Question about Mitsubishi WS-55805 55" Rear Projection Television
Flashing green light
Tv was fine until the other day  when I tried to turn it on the green light just keep on flashing but it won't turn on, then yesterday I tried again it turned on ... but this morning I tried but the green light is back flashing again... it's a mishubishi 1080 WS55513 a 52 inch model 3 years old..i hope you can help me with this one
  • 4 more comments
  • feedjake Nov 29, 2007
    i have the same green light problem is it easy to fix?
  • Anonymous Dec 28, 2007
    was fine until the other day when I tried to turn it on the green light just comes on for 3 seccond but it won't turn on, it's a mishubishi 1080 WS55513 a 52 inch model 4 years old..i hope you can help me with this one thanks KHAN 650-290-1234
  • Boots2 Jan 02, 2008
    I've got the same flashing green light problem...no power. I understand that there is a repair kit that sells for $5.21 that fixes this common problem with Mitsubishi progection TVs. The picture shows it comes with two resistors and two capacitors.
    Does anyone know how to instal these?
  • Neale Jan 03, 2008
    I have a WS-55813 and have the same problem. I had a flashing green light which went off after several hours and the tv could be turned on for several weeks. Now the light blinks continuosly and the tv will not turn on. I have unplugged it for hours but still have the problem.
    Neale
    [email protected]
  • fresno mike Jan 31, 2008
    same problem with the flashing green light, all my internet research indicates the same solution, capacitors, one mitsu bulliten suggested using a 680mf 16v capacitor instead of the factory 100mf. that was a mitsu bulletin. anyway, can anybody tell me where to get these things? or a repair procedure? i would hate to mess something else up because i didnt do something in the correct order. [email protected]
  • Pistol23 May 11, 2010
    Mike or others on this request... Do you still need help with this problem? If so let me know and I can email you directions on how to fix (pictures included) and tools needed.
I had the same problem with a WS 55813,2004 model.Paid 130.00 for local Mitsubishi authorized dealer that told me I needed a new DM module at an additional 505.00. Called Sears and they repaired the board for 146.00 by replacing four capasitors on the board. The tech said there is an exolaination on the web that explaines how to do this. He said this is a very common problem and carries 8 caps with him.He even had to do this to his own tv. The caps are worth 8.00 total.
Posted on Nov 04, 2007
SOURCE:
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
19
What else is it doing are there any lights on or flashing?
Dec 19, 2011 | Sanyo DP19648 19 in. LCD TV
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
May 26, 2010 | Panasonic PT-50LC14 50" Rear Projection...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Mitsubishi WS-55805 55" Rear Projection Television Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
