Question about Canon PIXMA iP6700D InkJet Photo Printer
My printer makes a loud BANG when I turn it on, then displays Error 5100 and is unusable. Your local service rep. says it'll be cheaper to replace than repair but you no longer list this model. 1. Can t be fixed economically? 2. If not, what model do you recommend as a replacement? Paul Robinson
  • pbrobie May 11, 2009
    First, there is no Resume button.  I see Stop/Reset and OK, and tried your procedure with both.  Didn't help.
    The noise, however, I now realize is not a BANG but a very loud scraping, as though the ink carriage is grinding against something.  In fact, I find the carriage fully left when I open the cover. and it does not move to the middle.
    Any better ideas?
  • 11,896 Answers
You should check the metal slide for any kinks in bar, Also check for a broken belt which pulls the ink cartridge along the slide rail.
If the cartridge is not moving, that means there is a jam and it is making the the belt or gears scrape due to the pressure.
So I do suggest dismantleing as much as possible and look for kinks, broken belts, or anything out of ordinary.
If all else fails, take it in or exchange it.
Posted on May 11, 2009
  • 413 Answers
Hello i had the same problem with my canon pixma ip 3000 and i found this steps to reset the printer and it work i hope it will help you in yours.
Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
here is the link for other printers: http://www.cyber-ink.com/member-canon.html
Posted on May 08, 2009
"Service Call Error E54"
This error code indicates a fault with the Main Motor. Either it's jammed or unusable. Unplug the printer from the power source, leave it for around 30 minutes, . While it's turned off, remove the cartridges, check for any damage, then put them back in. After tha, then reconnect it to the power and turn it on again. If this still doesn't clear the code from the display then you'll need to see a Brother service agent to have the main motor replaced.
May 02, 2011 | Brother HL 1650 Laser Printer
Canon mx330 Error 5100 Error 5100 Printer error has occured. Turn printer off and then on again. If this doesnt clear the error, see the users guide for more detail.
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Nov 04, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Error message 5100 on Canon MX300 printer
If the ink cartridges are stuck you can manually slide them back to their default position and check for paper or junk which may have slipped down the paper chute and is blocking the ink cartridges.
Remove the blockage
Reset Printer
Done
I just had this problem and it was easy to fix.
If this not help, buy another printer! Cheaper than service...
Oct 22, 2009 | Canon MX300 Office All-In-One Printer
Selphy DS810 printer. Error code 5100. Possible full waste ink absorber? I just replaced an empty ink tank. Can I fix this problem myself?
How long have you owned the unit? This problem occurred after you changed the ink tank? Once I have more information I can assist you further.
Thanks,
Lee
Oct 16, 2008 | Canon Office Equipment & Supplies
Error 5100
Dear Scub,
Did you hear a loud crunching sound from the printer before the error code 5100 was displayed?
1. You may need to send in the unit for service. Some Cannon Service offer temporary replacement unit while working on yours.
Checking and do-it-yourself inkjet printer repair is messy.
2. You can try check if the print head assembly (carriage) moves freely from left to right. Lubricate/clean if necessary (If your printer has one) check also the **** strip at the back of the carriage. This is a plastic film with multiple dark notch like mark. Clean with cotton swab and light solvent or isoprophyl alcohol.
If these does not solve your problem, guess your back to # 1.
Cheerup And Be Happy always
Mar 25, 2008 | Canon Pixma MP450 All-In-One InkJet...
PHASER 7700 ERROR 30
try this
The following functions will generate a Tech Rep Fault:
  • Error: 30: Belt Home Too long
  • Errors: 12, 13, 14, 15: ATC-YMCK Sensor Fail
  • Errors: 40, 44: Fuser Main/Sub Lamp Temp Too High
  • Enter Service Diagnostics
  • Highlight NVRAM Access and press OK
  • Highlight Clear Tech Rep Faults and press OK
  • Highlight the Tech Rep fault to be cleared and press OK
If you have had the error 3 consecutive times , you do need to send the snippet to the printer to clear the error. The instructions how to do it are in the download.
Other things. You may need to replace the accumulator belt.
You may have toner backed up in the waste auger, you can clean that out and replace the waste bottle.
Cause:
The plastic tab attached to the cleaning blade assembly was broken, this tab opens the cleaning blade waste assembly when the belt is lowered .
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. The waste toner from accumulator belt cleaner could not reach the waste bin and jammed the augur. This caused the grinding noise by stalling the accumulator belt motor. This causes an error 30 code to be displayed.
The belt cleaner does come as a separate part 016-1889-00 and is very easy to fit and much cheaper than a new belt assembly.
Error 30 is a Tech Rep fault. After three Error 30's, the NVRAM Clear Tech Rep Faults will need to be reset to be able clear the Error 30 message.
Mar 04, 2008 | Xerox Phaser 7700 Laser Printer
Service error 5100
may be the driver are not installed correctly ... just try reinstalling the drivers ... and make a check that you have inserted the ink cartilage or not ...
if not insert it and then give try ... it may work ..
if problem persists then call the service rep ...
Feb 07, 2008 | Office Equipment & Supplies
Service error 5100
Error 5100 is either a logic board, or
the code strip (if that is the problem) is another matter -
It is the plastic strip that runs across the printer and through the head
carriage, it is supported at each end (one end under spring tension).
If it has become dislodged it will give this error, also if it has any ink,
grease or other foreign matter on it, it will give errors.
You can clean it with a cloth dampened with water but you need to exercise
great care to avoid pulling it off its anchors.
The other thing to do is clean the stainless steel bar that the carriage sli
des
on and lubricate it with a cloth moistened with 3-in-1 or light machine oil.
If neither of these works then I guess it is repair shop or replacement time
Nov 03, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
ERROR 5100
Hi, Did you hear a loud crunching sound from the printer before the error code 5100 was displayed? 1. You may need to send in the unit for service. Some Cannon Service offer temporary replacement unit while working on yours. Checking and do-it-yourself inkjet printer repair is messy. 2. You can try check if the print head assembly (carriage) moves freely from left to right. Lubricate/clean if necessary (If your printer has one) check also the slit strip at the back of the carriage. This is a plastic film with multiple dark notch like mark. Clean with cotton swab and light solvent or isoprophyl alcohol. If these does not solve your problem, guess your back to # 1. Good luck and kind regards.
Aug 26, 2007 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA  iP6700D InkJet Photo Printer Logo
43 people viewed this question
old marine
old marine
