This occurred after I replaced my color wheel and lamp. All the other video connections work fine, did not try HDMI connection. One time moving the cable connection gave me video, but could not duplicate it again. Used different cables and input devices. No luck.
Sounds like something isn't connected securely inside. Go back and recheck your cables, particularly the DVI cable. Report back if this doesn't solve your problem and we'll try something else.
What's happening is power up chime, and faint volume. I can change channels. Meanwhile, no pic,...
(More)
What's happening is power up chime, and faint volume. I can change channels. Meanwhile, no pic, and the lamp light flashes. After a minute or so this repeats, and then powers on and off, until ultimately all three lights end up flashing simultaneously, with no sound.
I have a Samsung HLN 617 W and I turned it on today and it worked fine then later this evening we...
(More)
I have a Samsung HLN 617 W and I turned it on today and it worked fine then later this evening we turned it on with the controls on the side of it because the remote would not work and the channels were going up and down and all over the place. I tried to change the input but was unsuccessful. I held the volume button down on the side of the tv and change the input and got the menu up. It would not function properly only letting me go down the menu even when pressing up left or right. bulb is new,color wheel is new. It just keeps switching back from no signal to not available. The remote does not turn it on or allow me to use anything but the light blinks on the tv showing it is recieving a signal from the remote. It will show a picture when it is surfing the channels and there is sound. Light from the bulb can be seen when looking at the back. Color wheel can also be seen spinning the colors. Can someone please help me with this problem. This is a great tv. Thank you Jason
