Question about Tools & Hardware - Others
Rexel electric stapler is jammed
We have a Rexel Stella 70 electric stapler which has been in a cupboard for some time but had never been used. I ordered the correct staples and it worked for a couple of weeks. It is now jammed. I removed one staple but it is possible there are more inside. I have followed the instructions ie removed the cover and cartridge,replaced the cover, plugged it in and activated the red trigger numerous times. When I then open the stapler,replace the cartridge and cover, the stapler still outwardly goes through the motions of stapling but no staples come out.
  • 2712 Answers
SOURCE: Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Posted on Aug 27, 2008
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
SOURCE: there's a jammed staple but I can't figure out how to open it to fix the problem and refill it
This is how it works on the Arrow staple gun. On the back bottom, opposite end from where the staples come out, there is a little plate. Push it in and it unhooks and pops out. attached to a rod. When you refill with staples, just push them in, then put the rod back in and the spring applies the pressure.
Posted on May 31, 2009
  • 132 Answers
SOURCE: I need staples forthe swingline electric stapler
Go to Lowes or Ace. Take the stapler or an empty box along.
Posted on Jun 27, 2009
SOURCE: loading staples
Never used one before and sons lost the packaging. No instructions.
Posted on Dec 04, 2009
How do I prevent Rapid 5080e stapler from jamming
Make sure that the tray for the staples is clean and LIGHTLY oiled, Staples are held together with glue. IT could also be an issue with the wear on the staple head driver. If you use it a lot, the unit might be worn to the point that it is out of spec.
Aug 28, 2015 | Rapid 5080E HEAVY-DUTY FLAT CLINCH...
Stapler malfunction
I don't know, but check how frequently the stapler jams.
Dec 10, 2013 | Panasonic AS-302NN Electric Stapler Heavy...
Rexel stapler
Sadly, the solution to this problem is very simply, and stated on the instructions for the stapler, which I ignored myself until I had bought my third one and continued to have the jamming problem. The solution is you HAVE to use the Optima staples they sell. Look for them in the silver metal box, and they are labeled Optima. Once I did that, all three of the staplers worked without a hitch, and I love them. Good luck!
Sep 30, 2013 | Swingline 48210 Optima ® 70 Electric...
How to load staples into rexel easy touch stapler
If you imagine that the end that the staples come out of is the front, then the back is where you load the staples. Your picture shows a small black bit at the very back of the stapler. You have to remove this, usually by pushing it in and lifting it up. Once loosened, it should pull out from the back of the stapler. You should then be able to reload. Finishing is the reverse process.
Nov 05, 2012 | Tools & Hardware - Others
Has anyone found substitute rexel titan No 37 staples for the rexel titan tacker gun yet. The No 88 staples although they fit the gun do not fire as they are not fine enough .The original No37 ones are...
Rapesco Part number is: S14082M3. I've used these without problem
apparently Rapesco has now changed to Tacwise and they are now sold as
Tacwise 0346 (Type 140)
Oct 09, 2012 | Office Equipment & Supplies
My rexel stapler does not work, any help[
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Sep 11, 2012 | Office Equipment & Supplies
How do I open up a rexel stapler?
There's a plastic button on the back of the Rexel stapler that says "press."
May 04, 2012 | Tools & Hardware - Others
I have a rexel odyssey heavy duty stapler but the spring has popped out, how and where do I attach it back on?
Rexel Odyssey heavy duty stapler: The pring that pushes the staples into position can come losse if the stapler iss dropped. It's difficult to work out how to replace it! However, there are only two "lugs" that will take the circular ends of the spring. One obviously fits to the sliding staple retainer. The other to the back end of the pressed-metal inner body. However, to work, the spring must be threaded from this point along the pressed metal parallel-sided inner body back through a slot and over a rounded bent piece (shiny from prvious friction) and back down to the sliding staple retainer. It's trickey to do, but that's where it has to go in order to provide forward tension when the Stapler is closed.
Aug 02, 2011 | Office Equipment & Supplies
Hi Guys Rexel Cosmos 210 Stapler (Staple Gun - Mk II) I have a Rexel Cosmos 210 Stapler that has a broken white plastic bit. I have had it and used it at work for about 25 years. How can I get a...
I have one equally old and my plastic bit broke off many years ago.
I just get used to using it without.
It sticks but it's such a good stapler I forgive it.
Jun 12, 2010 | ACCO Brands Office Equipment & Supplies
Instructions on unjamming swingline electric stapler model 270; jam is at the front of the stapler; staplers come out either broken, flaten or crooked and does not secure document.
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Mar 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Tools & Hardware - Others Logo
257 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
