Question about GE 30 in. Profile JP350 Electric Cooktop
30 IN JP345 CERAN PROFILE SELECTOR KNOBS - GE 30 in. Profile JP350 Electric Cooktop
I KNEED NEW KNOBS FOR MY SCHOTT CERAN BLACK GLASS HOB
The reference to Schott, is the maker of the ceramic glass itself. The label outlining the manufacturer and model number will be located on the base of the cooktop. Once you obtain that, contact the distributor to obtain the required knobs.
Nov 14, 2016 | Cooktops
My Schott Ceran cooktop will only work on full heat and will not simmer at all. why?
usually there are 2 elements a smal and a large the small one possibly burnt out .
Apr 20, 2015 | Whirlpool 30" Schott Ceran Surface...
Maytag schott ceran front eye wont get hot
I navigated the SCHOTT website to find a solution and was able to find out how to properly clean my SCHOTT stove top. I would check the Ceran FAQ list to see if your question is answered before anything else.
Nov 19, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
Just purchased Ilve Ceran ceramic cooktop. Is V364X the cooktop model number?The outer are of the left front burner does not heat up
You may already be aware of this but ... If our ilve ceran cooktop is the same as yours turn the knob past the 12 setting till you feel pressure and it springs back. This is the switch to fire up the marked outer elements.
Mar 11, 2012 | Cooktops
I have a GE Profile 30" Ceran Schot cooktop mottle black glass.One of the burners has burnt in partial ring that will not come off with the recommended cleaners. Is it possible that it has literally...
If there was sugar in the item that boiled over, it will not come off it etches the glass. If it was with out sugar you might try a razer blade to scrape it off it will not hurt the glass if you use it flat
Sep 27, 2017 | GE 30 in. Profile JGP989 Gas Cooktop
Liquid spilled on cooktop Ceran schott
You will have to clean the control area connections .
Oct 09, 2017 | Cooktops
Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Apr 18, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Ceran stock top chipped and cracked
most of thoose ceran tops have a five year parts only warrenty read your owners under 2-5 years warrenty if it does call ge cust assistance to see what you can do
Jan 20, 2008 | GE 30 in. JGP328 Gas Cooktop
GE 30 in. Profile JP350 Electric Cooktop Logo
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
