Question about Andis RACD Pet Clipper
Andis racd Blades oscillate but do not cut the dog hair. Changing the blade does not fix the problem
SOURCE: My Blades won't move.
GET MONEY MONKEY DAT IT
Posted on Jul 12, 2009
  • 8 Answers
SOURCE: adjust blade
On the Andis T-Outliner or Outliner if you have use the trimmer for more than 3 hair cuts or 3 time or more I do not recommend moving the blade, reason why is that you have all ready start or have a sit in or a grooved, I have found that by moving the blade it won't cut at all.You need to resharpen the blade with a professional sharpener and have them reset the blade for the type of hair cut you want. The blade can be set to shave or do line ups, and Fades. This type of trimmer is for that kind of hair cut the professional barber use them all the time. Call Mannys Sharpening 323 263-4697 They have a good rating on Yahoo Local.
I have try many sharpener and had no luck, until a friend of mind told me about Mannys Sharpening, They know what they are talking about highly Professional in thier work.
Posted on Aug 01, 2009
  • 61 Answers
SOURCE: My andis agc2 clippers will not cut hair now.They
clipper and blade simply needs adjusting
Posted on Dec 28, 2009
brector3
  • 1610 Answers
SOURCE: how do I adjust the blades or sharpen blades.
Clipper blade sharpeners are availale but the cost of these typically start at about $300 and go as high as several thousand dollars. This makes it unaffordable for home use.
For affordable, professional clipper blade sharpening, I suggest you contact the folks at clipperparts.com
Your clipper moves at just one speed. There is no way to 'speed it up' if it is working correctly.
Posted on Feb 06, 2010
SOURCE: My andis t-outliner keeps pulling hair when
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Posted on Jun 20, 2010
I have an Andis 10 blade model MBG2 that i use on my border collie and miniature schnauzer. When i go to cut my dogs hair it works perfectly for a few seconds (which leads me to believe the blade is still...
When is the last time you cleaned and oiled your blades? Or if you have been using them for a long time they may need to be sharpened? Blades experience wear and tear and require regular maintenance.
Aug 08, 2013 | Pets - Others
When i cut hair my andis master clipper seems to get stuck while cutting hair causing me to take longer with the fade how do i go about fixing it to where it doesnt get stuck in hair & by the way im...
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
Jun 19, 2010 | Andis 01690 Hair Trimmer
My andis t-outliner keeps pulling hair when cutting and it barley cuts the hair. Do the blades need adjusting?
Jun 08, 2010 | Andis 01690 Hair Trimmer
Brand new blades #10 in perticular leave stripes
hi, new blades are not the answer try replacing the blade drive assembly which is located at the drive end of the clipper and goes from side to side, as the clippers are used this part will gradually wear in width thus not moving the cutter far enough to complete a cut this will produce snagging in smaller blades and tram lines in larger blades like 7, 5, 4 and 3's. All Clipper Parts are available for these clipper repairs.
May 29, 2010 | Andis 01690 Hair Trimmer
Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Aug 13, 2009 | Andis Health & Beauty
Andis Super 2 Speed AGC Clippers - The blades get very hot !
Buy some Kool Lube (Oster) or Andis Blade Coolant. Both are aerosols. Your 2-speed runs faster, so your blades heat up quicker. Check them often by touching them to your inner wrist, and spray them when they are hot. A bonus is that the sprays also disinfect! (FYI a hot blade can badly burn a pet, so make sure you keep them cool)
Apr 09, 2009 | Andis 29745 Clipper Headliner Hair Trimmer
Andis pm-3 dog clipper won't cut anymore!
I have had this same problem!  I bought new blades, sharpened old ones, and nothing worked.  Finally, I went to an authorized service center and they couldn't figure it out.  Then the tech. pressed on the blade (the outside bottom one) and it cut!  When you remove the blades with the 2 big screws, there are 2 more smaller screws inside under the smaller blade.  One of those was not screwed in tightly.  That was all it was!  I guess they jiggle loose.  I hope this helps!
peony
Mar 02, 2009 | Andis ProMotor PM-3 Hair Trimmer
Andis RACD Pet Clipper Logo
Top Andis Pets - Others Experts
Ross Keen
Anglia Clipper...
adam adms
adam adms
Are you an Andis Pets - Other Expert? Answer questions, earn points and help others
