Sharper image radio controlled weatherstation model LM512
Indoor temp not showing also need to change time and date. need manual
SOURCE: Sharper Image Projection US Atomic Alarm Clock (model number OQ311)
Hi!  I have the manual! ... I will try to scan in the whole manual, but for now:
Setting Alarms:
1) Press and hold ALM1 or ALM2 for two seconds until the alarm time flashes. 2) Press ALM1/HOUR to advance the hour and ALM2/MIN to advance the minute.  The time will display "PM" if set to PM and nothing if set to AM 3) Clock will revert to normal operation when no buttons are pressed for 15 seconds.  The alarm is now set and activated.
Posted on Jul 31, 2008
SOURCE: manual for sharper image clock radio phone NW#400
Press "SET" and hold until "Set Time?" appears, let the button go and press it again. Set the year by using the VOL up & down button. Press and release the "Set" button again and adjust the next item.
When you are done with the last item press "Set" one more time.
Posted on Sep 15, 2008
  • 4 Answers
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
  • 10 Answers
SOURCE: NEED MANUAL FOR SHARPER IMAGE JUMBO UNIVERSAL REMOTE 1613086
The manufacturer of that remote is Emerson.  Here is the manual.
http://mscustomercare.com/forms/JumboRemoteEM_InstructionManual.pdf
Posted on Mar 27, 2009
SOURCE: Need to tranfer codes to jumbo remote,Think I need owners manual
Don't see an answer to this old question, but I just bought this unit. The box has an address: www.mscustomercare.com. Went there and was able to download the manual without any problems. Codes can be manually downloaded or learned from your older remotes.
Posted on Oct 10, 2009
Tip
How to set the time & alarm for SI564
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} After several unsuccessful attempts to locate a user manual for this clock radio, I discovered for myself how to set the time and the alarm for this model by trial & error. Hope this tip helps others!
Press the MODE button located on the top of the clock. The screen blinks the hour with "AL HOUR?" specified. Press the SELECT button to go forward or the PRESET button to go backward. Press the MODE button again to set the "AL MINUTE?" Subsequent presses of the Mode button scrolls through AL BUZZER, AL VOLUME, HOUR, MINUTE, DUAL HOUR, 12/24 HR, YEAR, MONTH, DATE, temp F or C, AREA features. It seems that the clock saves the last setting you made once you stop pressing any buttons.
on May 29, 2009 | Sharper Image SI564 Clock Radio
I thought I was downloading a manual for the Sharper Image Select a Temp. But somehow I downloaded one of my files instead. How do I remove it?
in the internet explorer, go to internet options > general > settings
> view files , this will show you all the files downloaded in temp folder . and you can search by date .
Feb 15, 2015 | Sharper Image The Select-A-Temp 1.7L...
Instruction manual for the sharper image super grill
Hi Philip,
Here's the manual in pdf.
Please rate this answer.Thanks!
Dec 05, 2011 | Grilling
Owners manual and operating instructions
I need the users manual for a sharper image turbo sm240 handheld steam cleaner that I can print off the computer. thank you
Dec 21, 2009 | Sharper Image SI785 Clock Radio
How do i set the time and date on the sharper image splashproof clock radio s1695
While the radio POWER is off, press the "MODE" button 6 times Press "CH-" to decrease hours, "CH " to increase. Press "mode" again when hour is correct. Repeat for minute, month, date, year, etc.
Aug 28, 2009 | Sharper Image Audio Players & Recorders
Need Manual or how to use this!
Press reset button in battery case make sure your plug in also
Press Wave for 2 seconds press + or - to set zone
Press wave set year + or-
Press wave set date " "
Press wave set time to 24 hr real time + or -.
Press wave set to 12 by + or-and it will set temp F
Mar 04, 2009 | Audio Players & Recorders
169 people viewed this question
 Grubhead
Grubhead
