Question about Apple iPhone Cell Phones
I've forgotten the password for my apple 4a phone
4a
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 74 Answers
Put the phone in DFU MODE by pressing power and home with the device turned off ... when the screen shuts down again release both home and power (you should find tutorial on youtube just search dfu iphone) ...itunes will recognize the phone and allow you to reflash.BEWARE THIS PROCEDURE WILL DELETE ALL YOUR DATA FROM THE PHONE .
Posted on Jun 05, 2014
Bajanguru
  • 7752 Answers
SOURCE: forgotten privacy lock password
okay what you can do....is eprom it by pressing *2767*2878#.....this will also blank all data you had save on the phone.
Posted on Jan 31, 2008
  • 4 Answers
SOURCE: i forgot my password on
go to the nearest apple store, they should be able to assist you. have you tried a system restore?
Posted on Feb 01, 2009
AmrSabri
  • 59 Answers
Hello jakaleman,
Remove the sim-card and switch on the phone .. and press this code *2767*2878# .. the phone will restore the factory settings.
Thank you for using FixYa.
Posted on Apr 09, 2009
rjel
  • 56 Answers
SOURCE: hi i,ve forgotten my password on my samsung g600 privacy passowrd
you can try to reset your phone
*2767*3855#
disclaimer: all information save on your phone's memory will be erase
Posted on Jul 03, 2009
  • 3 Answers
SOURCE: i have forgotten my password
You can reset your password here:
https://iforgot.apple.com
You will get the new one by e-mail.
Posted on Mar 01, 2011
Does any one know how many valves a 1986-1987 toyota carolla 1.6 has, I think it is 12 or 8
Hi there:
Keep in mind this information:
Japanese market engines:
* 3A-U 1.5 L (1490 cc) I4, 8-valve SOHC, carb, 83 hp (62 kW)
* 3A-LU 1.5 L (1490 cc) I4, 8-valve SOHC, carb, transverse mount, 83 hp (62 kW)
* 4A-GEU 1.6 L I4, 16-valve DOHC, EFI, 130 hp (97 kW)
* 2E 1.3 liter
* 5A-F 1.5 liter
* 5A-FHE 1.5 liter
* 4A-FE 1.6 liter
* 4A-GE 1.6 liter
* 4A-GZE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, supercharger, 165 hp (121 kW) GT-Z
* 2E 1.3 L (1295 cc) I4 cylinder 12v SOHC 73 PS (54 kW; 72 hp)
* 4E-FE 1.3 L (1331 cc) I4 cylinder 16v DOHC 100 PS (74 kW; 99 hp)
* 5E-FE 1.5 L (1497 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 5A-FE 1.5 L (1498 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 4A-FE 1.6 L (1587 cc) I4 cylinder 16v DOHC 115 PS (85 kW; 113 hp)
* 4A-GE 1.6 L (1587 cc) I4 cylinder 20v DOHC VVT 160 PS (118 kW; 158 hp)
* 4A-GZE 1.6 L (1587 cc) I4 cylinder 16v DOHC supercharged 170 PS (125 kW; 168 hp)
North American market engines:
* 4A-C 1.6 L I4, 8-valve SOHC, carb, 90 hp (67 kW)
* 4A-GE 1.6 L I4, 16-valve DOHC, EFI, 112 hp (86 kW)
* 4A-F 1.6 L (1587 cc) I4, 16-valve DOHC, carb, narrow valve angle, 95 hp (71 kW)
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 102 hp (76 kW)
* 4A-GE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, 115 hp (86 kW) 1988/89, 135 hp (100 kW) 1990/91 GT-S
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 93-94 SD
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 100 hp (75 kW) 95-97 SD
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 115 hp (86 kW) 93-94 DX and LE
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 95-97 DX, and LE
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 18, 2012 | Toyota Corolla Cars & Trucks
Replacing oil pan in 1990 Toyota Corolla
Vehicles covered: Toyota Corolla, 4A-F, 4A-FE, and 4A-GE Engines
Here's your maintenance manual entry for the complete procedure:
OIL PAN REMOVAL & INSTALLATION - 1990 Toyota Corolla
4A-F, 4A-FE and 4A-GE Engines
See Figures 1 through 7
1. Disconnect the negative battery cable.
2. Raise and safely support the vehicle.
Fig. 1: Exploded view of the oil pan assembly-4A-F and 4A-GE engines
3. Drain the engine oil into a suitable container.
Fig. 2: Remove the oil pan drain plug to drain the engine oil from the crankcase
4. Place a jack under the transaxle to support it.
5. Remove the splash shield from under the engine.
6. Raise the jack under the transaxle slightly.
7. Remove the front exhaust pipe between the exhaust manifold and catalytic converter. Some models have an oxygen sensor, disconnect the oxygen sensor wiring.
Fig. 3: Remove the front exhaust pipe for better access during oil pan removal
8. On the 4A-F and 4A-FE engines, remove the center mounting.
Fig. 4: Remove the bolts and nuts retaining the center mounting-4A-F engine
9. Some 4A-FE engines and all 4A-GE engines are equipped with a stiffener plate. Remove the set bolts and pull the stiffener plate from the vehicle.
10. On the 4A-GE engines, unbolt and lower the flywheel housing under cover.
11. If equipped, remove the oil cooler hose and union from the oil pan. Remove the two nuts and nineteen bolts retaining the oil pan.
12. Insert a blade between the pan and cylinder block, cut off the applied sealer and remove the pan.
Fig. 5: Insert a blade and tap lightly to loosen the oil pan free from the block
To install:
Note: Be careful not to drop any oil on the contact surfaces of the pan and block.
13. Using a razor blade and gasket scraper, remove all traces of packing (FIPG) material from the gasket surfaces. Thoroughly clean all main surfaces to remove loose material. Clean both sealing surfaces with non-residue solvent.
Fig. 6: Apply a reasonable amount of sealant (FIPG) to the oil pan surface-except 7A-FE engine
14. Apply new packing (FIPG) 08826-00080 to the oil pan as shown. Avoid applying excessive amounts to the surface. Be especially careful around the oil passages.
Note: Parts must be assembled within 3 mins of application. Otherwise, the sealer (FIPG) must be removed and reapplied.
15. Install the oil pan over the studs on the block with the nineteen bolts and two nuts. Tighten the bolts to 43 inch lbs. (5 Nm). Make sure when you install the oil pan drain plug using a new gasket.
Fig. 7: Tighten the 19 oil pan retaining bolts securely-4A-F, 4A-FE and 4A-GE engines
16. If equipped, install the oil cooler pipe, two new gaskets and union bolt. Tighten the union bolt to 18 ft. lbs. (25 Nm).
17. Install the front exhaust pipe (with new gaskets on either end of the pipe) to the manifold.
18. On the 4A-GE engines, install and secure the flywheel housing under cover if removed.
19. On the 4A-FE engines if removed, attach the stiffener plate. tighten the No. 1 bolt first then the 5 bolts in the sequence shown. Tighten to 17 ft. lbs. (23 Nm).
20. On the 4A-GE engines, attach the stiffener plate with the 3 set bolts and tighten them to 27 ft. lbs. (37 Nm).
21. Attach the center mounting and tighten the member side bolts to 38 ft. lbs. (52 Nm), plate side to 17 ft. lbs. (23 Nm).
22. Lower the jack from the transaxle.
23. Lower the vehicle, and fill the crankcase with the appropriate amount of engine oil. Engine oil crankcase capacity is 3.4 quarts (with oil filter change).
Above -9 degrees Fahrenheit, use 10W-40 motor oil, and above 10 degrees Fahrenheit, use 20W-50 motor oil.
24. Connect the negative battery cable, start the engine and check for leaks. If all is well, raise the vehicle slightly and install the engine splash cover.
25. Recheck the engine oil level, top off if necessary.
Feb 14, 2012 | 1990 Toyota Corolla
5(a+3)-a=-(4a-6)+1
For this problem you have to type solve(5(a+3)-a = -(4a-6) +1,a)
See captured image
Oct 18, 2011 | Texas Instruments TI-86 Calculator
A+1/4a
a+1/4a = 4/4a+1/4a = 5/4a
Jan 16, 2011 | Mathsoft StudyWorks! Mathematics Deluxe...
Just simplify this rational algebraic expression 16a^2-8a 1/4a-1
16a power of 2, -8a,),,(1/4a-1) are these two prolems polynomials, to be multiplied togethor? is 4a to the third power-18a squared+8a, used the distributive property
Michael
Oct 04, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
What would the torque setting for a 86 corolla head bolts and cam bolts thank you Jason
4a-c and 4a-ge is 108lbs. for camshaft bearing caps bolts. cylinder head bolts:4a-c =43 4a-ge =44.
Apr 06, 2010 | 1986 Toyota Corolla 2 Door
PS-4A
Tom, Are you logged in as administrator? Have you checked firewall settings on the machine and the router? Permissions(if not admin)? Have you checked the print spool service or another needed service. Just some quick thoughts. Tim
Jan 27, 2007 | Keyspan (PS-4A) (PS4A) Print Server
Cell Phones Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
