model 100 firearm will be inspected, the firing pin replaced and tested
and the firearm returned to you. The inspection, replacement/testing and return postage
will be accomplished at no cost to you. If other repair or maintenance work is authorized
by you to be performed on the firearm when the firing pin is replaced, such work shall be
at your cost.”
W. R. Long Gunsmiths
2007 Brook Road North
Cobourg, Ontario K9A4W4
Canada Frank LeFever & Sons
RD 2 Box 31
Lee Center, NY 13363
USA Bolsa Gunsmithing
7404 Bolsa Avenue
Westminister, CA 92683
USA Nu Line Guns
1053 Caulks Hill Road
Harvester, MO 63303
USA
If you have any questions concerning this notice, call Winchester Product Service
1-800-852-5734 or write to Winchester Firing Pin replacement Notice, PO Box 10 Cottage
Hills Illinois 62018 Attention Product Service Dept.
The following is Wisner's rendition & info on the subject.
The difference in the old firing pin and the new one is as follows. The old replaced
style, was totally lathe tuned (round). While the new recall style is similar in lathe
turning on the front and back, but in the front midsection it has two flats milled, one
on each side. This makes the center section stronger. Also replaced is the bolt sleeve
lock pin (firing pin guide) which was made to accommodate this different shaped firing
pin
Part number for the new parts are, firing pin =1391ND, bolt sleeve locking pin =1491ND
The word was at the time this recall was in process was that if the firing pin would
break at the mid section and still remain in the gun as two pieces, the possibility of a
premature discharge before the bolt was locked was possible. This apparently was caused
by the firing pin tip (now not having a retracting spring) to be stuck forward, and
thereby slam-firing upon chambering.
The responsibility for the recall apparently was on Olin, as they were the parent company
at time of manufacture. Olin set up regional recall centers at three established US
gunshops. There was a manufacturing delay in the replacement firing pins, and a backlog
occurred, also some collectors did not like the idea of shipping their guns long
distances. Olin then also authorized other gunshops to make the required alterations.
Upon completion of the recall, the shops were to test fire the firearm and to stamp an
assigned letter on the inside top of the receiver as seen thru the magazine well with the
bolt retracted. The letter “B” represented Bolsa Gunsmithing, “L” was Lefever, and “N”
was for Nu-line Guns. The letter “X” apparently was for all the other independent shops.
However this identification information did not get communicated to some of the smaller
shops at the start of the project. The only way to tell if the gun as been modified, if
the ”letter” is not present, is to take the barrel & action out of the stock, remove the
trigger guard assembly and the try to rotate the firing pin by twisting it. If it does
NOT rotate, then the firing pin recall HAS been performed.
For link back to the parts & price list that we make & have for sale CLICK HERE
Copyright © 2004-2007 Wisner's Inc. All Rights Reserved
Back to Additional information To Winchester model 88 & 100 parts
Originated 01-13-2001 Last Modified 03-19-2007
LeeRoy Wisner
Apr 05, 2009 | Sport & Outdoor - Others
Wrt150n dd-wrt firmware slow loading pages
First off thanks for using fixya.com
Second, I too am a dd-wrt user and found a similar problem when using dd-wrt with my IPCOP. You may want to go into the "Security" section of your dd-wrt and disable any fire walling or access-restrictions. Since you are already running zonealarm. Or remove zonealarm if you plan to use dd-wrt as your firewall.
Running multiple firewalls will slow down your network/Internet traffic.
Hope this helps you out.
Jei
Dec 15, 2008 | Linksys Wireless-N WRT150N Router
Air Tools & Compressors Logo
35 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
