Question about Baby Jogger City Elite Stroller
Replacement brakes
Drain brake fluid
check for fluid leaks at hoses , pipes and brake callipers and cylinder units. Pull the vacuum hose off the booster and check for brake fluid in the hose. (wet). Repair the fault-replace calliper leaks, replace wheel cylinders , replace brake lines and replace the brake booster.
Fill with brake fluid and bleed out starting at the longest line first and finishing at the shortest.
Sep 03, 2014 | 1992 Nissan Sentra 4 Door
Tip
How to Change Your Brake Pads
Brake Pads should be replaced in pairs, the front will wear faster than the rear so usually the front will need to be replaced more often.
First Here is a list of what you will need. This list mainly applies to disc brakes but I have included a link for how to replace drum brakes with graphic images. All parts can be purchased from an auto parts or hardware store.
  • New Brake Pads
  • C-Clamp
  • Small amount of Brake/Caliper Grease (usually comes in a small packet)
  • A can of Brake Cleaner
  • Car-jack and lug wrench
  • A small bungee cord
  • Wrench/Socket/Allen Wrench (depending on your car)
  • A hammer (mainly for drum brakes)
  1. Lossen the lug nuts.
  2. Jack up the vehicle.
  3. Remove the tire from the vehicle.
  4. Use the brake cleaner to spray the brake pads and disc taking care not to spray plastic parts on the vehicle. This is done to partly protect yourself from the brake dust and to also clean everything and help remove rust.
  5. The following steps are for disc brakes, for drum brakes skip to step 15.
  6. Next, remove the caliper bolts, the heads will be located on the inside side of the caliper, the wrench needed will vary base on vehicle make and model.
  7. Slide the caliper and brake pads off of the disc.
  8. Remove the outer brake pad.
  9. The bungee cord may be used to keep the caliper from hanging freely. Do not allow the brake line to be bent or hold the caliper itself.
  10. Use the C-Clamp to slowly depress the inner brake pad as far as it can go. If any brake fluid leaks out of the reservoir, it may need to be replaced once brakes are replaced. Make sure to press the brake pedal several times between each tire having brakes replaced to help keep brake fluid from leaking. Some brake fluid may be siphoned beforehand to prevent loosing any fluid.
  11. If the disc is to be replaced, do so now, spray the new disc with brake cleaner to remove any residue. The disc should be replaced if grooves or chips are found on it, or if it is outside of thickness specifications of the manufacturer.
  12. Grease the caliper bolts.
  13. Put the new brake pads on the caliper and slide the brake pads and caliper back onto the disc and insert the bolts.
  14. Skip to Step 18 for disc brakes.
  15. For drum brakes, use the hammer, brake cleaner, and possibly a pry bar to remove the drum which should slide directly off.
  16. Use the brake cleaner to spray the brake pads and other parts within the drum to clean and prevent dust from being breathed in.
  17. Use the following link for better information on how to replace drum brakes http://www.2carpros.com/articles/how-to-replace-rear-brake-shoes-and-drums
  18. Mount the tire, bolt on the lug nuts, and remove the jack.
  19. Press the brake a few times and clean up.
Congrats on replacing the brake pads on your vehicle.
Benjamin
on Jan 06, 2011 | Dodge Intrepid Cars & Trucks
2006 brake light will not go out
Light gets power from brake light switch/.May be switch got shorted an brake light getting non-stop power causing it not to turn OFF brake light.
Get the brake light switch checked. Check volt at brake light switch.
It can be faulty brake light switch causing the problem or its wiring short for switch.
To trouble shoot brake related problem, check the help links mentioned below:-----
Click the link:----
1996 Buick Regal Grand Sport Brake light Switch Location?
http://schematicsdiagram.blogspot.in/2012/04/1996-buick-regal-gran-sport-brake-light.html
No brake lights on Buick?
http://schematicsdiagram.blogspot.in/2012/04/no-brake-lights-on-buick.html
Brake lights not working on 1989 BUICK REGAL?
http://schematicsdiagram.blogspot.in/2012/04/brake-lights-not-working-on-1989-buick.html
How to replace Brake light switch on Chevrolet Tahoe?
http://technoanswers.blogspot.in/2012/02/how-to-replace-brake-light-switch-on.html
How to replace Parking, turn, and Brake Lights on car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-parking-turn-and-brake.html
Upper brake lights work, but low brake light not working?
http://schematicsdiagram.blogspot.com/2011/12/upper-brake-lights-workbut-low.html
1997 Cadillac Catera: How to replace Brake Light Switch?
http://howtobyme.blogspot.in/2012/06/1997-cadillac-catera-how-to-replace.html
1996 Chrysler LHS brake light circuit wiring diagram?
http://technoanswers.blogspot.in/2012/02/1996-chrysler-lhs-brake-light-circuit.html
How to replace rear Brake lights on 2004 Toyota RAV4?
http://schematicsdiagram.blogspot.in/2012/02/how-to-replace-rear-brake-lights-on.html
One brake light on driver side not working, but other lights work?
http://schematicsdiagram.blogspot.com/2011/12/one-brake-light-on-driver-side-not.html
2002 Lincoln Town car Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/2002-lincoln-town-car-fuse-box.html
2007 KIA Rio: Brake Light Fuse Box Diagram?
http://repairhelpcenter.blogspot.in/2012/06/2007-kia-rio-brake-light-fuse-box.html
Overhead Brake lights not working on 1999 GMC Sierra 4x4?
http://technoanswers.blogspot.in/2012/03/overhead-brake-lights-not-working-on.html
http://schematicsdiagram.blogspot.com/2012/11/brake-lights-not-working.html
2004 Ford Mustang: Brake light Fuse Location?
http://howtobyme.blogspot.in/2012/05/2004-ford-mustang-brake-light-fuse.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Case 4210 wiring diagram
It can be faulty brake light switch causing the problem or its blown brake light bulb.First check and confirm brake light lamp is working and that's not the case.
To trouble shoot brake related problem,check the help links mentioned below:-----
Click the link:----
1996 Buick Regal Grand Sport Brake light Switch Location? http://schematicsdiagram.blogspot.in/2012/04/1996-buick-regal-gran-sport-brake-light.html
----------- No brake lights on Buick? http://schematicsdiagram.blogspot.in/2012/04/no-brake-lights-on-buick.html
---------- Brake lights not working on 1989 BUICK REGAL? http://schematicsdiagram.blogspot.in/2012/04/brake-lights-not-working-on-1989-buick.html
How to replace Brake light switch on Chevrolet Tahoe? http://technoanswers.blogspot.in/2012/02/how-to-replace-brake-light-switch-on.html
---------------How to replace Parking, turn, and Brake Lights on car?
1997 Cadillac Catera: How to replace Brake Light Switch? http://howtobyme.blogspot.in/2012/06/1997-cadillac-catera-how-to-replace.html
------------1996 Chrysler LHS brake light circuit wiring diagram? http://technoanswers.blogspot.in/2012/02/1996-chrysler-lhs-brake-light-circuit.html
----------How to replace rear Brake lights on 2004 Toyota RAV4? http://schematicsdiagram.blogspot.in/2012/02/how-to-replace-rear-brake-lights-on.html
One brake light on driver side not working, but other lights work? http://schematicsdiagram.blogspot.com/2011/12/one-brake-light-on-driver-side-not.html
---------- 2002 Lincoln Town car Fuse Box http://schematicsdiagram.blogspot.com/2012/11/2002-lincoln-town-car-fuse-box.html 2007 KIA Rio: Brake Light Fuse Box Diagram? http://repairhelpcenter.blogspot.in/2012/06/2007-kia-rio-brake-light-fuse-box.html
-------------Overhead Brake lights not working on 1999 GMC Sierra 4x4? http://technoanswers.blogspot.in/2012/03/overhead-brake-lights-not-working-on.html
---------2004 Ford Mustang: Brake light Fuse Location? http://howtobyme.blogspot.in/2012/05/2004-ford-mustang-brake-light-fuse.html
---------These will help.Thanks.
Nov 23, 2012 | Cars & Trucks
Brake esemble diagram
Hey Stan the man,need your vehicles info.,year,make,model and engine size and Tommy on the spot here will send you a picture diagram of your rear brake assembly.There's a special spring tool you can get at auto parts store to remove and install springs,me got one.
Oct 15, 2012 | Cars & Trucks
How to trouble shoot the brake system?
To trouble shoot the brake system you have to check:AntiLock Brake System ABS:
Hydraulic Modulator
Basically this unit holds steady or bleeds off pressure in brake line, as necessary, when the Electronic Brake Control Module (EBCM) detects an abnormal deceleration in the speed of the wheel. On 2000 and later models the EBCM and Brake Pressure Modulator Valve (BPMV) are mounted on a bracket attached on the left strut tower.
Wheel Speed Sensors, brake fluid level, brake hoses and lines, inspect and replacement, Brake hydraulic system-bleeding, Brake light switch, check, adjustment and replacement.
Disk brake caliper, disk brake pads, drum brake shoes, master cylinder, master cylinder reservoir, O-rings replacement, parking brake adjustment, parking brake cables inspect and replacement, parking brake shoes-replacement, power brake booster, check or replacement, wheel cylinder inspect and replace.
Oct 10, 2010 | 2000 Chevrolet Venture
Video for replacing front brakes pads and rotors on a 2004 ford e
ccr20011001bb00.jpg Brake Bleeding
Purging air and moisture from your binders
CarCare - Maintenance - Brakes
ccr20030701as00.jpg ABS Speed Sensor Service
A clean sensor is a happy sensor
ccr20030701db00.jpg Drum Brakes - Rear Brake Drum Adjustment
It's stupid not to adjust your rear drum brakes
ccr20050201rr00.jpg Replacement Rotors
Friction, brake rotors, and you
ccr20050501pb00.jpg Power-Bleeding Brake Systems
Air today, gone tomorrow
ccr20050701bp00.jpg Replacing Brake Pads
How to replace worn pads
ccr20071101bs00.jpg Bleeding Power Steering
Getting rid of that air in there
CarCare - Maintenance - BrakesThanks
May 29, 2010 | 2004 Ford Escape
No brakes
check master repair kit replace rubber cup , replace brake line that are leaking and check and replace brake pads on the brake drum.
Jul 10, 2009 | 1995 Honda Accord
Rear axle bearing replacement
REAR WHEEL BEARING/ HUB
Removal Procedure
  1. Raise the vehicle. Refer to Vehicle Lifting in General Diagnosis.
  2. Remove the wheel and the tire. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
    1. Remove and support the brake caliper. Refer to Brake Caliper Replacement (Front) or Brake Caliper Replacement (Rear) in Brakes.
    2. Remove the brake rotor. Refer to Brake Rotor Replacement in Disc Brakes.
    3. Remove the ABS sensor wire connector.
    4. Remove the four bolts from the control arm.
    5. Remove the hub and bearing from the control arm.
    6. Remove the brake shield from the control arm.
    7. Clean the control arm face and the bore before installing the hub and the bearing.
    Installation Procedure
    Notice: Refer to Fastener Notice in Service Precautions.
    1. Install the brake shield and the hub and the bearing to the control arm with the four bolts. Be careful not to drop the hub and the bearing, as it could be damaged. Reconnect the ABS sensor. Tighten the hub and bearing bolts to 70 Nm (52 ft. lbs.).
    2. Install the brake rotor. Refer to Brake Rotor Replacement in Disc Brakes.
    3. Install the brake caliper. Refer to Brake Caliper Replacement (Front) or Brake Caliper Replacement (Rear) in Disc Brakes.
    4. Install the wheel and the tire. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment. Tighten the wheel nuts to 140 Nm (100 ft. lbs.).
    5. Lower the vehicle.
Feb 14, 2009 | 2002 Pontiac Bonneville
Baby Jogger City Elite Stroller Logo
27 people viewed this question
Top Baby Jogger Baby Gear Experts
Lyle Siemens
Lyle Siemens
john h
Are you a Baby Jogger Baby Gear Expert? Answer questions, earn points and help others
