Question about Car Audio & Video
Difficulty wiring into GM harness
Trying to install a Durabrand DB1215 CD Receiver into a 1995 Plymouth Voyager with a wiring harness. Got all the wires hooked up except the orange illumination wire(in vehicle harness). Keep blowing fuses trying to figure it out.
  • cjmcfeeley11 May 09, 2009
    Black is to ground. not enough wires from receiver to connect to harness. I've verified red and yelllow and black. Orange illumination wire in GM wiring harness is the one I'm trying to find a place for. No power till it's hooked up somewhere. Had it hooked up in another vehicle just not sure where the illum. wire was.
  • May 11, 2010
    Look closely at your hot leads. It sounds like you have a hot wire that is to ground. What color are you thinking the hot leads are?
  • 34 Answers
Well if your trying to actively wire it up with the car battery still connected that is why you are blowing fuses. just a heads up too if you have a live connection while hooking up the cd player you could short out other electrical devices and you could be in alot more trouble thatn just blowing fuses. the black wire is what is blowing fuses its because you have it hooked up wrong to a wire that is sending voltage not recieving voltage. ground the black wire to the actual chassis instead of hooking it to the ground wire from the harness or whatever color its grounded to which shouldnt be anything but black if you have the black wire hooked up to ANYTHING that isnt black that is why you are popping fuses. so hook up the red yellow and make your own ground you shouldnt have any problems after that.
Posted on May 08, 2009
Im looking for a transmission wiring diagram for a 95 plymouth voyager se with the 3.3l engine
Plymouth Voyager Repair Manual / Service Manual Online ...
? 0:43
https://www.youtube.com/watch?v=2GqbKAZhMcY
Dec 14, 2014 - Uploaded by Tanner Jackson
If you need a Plymouth Voyager repair manual, you're in luck. ...steering, suspension, engine, transmission, air conditioning, heater, or something ... 1994, 1995, 1996, 1997, 1998, 1999, 2000 (90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 00) .... Plymouth VoyagerDodge Caravan 1996 19971998 1999 2000 3.3L ...
images for wiring diagram plymouth voyager
Nov 28, 2015 | Plymouth Cars & Trucks
We are trying to replace a 1995 Plymouth Voyager, how do you remove the belt-we can't locate the belt tensionor?
The tensioner is located just under the alternator. It has a nut sticking out for you to put a wrench or socket on. Be sure to pull down to install the new belt.
Dec 29, 2010 | 1995 Plymouth Voyager
I need to replace my puel pump for plymouth voyeger 1999.
The fuel pump in a Plymouth Voyager is electric so you should check the fuses and relays before inspecting the fuel pump itself. If you have fuel in your tank but your vehicle has difficulty getting fuel, you may need to clean your fuel pump or replace it entirely. The Plymouth Voyager comes in a variety of styles and this may affect your choice of fuel pump.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Things You'll Need:
  • Fuel pump kit
  • Socket wrench set
  • Torque wrench
  1. Step 1 Determine the fuel pump that your Plymouth Voyager will require. This depends on the make and model and engine size of your vehicle. Models manufactured from 1991 to 1995 came with a 2.5 L K, 3.0 L Mitsubishi 6G72, 3.3L EGA or 3.8 L EGH engine. Models made after 1995 may have a 2.4 L EDZ, 3.0 L Mitsubishi 6G72, 3.3 L EGA or 3.8 L EGH engine.
  2. Step 2 Relieve the fuel2_bing.gif system pressure and drain the fuel tank. Disconnect the negative battery cable with a socket wrench.
  3. Step 3 Support the fuel tank and loosen the strap bolts with a socket wrench. Remove the fuel line and electrical harness for the fuel pump.
  4. Step 4 Lower the fuel tank so that you can remove the lock ring for the fuel pump. This will allow you to remove the fuel pump.
  5. Step 5 Install the new fuel pump using the items included in the kit. Use a torque wrench to tighten the lock ring and bolts for the main fuel tank straps to 40 ft. lbs. Torque the bolts on the T strap for the fuel tank to 250 in. lbs.
  6. Step 6 Complete the installation by reversing the removal procedure.
Feb 19, 2010 | 1999 Plymouth Voyager
Instructions on installing durabrand DB1215
Why did my db 1215 not come with wires so I could install it in my car?
Oct 17, 2009 | Durabrand Car CD Player and AM/FM...
Need wiring plug for a model DB1215 am/fm/cd receiver that was lost but we want to keep the radio unit
Just bought the DB1215 Model--Can you tell me what is the best size speaker to use and how many?? Thank you Dan
Oct 12, 2009 | Namsung Car Audio & Video
Tie rod end removal for 1995 plymouth voyager mach 3
Not too much to it, Crack jamb nut loose at threaded end where it threads onto. Pop/whack, it out of spindle/knuckle, after removing cotter pin & nut, thread it out, and new one on, same distance, or amount of threads, and tighten jamb nut against it. Push end back into spindle/knuckle, give light tap with nylon or rubber hammer, so it won't spin when trying to tighten nut & install nut (35 ft.lbs) & cotter pin.
Mar 07, 2009 | 1995 Plymouth Voyager
SOMETHING BLEW WHEN A SPARK APPEARED INSTALLING RADIO
I have 25 years audio experience. Your looking for the wrong thing for starters. please go premium or live chat and I can go over things with you. If this is helpful, please post as such. TY
Jan 18, 2009 | 1996 Plymouth Grand Voyager
How to install a durabrand 60 watt car cd player?
the easy way is to buy a 5$ harness from pepboys or a auto stereo store ask them a harness for your make and model car to hook up a after market radio that harness will plug into your factory harness also the new harness will give you a wire diagram telling you what wires are what if you dont know about what wires are what on your after market radio they are sometimes listed on the top of the radio its real easy most radios are red power yellow aux -only power when ignition is on and black ground speakers are most of the time one color for all negitive and multi colored for positive good luck I hope this helps good luck....
Dec 31, 2008 | Durabrand Car CD Player and AM/FM...
I want to connect a Kenwood KDC-20011S CD Car stereo to my old 1995 plymouth voyager. Where is a simple website I can go to get a diagram of the wires to connect.
Go to intalldr.com and go to quick wiring info. But on the other hand I would recommend going to an audio shop or even walmart and getting a wire harness. There are so many things that can go wrong when you dont and its quicker to do. All you have to do it color match the harnesses, then plug and play. Good luck
-Andrew Hawkins
Jul 31, 2008 | Kenwood Car Audio & Video
Car Audio & Video Logo
163 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
