Question about Delfield Refrigerators
I HAVE A DELFIELD MODEL V18796-DOM-1
WERE CAN I FIND INFO ON THIS UNIT TRYING TO REPAIR TOP UNIT FREEZES BOTTOM DOESNT COOL
5 Suggested Answers
SOURCE:
  • 958 Answers
SOURCE: not cooling on top
that's very odd...normal air flow is from top to bottom, could be the light is always on, a defective door switch. look at the light and gently close the door, observe the light, it should turn off before the door closes tight.
Posted on Feb 14, 2008
  • 3 Answers
SOURCE: top of the freezer will freeze but bottom want
Could be same as problem I just fixed.
Remove back panel inside freezer and
1. check fan operation
2. check for ice/water at bottom of the hidden section. There should be a drain hole, which may be blocked by ice. Fix by turning off and pouring boiling water in there until blockage is fixed
See http://www.fixya.com/support/t1507330-ice_collects_in_bottom_freezer
Posted on Jan 26, 2009
  • 672 Answers
SOURCE: top freezes but bottum doesnt cool
The fan has quit working or is blocked. The fan is usually located in the back of the freezer, under a cover. this is easily changed if you have access to parts and a few tools, you can probably replace it yourself. Unplug frig while removing fan and the cover, remove the fan attaching screws, unplug the wire, reverse sequence for installation. It is safe to leave the frig plugged in while you get replacement fan. Whirpool makes Kenmore so you may be able to get the fan at Sears parts center.
Posted on Jun 28, 2009
imufo2
  • 3773 Answers
SOURCE: my frigidaire side-by-side FRS23LH5DW5 freezes
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 19, 2011
We have a Delfield Fridge on top, freezer on bottom, the only number we can find anywhere is SL Series SLR/F. We need to order parts and door gasket but don't know where to go will little info on freezer,...
We specialize in cooler/freezer gaskets and have a custom made gasket option that would be helpful if you cannot locate the model and serial on your unit. It's a simple process at coolergaskets.com
Step 1: visit our custom made gaskets page HERE and identify the gasket profile material that best matches your existing gaskets. Common Delfield profiles: 165, 221, 494, 548, 770, 802, 891, and 967
Note: If you have a hard time with this we offer a $1 gasket sample ring.
Step 2: Input the outside edge dimensions you need your gasket to be (length and width) and how many sides it has (3 sided gaskets are most common for walk-in coolers/freezers, You will want precise measurements. Here's our " How to measure your gasket" video.
Step 3: Select the quantity you want and add that gasket to your cart where you will be able to proceed to check out there. Then relax because your gasket is in good hands!
I hope this helps!
Matt
[email protected]
855-288-2259
Nov 02, 2010 | Delfield (F18WC60) Commercial Refrigerator
Screen showing eror-7
http://www.delfield.com/?xhtml=xhtml/del/us/en/general/partsandservice/archivemanuals.html&xsl=minisite.xsl
since you did not supply any info, lik model or serial numbers, check out this site for a manual on your unit and see if you can find what you need.
Sep 01, 2010 | Delfield Freezers
How do i replace the gaskets on the three part refrigerator?
Replacing your gaskets on your Delfield unit is a simple process. If you can locate your model and serial # on the inside data plate just give us a call or shoot an email and we'll identify the gasket you need. If you cannot locate that info then we offer a custom made gasket option: http://www.coolergaskets.com/custom-made-gaskets/
Here's our How To Videos to help start the process: http://www.coolergaskets.com/how-to-videos/
Matt - 855-288-2259
[email protected]
Aug 11, 2010 | Delfield (F18RR60) Commercial Refrigerator
Need run pressures
You have to give more info. What refrigerant, where is the unit located so ambient temps can be considered, is there a cap tube or txv.
http://www.delfield.com/docs/uploaded/del/manuals/DM6000XL.pdf
Try this web site from Delfield. It should be you manual. It says your unit has 404-A. Check it out and let me know if you need more info.
Dec 16, 2009 | Delfield Freezer 6125XL-S
Delfield model #mrr2n-s ser. 0403036101321-t ice
can not immediately locate manual.
If this unit is a cooler, check this:
Anything that can effect air flow. Fans not running or running in wrong direction.
Too much product in unit.
Thermostat set too low or stickes and unit does not shut off unit.
Possibly has a defrost timer. Most coolers do not but some do. Look for one and see if it is working. Make a mark on the face and wait 15 minutes to see if it moves.
Drain pan clogged.
Doors not closing or seals not sealing.
these are the things to check out.
Aug 03, 2009 | Delfield (F18WC60) Commercial Refrigerator
Unit freezes up.......Freon Leak?
Your AC unit is low on refrigerant. It should be recharged. be sure to keep the filter cleaned all the time as well. If this is an inexpensive unit, it may be cheaper just to get another one, since a lot of people would charge around $100. to charge it. hope this helps you, Rick
Apr 18, 2009 | Heating & Cooling
F&P E402B Active Smart Fridge Compartment not cool
You need to start with a clean totally defrosted unit. That means clean, vacuum and wipe as much as you can around the entire motor compressor area especially any coils you can reach. Then set temp around whatever normal is and see what happens. If still the same it's time to have a tech do pressure tests.
Mar 29, 2009 | Refrigerators
I work in a restaurant that uses a delfield upright.it has sliding glass doors on top,and solid doors on the bottom. it is a refrigeration unit only.the bottom door hinges are always falling off. i say its...
Yes. The unit should sit level.
Screw the front legs out to level it up.
If that does not give enough height,
Have someone help you tilt it to the rear and place small wood blocks under the front legs.
Mar 17, 2009 | Refrigerators
Delfield model st4660n 2door cooler no cold air
sounds like the temperature control is not calling for the cooling unit to energize. I would start there. first.
Let me know if I can be of any further help
Dec 09, 2008 | Delfield 60 Refrigerated Work Top Model...
Refrigerators Logo
106 people viewed this question
Top Delfield Refrigerators Experts
Dennis Boxerman
Marvin
Marvin
Steve Mason
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
