AVT-QUAD 2 RF light is on on channel 4
AV Tronics Quad 2 receiver rf light is on on channel 4. What causes this and how do I fix the problem? We experience noise when this channel is not muted but with microphone turned off.
welcomejee
  • 10594 Answers
SOURCE: Telefunken analogue color TV model
As you said, its an analog model tv so it doesn't have Audio-Video connectors to hook up set top box.
Sorry.
Posted on Sep 14, 2008
  • 3 Answers
SOURCE: Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Posted on Jan 29, 2009
SOURCE: Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Posted on Feb 27, 2009
rulds2008
  • 3866 Answers
SOURCE: What is RF CH used for?
RF is used for Radio Frequency on your Qam tuner to break it down its the tuner like cheel 1-99 or 1-125 or digital RF clear Qam tuner so RF is your tuner respectivly. You would use this when you have a OTA over the air antenna or sraight cable meaning from wall outlet to tuner not wall outlet to cablebox.
I hope this clears up the meaning.
Thanks for using fixya.com I hope this was Very Helpful to you.
Posted on Dec 12, 2009
Sutibun
  • 186 Answers
SOURCE: My Super Nintendo turns on but doesnt show
It is the SNES it has the same issues that the NES had simply turn off the machine remove and put back the cartridge and turn on. some times you will have to press the restart button a half a dozen times.
Posted on Jan 22, 2010
Testimonial: "Thats exactly what it was. Thank You very much. "
I connected the dvd cables to the tv which channel does the tv need to be on for ti to work
You haven't given any details of wiring have done with tV to DVD. If it is connected via AV cable, the input to TV must be selected to AV. If it is connected with RF cable to to TV antenna socket, channel-3 or channel-4 has to be selected. The pictures of AV cable and RF cable attached.
This is AV cable.
Apr 01, 2012 | Emerson EWF2703 27" TV
Connecting Digital Decoder to Analogue TV.
The av channel is 0 and then you need to search on channel 0 as i mean tune into the channel
Sep 14, 2008 | Televison & Video
Telefunken analogue color TV model MP-A2055VT-H to connect up digital decoder set-top box. The TV only has an RF input. no other plugs. Searched all 80 channels and I cannot find an AV channel on the...
The simplest solution would probably be the use of an RF Modulator. Feed the RF Mod with the A/V signals from the Conia CSTB12, set it to transmit on Ch 3 or 4, tune the Telefunken to either channel.
In most Telefunken TVs we have worked on, the A/V INput/OUTput would be on the SCART connectors as shown below.
To my understanding, a Conia CSTB12 as sold in Australia has a composite RCA (yellow) Video OUTput and L/R White/Red audio OUTputs. What would be needed would be a A/V signal to SCART adapter/converter.
If your Conia CSTB12 has an S-Video, then this may be used.
If your Conia CSTB12 has an HDMI, then something like this may be used.
Incidentally, should you be interested, there are comparable receivers to a Conia CSTB12 that has SCART OUTputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
Magnavox sdtv tuner i set it by mistake in setup in rf and now i get nothing but power light i cant get back to setup to fix what i did
If you have a friend with a TV that has yellow/red/white connectors, for composite video and left/right audio, connect using the RCA plugs to that TV. Then you can see the 'menu' settings.
You could also connect the Y/R/W connectors to a VCR that has those inputs {most} and connect the VCR RF output on channel 3/4 to the RF {cable connector or 300ohm converter} input on the TV. The VCR would convert the RCA jack stuff to channel 3 or channel 4.
tom
Aug 11, 2010 | Televison & Video
Can you hook up a super nes without AV cords? I have 2 cords, 1 is power and 1 connects to an antenna-like input.. do you need AV cords aswell??
It is called an RF connector.Plug your cable coming into the house from outside into the RF connector,then plug the RF connector into the TV.The TV needs to be on channel 3 or 4,depending on what it is set on the console,to use the console.There should be a selector on the console back.If there is a strong broadcast on the channel you select to use,just change to the other channel.If you have the proper channel,the TV signal will go away and the game will appear.You do not need the A/V cables.
Jul 23, 2010 | Nintendo Super NES Console
I have an analog tv (coax cable) and a new dvd (av plugs) player. How do I inexpensively connect them? i saw the solution posted about the rf modulator. I have a digital to analog tv convertor. Is this...
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
Jun 12, 2010 | Televison & Video
No sound from RF & RR speakers
run new wire to the speakers is what i would do but u have to do it to all due to there possibly being a pre amp in the vehicle.
Oct 24, 2009 | 1999 Dodge Ram
Snes screen jumps, only on certain tv
Try the other channel.
If both are set to channel 4, change both to channel 3.
If both are set to channel 3, change both to channel 4.
Mar 16, 2009 | Nintendo Super NES Console
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
62 people viewed this question
 Grubhead
Grubhead
