Question about Garden
John deere parts diagrams
I have a lt66 and when I turn the key there is a buzzing noise and smoke from the positive terminal on battery and starter? Whats the problem
pic498
  • 32 Answers
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Posted on Jun 13, 2009
  • 218 Answers
SOURCE: blade position for 155c john deere
Hi..my name is Keith...to answer your question..there is no certain position to put the blades and there is enough clearance that they wont hit...but there is a proper torque on the nut when reinstalling the blade..and its usually like 100 foot pounds..i hope this has helped
Posted on Jun 30, 2009
SOURCE: how to replace belt on john deere 425
take a sharpy and outline it before removing
Posted on Jul 19, 2009
wireguy212
  • 1627 Answers
SOURCE: I have a Deere LX188 mower, while mowing the
you need to check the seat switch first then have the park brake switch looked at.is there power to the starter relay?
Posted on Jul 23, 2009
SOURCE: John Deere 318 won't start. Replaced starter/alternator.
I don't think it's electrical. The starter gear gets jammed against the teeth on the flywheel. Try tapping the edge of the gear with a drift of some kind then try starting again. It won't solve the problem long term, but it will save you spending time troubleshooting an electrical problme that doesn't exist.
Posted on May 04, 2010
2.4. Why doesn't it start?
check for voltages at the battery and starter, the large terminal should have battery voltage and the smaller terminal should only have battery voltage when the key is turned to the crank position. if these are good the starter is bad.
Jul 12, 2015 | 2002 Dodge Stratus
1993 mbz 300e won't turn over, battery full charge and buzzing noise from relay area.
hi,
the first thing that I would check is to make sure your battery is fully charged or try and jump the battery using another car battery.
if still no go then I would say that your starter solenoid is bad.
while checking the solenoid/starter double check to make sure your block to body ground cable is secure.
hope this helps,
chris...
Sep 26, 2012 | Cars & Trucks
My 2007 Yamaha 650 will not start. The headlight does not come on. When I start it, it tries to turn over but there is a buzzing noise that comes from the center section of the bike (almost directly...
Hi, Robyn and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty kickstand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Won START Buzzing sound from main fuse
VSTAR Starter click then buzzing sound
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
https://dd5394a0b8ca8e97ba29-abf76f3d91a2125517d6c7c409f095c7.ssl.cf1.rackcdn.com/content/common/manuals/1999/LIT-11626-12-30_126.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 17, 2012 | 2007 Yamaha V Star Custom
When i try to start the car it makes a click click clicking noise like the starter motor isnt engaging but also the battery is shorting/smoking?? any help?
It sounds like the starter is jammed and overloading the battery, causing the solenoid to drop out when the voltage falls too low due to the dead short on the battery. Remove the starter and check that the bendix in not jammed on a worn ring gear.
Mar 21, 2011 | BMW 318 Cars & Trucks
96 Olds Aurora wont start nothing happens when i turn the key,battery is good.
CHECK THE INSTRUMENT CLUSTER FOR POWER TO GAUGES TO SEE IF THEY WORK WHILE IGNITION IS IN THE ON POSITION.IF NO CHECK THE 40 AMP IGNITION FUSE.IF FUSE GOOD IGNITION SWITCH IS BAD OR HAS A LOOSE OR BROKEN WIRE.IF FUSE GOOD ALL GAUGES IS WORKING.I BE LOOKING AT STARTER AND STARTER SOLENOID.REMOVE THEM HAVE AUTO ZONE TEST STARTER.OR YOU CAN GET A REMOTE STARTER SWITCH AND SET OF BATTERY CABLES.HOOK BATTERY CABLES TO A BATTERY.WITH STARTER OUT OF CAR TAKE BATTERY CABLES HOOK NEGATIVE BATTERY TO STARTER BODY FOR GOOD GROUND.TAKE POSITIVE BATTERY CABLE HOOK TO STARTER POSITIVE TERMINAL WHERE POSITIVE BATTERY CABLE GOES.THEN HOOK THE REMOTE SWITCH RED WIRE TO STARTER POSITIVE TERMINAL AND THE OTHER REMOTE SWITCH WIRE TO THE S OR SWITCH TERMINAL ON STARTER SOLENOID.PRESS THE REMOTE SWITCH IS STARTER RUNS GOOD WITH NO FUNNY NOISES ITS GOOD IF STARTER DONT RUN THE STARTER SOLENOID OR STARTER IS BAD. THE PROBLEMS IN YOUR CAR COULD BE A BAD KEY TRY ANOTHER KEY YOUR CAR HAS THE THEFT DETERRENT MODULE SYSTEM BEST TO HAVE CAR SCAN TO CHECK THE THEFT SECURITY MODULE AND THE TRANSMISSION NEUTRAL SAFETY SWITCH IF ITS BAD STARTER WONT WORK.ALSO CHECK THE THEFT DETERRENT MODULE RELAY. BEFORE REMOVING BATTERY CABLES TURN OFF RADIO SO YOU WONT LOSE YOUR RADIO PLAYING CODE.
May 20, 2010 | 1998 Oldsmobile Aurora
93 wrangler won't start. no clicking when key is
If the battery is brand new then yes, the starter assembly/starter solenoid (located on top of the starter) is bad.
Oct 31, 2009 | 1995 Jeep Wrangler
1996 buick won't start
Try having someone turn the key to the start position while at the same time someone else taps on the starter with a hammer. If starter begins to crank the engine or makes weird noises or begins to smoke then you need a starter. If nothing happens, then using a test light or a volt meter check for power at the "S" terminal of the starter solinoid when the key is turned to the start position. The "S" terminal is the small terminal to the right of the terminal where the battery cable goes when viewed with the battery cable terminal at the 12 Oclock position. (usually a purple wire). Hope this helps.
May 07, 2009 | 1996 Buick Skylark
1991 volvo electrical problem
When did you change the timing belt last? Have you checked to be sure the cable from battery plus terminal is secure and tight as it runs to the starter? I would check the battery cables - if the starting current is too high and the cable is corroded or loose, the starter solenoid and starter motor might not be getting any current. I run a heavy duty battery jumper cable from the positive battery terminal direct to the positive starter terminal. If the starter turns, the problem is in the electrical connection in between. Another idea - there are fusible links under the hood designed to blow when overloaded. One of these might be out.
Sep 08, 2008 | 1991 Volvo 240
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
