Question about Columbia Sportswear Watches
ALARM FOR CL-3004
TURNING OFF ALARM
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
How do I set and turn on/off the alarm function?
Hugo Boss Watches have a MOVADO watch movement the PDF Manual accessed via the URL below contains information on how to set the alarm.
URL http://www.movado.com/media/manuals/pdfs/hugo-boss/MDE_internet_EN_120514en.pdf
Nov 24, 2012 | Hugo Boss 1512657 Watch
Timex expedition wr100m alarm
TURNING OFF A TIMEX IRONMAN (the wr100m is the one I made this work on) ALARM: hold "set" to set each alarm to "on," not "hide." exit. flip through the modes until each alarm shows. don't hit "set," hit "start" or "stop." it should then switch from showing as daily or whatever to showing as OFF! good luck. so, UNHIDE, SHOW ALARM, DON'T SET, STOP -> OFF.
May 04, 2012 | Timex Expedition Watches
Quicksilver arcade watch alarm
Hey Malcolm, just bought this watch so I hope it is the same. Press the MODE button (bottom left) until you get AL. Then press the STAR/LAP (top left) this gives you the options of turning it off : ON with Alarm or ON with Alarm and CHM (I think this is the hourly chim) or OFF. (Located above the Quicksilver brand mark) Hope this helps!
Carla
Nov 24, 2011 | Watches
I have a wacky wake up timex alarm clock and can't set it to correspond with daylight savings.
You press and hold down the time set button...once the time starts to flash you use the "fwd" or "rev" buttons to change the time to what you want it set to. The alarm is set the same way...just press and hold the alarm set button until the time flashes. :)
Nov 01, 2009 | Timex Watches
Turning alarm offI
how do I turn off the hourly setting
Jan 19, 2009 | Casio DB360G-9A 30 Pages Telememo Watch
I just got a Freestyle Tide Watch 3.0 for Christmas. I set the alarm, and now I don't know how to turn off the alarm. It only seems to give me the option of which days I want the alarm to go off, no...
I had the same problem. Emailed Freestyle support, it's pretty simple: Go into the alarm setting, and before you do anything else, push the reset button. That'll clear it. If you push the set button first, that'll put it in the set it mode, and the reset button will just advance you to the next setting.
Dec 26, 2008 | Freestyle Shark Tide Data 4 Alarms All...
GapKids Watch turning off the alarm
If you don't have the instructions, the buttons are labeled as follows:
Top Left is "Light" - Button A
Bottom Left is "Mode" - Button B
Top Right is "Start" - Button C
Bottom Right is "Reset" - Button D
With the time displayed, press the reset ("D button as listed in the instructions) and the alarm time should be displayed. While holding the "D"/reset button down, press the start or "C" button to toggle the alarm on or off.
Hope this helps
Dec 19, 2008 | Nike Triax Fly WK0006 009 Watch
Pulsar v041 9100 no manual Need to turn off alarm.
Press both buttons on left side of the watch at the same time to toggle through turning the alarm off and on.
Jul 12, 2008 | Pulsar Watches
Sector adv 1000 setting alarm
key for setting time can be pulled fully (to set time) or shortly (only 0.5-1 mm) for setting alarm. then you should turn it and watch how it moves (automatic, without your turning). when it comes to desired time just push key in. the watch will automatically rewind to present time and it will re-start running.
Apr 14, 2008 | Watches
Watches Logo
18 people viewed this question
Top Columbia Sportswear Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Columbia Sportswear Watch Expert? Answer questions, earn points and help others
