Question about Philips 50PL9126D/37B 50" DLP TV
Phillips 50pl9126d/37 red light comes and picture goes out
SOURCE: 50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Posted on Mar 23, 2009
  • 14 Answers
SOURCE: my phillips tv picture screen keeps going out
U MIGHT HAVE A PROBLEM IN THE POWER SUPPLY OR HAVE CONVERGENCE PROBLEM IF YOU HAVE A LITTLE KNOWLEDGE ABOUT IT CHECK UR PRIMARY THEN YOUR SECONDARY IN POWER SUPPLY WITH DIGITAL METER, IF UR READINGS LOOK GOOD THEN CHANGE THE STK'S THE ONES THAT CONTROL THE CONVERGENCE FROM PAST EXPERIENCES STK'S ARE THE ONES THAT MOST LIKELY GO OUT. IF YOU DONT KNOW HOW TO DO THESE THINGS CALL A TECH.
Posted on Jan 29, 2010
SOURCE: I have a Phillips 50pl9126d/37
I currently have this problem also. However my TV is blinking 6 times fast and then 5 times slowly. I was told by a TV repairman that it was in fact the bulb or lamp. I plan to replace it, soon, I will keep you posted hopfully it works.
Posted on May 17, 2010
  • 8457 Answers
SOURCE: I have Philips 50PL9126D/37 The
The tv projection lamp in this tv been in the tv it like 2 years or more,tv in used daily like 4 or 5 hrs every day?The red LED light indicator is on,have a "LAMP"word written on the bazel frame?Yes,tv projection lamp life is over or eding.Tv reqire a new projection lamp.
Posted on Apr 05, 2011
hardrocko
  • 1476 Answers
SOURCE: have a phillips 50pl9126d/37 put new bulb still no
bearsdis,
I have a tip at http://www.fixya.com/support/r5207658-dlp_tv_run_after_replacing_lamp which explains the troubleshooting procedure and where to get any parts that you may need.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on May 26, 2011
My 50 inch Phillips tv model #50PL9220D/37 wont turn on? blue power light is just flashing ? what could be the problem?
Hello more than likely the lamp has gone bad. On that set you have to remove the back cover to check the lamp to see if it has broken. the picture gives you an idea and some instructions on how to change it. tks7bef3142-61c4-4329-b27d-2507769a830c.jpg
Nov 04, 2013 | Philips 50PL9126D/37B 50" DLP TV
My Phillips 50PL9126d/37 is making a loud humming noise and the picture color is barely there.
Hi, Sounds like a bad color wheel. If you know what your doing you can get one on E-bay for around $170. In the past the whole light engine would need to be replaced $700 ish.
Good Luck
May 20, 2013 | Televison & Video
Where is the power board for a phillips 50inch model #50pl9126d/37
Hello
As far as the lamp stays lit for a few seconds, all other voltages comes to the lamp and inverter board are OK. If the lamp has reached its life time, this type of fault can occur.
Feb 16, 2012 | Philips 50PL9126D/37B 50" DLP TV
Phillps tv model number 50pl9126d/37 what is the red light mean
It depends on whether you are able to see a clear image or not. check the lamp first if its more than 2 yrs old you may need a new one, last one we checked with the problem you describe had a fan running slow. The fan nearest the lamp needs to run correctly or the tv will shut down. Good luck !
Nov 11, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
I have a Philips model Problem with the Philips 50PL9126D/37B 50 in. HDTV DLP TV I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
Apr 22, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have Philips 50PL9126D/37 The red light on the front where the power indicator is keeps coming on. What does this mean? When it comes on my screen goes blank. Any suggestions?
Apr 05, 2011 | Philips 50PL9126D/37B 50" DLP TV
Philips Model 50PL9126D\37 Turn TV on and after a
Ur LCD inverter board is dead,must change to get ur picture back.It usally a long board.
Jan 21, 2010 | Televison & Video
I have a Phillips 50pl9126d/37 it wont turn on picture or sound blue light in the front flashes 6 times fast looked at the bulb and it doesnt seem broken ie( no glass bits inside broken off) otherwise...
Dec 11, 2009 | Philips 50PL9126D/37B 50" DLP TV
Mar 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips TV, Model # 50PL9126D/37
Check to make sure all the ventilation opening on the tv arent plugged. if not, then you will have to make sure all the fans inside the tv are working properly.
Sep 23, 2007 | Televison & Video
Philips 50PL9126D/37B 50" DLP TV Logo
16 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
