Question about Refrigerators
Psc23mste My GE psc23mste fridge section recently stopped holding at 37 degree set point and will only cool to 41. Any suggestions as to where to start looking for problem? Thank you.
HVACRH20
  • 237 Answers
SOURCE: fridge freezer not cooling from new - buttons not working
Sounds like an air flow problem from the freezer section to the refer section. Check that nothing is blocking the air vents, and that the dampers are operating properly (they control the flow of air). Of course if it's under warranty... call the service techs out.
Posted on Nov 09, 2006
SOURCE: Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Posted on Aug 04, 2008
  • 9 Answers
SOURCE: Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Posted on Sep 06, 2008
SOURCE: Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Posted on Oct 02, 2008
  • 531 Answers
SOURCE: GE side by side fridge not cooling enough Freezer side was still
check see if you have frost build up in the freezer back wall you may have defrost problem
Posted on Apr 06, 2009
Food freezing in crispers in ge bottom freezer fridge
Check to see if the fan is working...put a thermometer in the refrigerator and make sure the temps are between 33-41 degrees F.
Dec 18, 2013 | GE Refrigerators
I had ge refrigerator and the fridge is not cooling well
For starters a year and model number would be helpful. Do you have turn dials to contol temp of freezer and fridge or electonic pushbuttons? The fridges with manual rotating dials use a "dampner" between the freezer and fridge section. In short the freezer evap fan blows air in the freezer but also has a passage from the freezer to the fridge section which aloows a controled amount of air from the feezer section to cool the fridge section. IThis passage may be obstructed by ice build up or some other blockage. Units prior to 2002 are not controled by circuit boards and the ones after 2002 are. For more specific help give me the GE fridge model please.
Sep 24, 2012 | GE Refrigerators
The freezer compartment is working fine, holding at -18 degrees but the fridge section will not chill and has been holding at about 14-15 degrees for over a week but does not get any cooler than...
It sounds like one or more of your cooling tubes is blocked. Either you have a ice or frost buildup on your freezer side or something else is blocking it.
I would suggest you take a look behind the panel in your freezer and use a hair dryer or heat gun to blow warm air down the cooling tubes.
Jun 26, 2011 | Refrigerators
Freezer 20 deg --fridge 55 deg fridge not cooling
Check compressor working and also with correct pressure. Keep arm in condenser coil. If you feel warm, check freezer to hear slight whistling sound. If not short of gas or gas leak. If warm and no whistling sound means, system chocked. Release all gas and flush out system. Vacuum and do gas charging. Thermostat setting must be 3 to 5 degree Centigrade.(37*F to 41*F). Thanks.
Feb 04, 2011 | Refrigerators
There's a problem with my Whirlpool Gold refrigerator. I tried to set the setting to 37 degree F as recommended for the fridge and 0 degrees F for the freezer but it won't work. As a result the fridge and...
The problem is not on your settings but there could be a fault in many of the problem areas. First of all I would like you to shut off the fridege for abbout 8 hours, restart and see if the coolings appears. Next check if the compressor motor is humming fine and there is heat building up, if not you have to check for failure of gas pressure or gas. If the set cools and then it stops, you have to check up on the thermostat and the auto cut off sections. If there is no cooling action at all I am afraid that your compressor needs a close check up and you might need a fridge technician to see to the compressor pumping and the gas. You must weigh the cost of the work and decide if it works out feasible. Hope I could help. Good day
Jul 24, 2010 | Whirlpool Refrigerators
Freezer set to 0 actual temp - 1 Refrig side set to 37 actual temp drops to 30 and frezes items in refrig.
Set the refrig temp to 42 degrees . Also check to see if the damper (top left in refrig section ) is closing to stop the air flow into the fridge section . Sometimes they will stick due to ice build up inside the damper . Sometimes also , putting a knife inside and wiggling it around , will break it free , however , it may have to be replaced along with the #1 thermistor .
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge running warm
one thing to check for if you whant the freezer to colder the fresh food compartment will not go down i temperature because you stre blocking the air floe lower the freeezer control knob thanks from gilles
Feb 21, 2009 | GE GSS20IEP Side by Side Refrigerator
GE Side BY Side keeps Running
two reasons I can think of, fan motor because of the whining description you descibed, and possible freon leak. I think the first is the problem!
Dec 27, 2008 | Refrigerators
Oct 02, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
