Need to replace missing screws in the adjuster plate. Can't, wheel is in the way, (it's the drive wheel)
SOURCE: Need to know how to adjust the rubber drive wheel
Usually just replacing the drive wheel will fix the problem. There are two allen head set screws on the disc mounted on the engine shaft visable through the hole in the rear of the mower. However, don't expect when you loosen them that the disc will move up or down freely. I've only ever move one by taking the engine off. I'd try replacing the rubber drive wheel first.
SOURCE: honda lawn mower wheel drive works, but needs adjustment, how?
Take the covers off the drive,there should be a hollow bolt the cable comes thru, it should have 2 adjustment nuts This lengthens or shorts the cable. There also may be a adjustment on the handle.
SOURCE: stripped screw needs to be removed
hello. You will probably have to drill out these screws enough to use a tool called a screw extractor. That said take a look at this excellent link http://www.ehow.com/how_2078426_remove-stripped-screw.html
Joe
Testimonial: "thank you very helpful"
SOURCE: Poulan pro front wheel drive
Is the height adjuster tight on both sides? if loose the bolt holes may be elongated, both sides set the same? any wheel wobble indicating worn out wheels?.if it checks out as good put the machine an a known hard level surface such as a garage floor and check the clearance by turning the wheels by hand without putting pressure on them, If the wheel still slips the mowing deck may be warped or bent. if all wheels are original there shouldn`t be a question of mismatched wheels ie:different sizes.
