Question about Refrigerators
Thermador Fridge has E20 displayed - what to do?
Display window is no longer lit but can see the E20 code displayed. What does it mean and how do we fix it?
5 Suggested Answers
SOURCE: Error code F32 for fisher
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
Posted on Nov 09, 2008
sonicboomele
  • 1557 Answers
SOURCE: What does if mean when the display reads ER CF
it means there is a fault with the units compressor fan you will notice the fridge is running with less noise you will need to call a service man to come fix it good luck
Posted on Apr 21, 2010
taran_2005
  • 10515 Answers
SOURCE: my electrolux side by side
This is a really bad error on this model.
EF error means there is a problem with the control board. You should unplug the unit for 30 seconds and plug it back in. If this does not clear the problem you could try unplugging the unit for 12 hours in order to clear the internal memory and battery (this has worked for me a few times) If this fails to clear the problem you will need to replace the control board
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 27, 2010
  • 183 Answers
SOURCE: Display no longer remains lit
refer to your use and care guide( owners manual) if there is a way to turn it on and off it will be explained there.
Posted on Jan 07, 2012
Power module replaced on my Thermador T241F70NSP/03 built-in-freezer which fixed inoperative display. Now I get a click sound but the compressor is not starting. How do you check compressor?
You bought a Fancy fridge, now pay a Fancy technician to fix it...
Trying to own Thermador appliances on a budget is not possible nor is it intelligent.
Sep 03, 2016 | Thermador Freezers
E20 Error
Hello Diane Snow, thank you for your inquiry!
I understand that your Frigidaire washer is displaying "E20" error code. The "E20" error code means water is not pumping out fast enough. First, you want to check the hoses for restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would suggest seeking assistance from a professional technician for proper repair. I hope this is helpful. -Matt
Oct 06, 2014 | Frigidaire Washing Machines
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
Jan 07, 2012 | Kenmore Refrigerators
CODE F64 WHEN TRYING TO USE THE BOTTOM OVEN.
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Mar 29, 2011 | Thermador C302U Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
F24 error code
Hello there
  1. Turn the oven off and wait three minutes before turning it on again if "F -24" or "F-25" is displayed. These error codes mean the keys on the control panel were pushed or touched for longer than 60 seconds. Leaning against the oven or hanging objects in front of the controls can cause these error codes to appear.
  2. 3 Press the "Oven Off" key to clear the display and reset the oven if an "F" followed by two numbers is shown on the display. Wait three minutes, and turn the oven on. This type of error code indicates a problem with the signal received by the electronic control board.
  3. 4 Write the error code down if an error code displays more than once. Thermador recommends calling a service technician if an error code reappears.
Dec 04, 2010 | Whirlpool Kitchen Ranges
Error code F64 on lower thermador oven. Works for a minute or so then beeps and F64 is showing,
Nov 12, 2010 | Thermador Ovens
What does E20 code means on a delco cd player?
Hi E20 mean's
The CD player cannot focus on the disc or there is an internal focus problem.
try a known good CD and if it still displays E20 then you will have take it to a radio repair shop
May 10, 2009 | 1997 Pontiac Sunfire
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
