Question about Winter Sports
Mr christmas 1993 santa ski slope replace motor
Need to replace gear motor
3 Suggested Answers
SOURCE: need gearmotor model 100
Kmart
Posted on Nov 27, 2012
SOURCE: i am going to visit oslo in a couple weeks and i would love to go skiing but I'm not in oslo for so long so dont want to travel far to a slope. is there anywhere to downhill ski in/very near downt
Oslo Winter Park is just 30 min from downtown Oslo with some incredible slopes!!http://www.visitoslo.com/en/product/?TLp=12087&Oslo-Winter-Park
Posted on Feb 27, 2013
Error 54 please
Precor Error 54, Target Pulses Lost During Operation Probable Cause 1. Blown F2 fuse.
2. Gear motor wiring is damaged or has intermittent connection.
3. Gear motor is bad.
4. Gear motor target is damaged.
5. Lower PCA is bad.
Corrective Action
  1. Disconnect power from the unit. Remove the F2 fuse from the lower PCA. Using an ohm meter, measure the fuse for 1 ohm or less. If the reading is considerably high, replace the fuse. If the fuse is blown, inspect further for the cause to avoid the fuse blowing again. Inspect for damaged gear motor wiring or a bad gear motor. Replace if necessary.
  2. Thoroughly inspect the gear motor wiring for damage or intermittent connections. Repair or replace damaged wiring or poor connections as necessary.
  3. With unit disconnected from power, disconnect both wires from the gear motor. Using an ohm meter, check for approximately 9 ohms through the gear motor wiring. If the reading is considerably high or low, replace the gear motor.
  4. Inspect the gear motor target for rips, tears, or bad scratches. If any of these are found, replace the target.
  5. During the start up sequence, check the voltage at the gear motor. Voltage should be approximately 12VDC. The voltage should only be present between the time the sequence was started and the error 53 occurred. If the voltage is considerably low or absent and the F2 fuse proved good, replace the lower PCA.
Precor Error Code 54
Nov 02, 2013 | Precor Efx 5.17
Drum motor noise
Need to open the entire printer, don't feelbad if you are capable you start to open other pl don't open it,its major issue..While printing main motor driving entire printer except fuser assm, entire printer load on Main motor assembly, in main motor assembly contains motor and gears, pl see the marked gear in snap I experienced this gear found warn out, this is suits hplj 5200 main motor gear, you can choose this gear and its easily available.. replace this gear, but opening the printer is difficulty.. thanks..
Feb 04, 2012 | HP® LaserJet M5035 MFP Laser...
Intermediate gear and armature gear stripped on Milwaukee 6082. Is the armature gear replaceable? How do I remove both gears? How do I remove armature from motor housing?
No the armature gear is made as part of it. the intermediate gear is replaceable but you need a press. to remove the armature first unplug tool and remove brushes, then remove the 4 screws that hold the gear housing to the motor housing and pull out. the intermediate gear is pressed onto the shaft.. Let me know if you need more assistance before voting and thank you
Feb 20, 2011 | Milwaukee Saws
I have a 1990 bronco, and the driver side power window won't go back up. I believe the motor is shot, and I probably need to fix it, so how would I go about doing that? does anyone have instructions on...
first try to replace the switch,
if not, you have to take out the door panel, and then you'll be able to get to the elevator, the motor comes out easy, it's fixed just with some screws
Mar 13, 2010 | 1990 Ford Bronco
Headlamps are stuck in the up position. There is clattering, like a motor gear slipping, whenever lights are turned on or off
Hello, my name is Ben. You may know this is a very common problem in Corvettes. Chevrolet uses plastic gears in the headlight motors and the gears fail over time. You headlight motors are going to need to be rebuilt. There is a company that makes a brass gear to replace the plastic gear. I'm not sure if you are wanting to do the work yourself or having it done. If you are mechanical and feel you can accomplish the repair, I can send you the procedure.
Feb 26, 2010 | 1993 Chevrolet Corvette
My 05 seat will go front to back,tilt,but not up or down. do i need a new motor
HI. I would check the control section for loose wire connections first. make sure that all connectors are tightly connected to there respective locations on the motor. If the control wiring harness is ok, and connected well, move on to the gear assembly. The up/down function will use a gear assembly. If you are hearing any clicking while trying to initiate the up and down motion, this will indicate that the gears are stripped. the gear plat will need ot be replaced in this case. If the gear assembly is ok, go ahead and replace the motor.
Nov 11, 2009 | 2001 Dodge Durango
Does flip up lights have vaccum and were at
No, they're electric motor driven. One motor for each headlight. Most of time the problem with these headlights are,
1.The drive gear has teeth worn off, (It's Nylon)
You can do a Temporary fix that may get you by for 4 months to a year, or replace the gear. It's your call.
The temporary fix is to remove the Lift Arm from the shaft of the headlight motor. (10 Millimeter wrench)
Then use the Manual Override Knob, (Rubber cover that has "Remove for Manual Adjustment". Remove it to get to the manual override knob)
Turn the knob on top of the headlight motor until the Rotator Pin, turns 180 degrees from where you started from.
Now you're using part of the gear that hasn't been previously used. The gear only rotates 180 degrees when lifting, or lowering the headlight. (Circle is 360 degrees. Half circle is 180 degrees)
Reinstall the Lift Arm.
This video link, shows you how to access the parts I'm talking about for a temporary fix, and also how to replace that gear.
Tells of how to install a Brass gear, to replace the Nylon one.
I'm not advertising for the gear manufacturer, I'm linking the video for reference of how to do the above.
http://www.fquick.com/videos/Install_for_Firebird_Headlight_Gear/2024
Nov 05, 2009 | 1995 Pontiac Firebird
Got a 02' 125 ttr and it make a knocking noise in first gear? shifts fine and no other noise in other gears.
You have a broken tooth on the first gear set. This means two gears will need replaced; the drive gear and the driven gear in first gear range. DON'T just replace the gear with the broken tooth. Replace the gear it meshes with also.
Jul 23, 2009 | 2002 Yamaha TT-R 125 L
97 cadillac deville power window motor replacement drivers side
The motor sit on a gear stem you will have to wiggle it a little to get it off the magnet inside is holding it to the window frame just use a little pressure to remove.
Jul 16, 2008 | 1997 Cadillac DeVille
Winter Sports Logo
153 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
