Question about Garden
Won;t restart.. after mowing and turning off mower to clean\ off deck and try to start again the mower won;t start and just clicks
  • May 11, 2010
    Dose it start after you let it dry for a long period of time (Like overnight)?
  • 41 Answers
Check battery,if it's good, check charging system.
Posted on May 08, 2009
Have a black/decker electric mower that motor slows and dies while mowing.
Your battery is in its death throes and not charging properly. Ergo, it runs "out of gas" fast.
Mar 07, 2016 | Electric Garden
Clutch adjustment for engaging dec
You clutch is probably OK. This sounds like some binding in the mowing deck.
  1. Take off the deck.
  2. Clean the underside of the mowing deck.
  3. Remove the belt and be sure all the moving parts move freely. If something is bound, try to free it up with oil.
  4. Replace any bound up bearings. Bearing are a very high maintenance item on a mowing deck.
Good luck.
Apr 05, 2015 | Garden
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
How do i restart my cubcadet model cc46es after it stalled because of grass
disengage pto start up move to alredy mowed area shut off and clean grass from under deck restart it turn on pto cut grass
Jul 11, 2014 | Cub Cadet Garden
******* mower cutting deck restart failure
Your switch may be bad or wire come off.
Jun 08, 2013 | Garden
John Deere La175 Battery doesn't charge while mowing. After I mow for an hour or so and turn tractor off, it won't start. When I put the charger on it for a second or two, it turns over and runs....
I had the same problem. My LA 175 mowere deck would not engage and I figured out that the battery was not sending the sufficient 12volts to the mower deck to run the mower. I replaced the battery and that fixed the problem only to reveal the original problem. Within 2 hours of mowing the battery again died. I replaced the voltage regulator and that didnt help. I need suggestions on where to go from here please. Anybody?
Apr 22, 2012 | Garden
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
Strange noise from deck of Toro LX426
The engine wont have an impact with the deck because its belt driven. It sure sounds like you have a bad set of spindle bearings,just turning it by hand you wont hear any noise it has to be going fast to hear it. The noise may be coming from your clutch instead of the deck,and it sounds like the deck. Have these things checked out.
Aug 09, 2009 | Garden
Craftsman DYT 4000, 24 hp 48" deck. While I was mowing, the blades stopped turning, started again, and then stopped. I shut down, all looked OK, tried to start and nothing. No click, nothing. Any ideas?
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Jun 12, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
211 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
