Question about Sony KP-53V75 53" Rear Projection Television
No picture but have audio. Also "Video 1, 2, 3" etc displays as does setup. Connections are all good. Even direct link from xbox to tv does same (audio/no video)
premtech
  • 934 Answers
SOURCE: sony trinitron 32 in. pip no video, (raster, with audio)
What you have described there is a classic example of the jungle IC failure. Ic301 Sony p/n 8-752-101-04. A pic with no color, and lines or grainy texture in the picture. Not a project you want to tackle if you don't have the proper soldering equipment or skills. And not a costly one at a good repair shop.. Only real hurdle is getting that heavy monster into the shop. To answer your question, yes what you described there is raster. Even the salt & pepper looking screen with no real decernable image is described as raster. In fact any image generated on the CRT is raster. And yes, these sets are prone to solder joint problems, usually ring cracking in circuits that generate the most heat.
Posted on May 25, 2007
  • 20 Answers
SOURCE: how do I get video input from one source and audio from another?
I am confused and might be overlooking something obvious here. SO PLEASE do not think I am being disrespectful! IF you have everything connected properly, then your television is a separate device, independent of your Sony STR. You should be able to watch the picture with the Sony STR turned OFF. In turn, you should be able to LISTEN to the Sony STR with the television turned off. Although it isn't a lot of fun, it might be best to DISCONNECT all the cables (not your speaker wire) and go through the process of reconnecting everything.
Posted on Jul 18, 2007
SOURCE: display 'video 1' stays on all the time
There is a "Display" button on your Sony remote that turns the display ( Video 1,2,3 etc) off and on , you probably hit it by accident like I did.
Posted on Oct 21, 2007
premtech
  • 934 Answers
SOURCE: sony trinitron xbr 32"
Did you correctly select the S-Video input on the TV via the remote? In other words, if the TV is not set to look at the S-Video input then nothing will happen. You have either an "input", "source" or tv/vcr button that will allow you to select what input the tv will look at for a signal. Make sure it's set to S-Video.
Posted on Nov 13, 2007
  • 1694 Answers
SOURCE: Sony KV-27FV310
Component In is not converted to composite out (yellow)
TV monitor out normally goes to A / V receiver in......T.
Posted on Nov 18, 2007
I have audio but no picture, just "Video 1"
You didn't mention tv make / model so thjis is only a guess . The tv may need tuning to find the direct tv cable.
Jan 07, 2015 | Audio Players & Recorders
Sky new zealand say my hd z70rx5 is unable to recieve hdcp even though the specs say the set is HDMI AND HDCP complient,they say no rear projection is able to receive hd is this true,any help i would be...
Terminals and Connections Dual HDMI digital inputs with HDCP (High Definition Content Protection) offer an uncompressed solution to the transmission and display of high definition video and audio content. All JVC HD-ILA TVs also include dual auto sensing component video inputs, assuring the best possible picture quality whether a viewer is using DTV, D-VHS or DVD, and three S-Video (two rear, one front) inputs and four AV inputs (three rear, one front).
hdmi.gif High Definition Multimedia Interface
HDMI is a new standard digital connection between A/V devices, such as a set-top box, DVD player or A/V receiver, and a digital television. HDMI offers exceptional video and audio quality with a single quick-disconnect connector. It supports multi-channel digital audio transmissions and component video color spacing for true rendering of HD video.
We carry a full line of high-performance HDMI cables. See them here...
Audio Features The JVC BBE High Definition audio system with Advanced HyperSurround and Active Hyper Bass includes two direct-drive speakers mounted underneath the screen for rich, expansive sound that fills your home theater or TV room.
Aug 06, 2008 | JVC Televison & Video
What are the different conections for.... at the back of the TV. (There are two plug with multipal pins)
TV's have many connections these days.
The majority of connections are inputs, which mean you can connect a external device into the back or side of the TV. For eg. you can connect a DVD player, Xbox, play station, camcorder, etc.
Most are labeled AV1, AV2, AV3 and so on. Which refers to Audio Video inputs.These connections will vary in style and are,
  • RCA style, Yellow is Video or picture connection. Red and White are sound, Right and Left........see attached photo.
  • S Video is a Video or picture connection, like the RCA but better picture quality...see photo.
  • H D M I is a rectangular shape connection and is for both picture and sound in the one cable and stands for High Definition Multimedia Interface, which is higher quality again....see photo.
So for example if you connect a device into HDMI 1 on the back of your TV, then you select HDMI 1 via the AV function on your remote.
So I believe the one your talking about with the multiple pins is the HDMI.
Hope this was helpful to you.
MobileJB
Jul 13, 2011 | Televison & Video
When I turn on the tv the picture isn't showing why is that ?
You have limited information on your post...so,
Just guessing, if your trying to just plug your tv into a wall outlet
and expect to get a picture....you probably won't.
If your running through a cable box or direct tv for instance.
Make sure that all of input and output connections are connected
properly. Also, sometimes if your using a hdmi it does not work
correctly, try the component video connections.
If your running it through a stereo receiver, you may have to select
something on that to get it to work.
I run mine through my stereo reveiver...I have to turn it on, select the source,
dvd, tv etc. then on the tv i have to run through the input selections
to have it display.
It will run my xbox, ps3, wii, dvd's etc. but, selection is the key.
You can try to hook up one of your gaming consoles directly and see
if you get a picture. Or you can try to hook up your laptop and do the
same. Also, maybe your dvd player.
Kind of unusual that this would not work right out of the box.
You should see the on light on the tv when you turn it on etc.
Maybe the above will help...hope so....
Good luck.
Jan 26, 2011 | RCA L32WD22 32 in. LCD HDTV
Audio has a echo effect
Now this can be caused by one of two things,
1. The settings on you TV are not set up correctly, Depending on your TV, the audio settings in the menu may have an option for "equalizer" or "sound mode" your best bet would be to have a play around with these settings whilst playing constant music etc.
2. The connection between your xbox and your TV are not propally connected, remove the cabling and blow any dust away and reinsert the cables.
One way you can test whether its your xbox or yout TV, could be to try the console on another television setup.
Good Luck!!
Nov 09, 2010 | Microsoft Xbox 360 Elite Console
I cant get the x box 360 to show the screen but the consle will turn on i hear the fan runninf but just no screen
I would check your video connections. If it is dark behind your TV, use a flashlight and make sure all of the audio and video connections are correct. Make sure the connections are firmly in place for your XBox and TV for the audio/video cable. Also, be sure to be on the right video setting on your TV (Video 1, Video 2, etc.).
Feb 02, 2010 | Microsoft Xbox 360 Console
Why can't we get the sound to work by hooking the DVD player directly to the tv?
The JVC system is designed to output audio only via the speaker terminals at the rear of the system. There is NO provision to send audio directly to the TV from the system.
Page 14 of the manual (link provided below - free to download) details the connections available to a TV. These connections are limited to three types of connections: 1) "Video" for standard TVs which is "good" 2) "S-Video" for TVs that have an S-Video input jack which is "better" (both #1 and #2 are considered "composite" types).
The third type is called "Component" which is used for TV's that are capable of "progressive scan" video input which is "best" for the system. Notice that the jacks on the DVD player are labeled "Y", "Pb" and "Pr", not "Video", "Left" and "Right". This type video signal requires the use of three cables - they do not send audio as you may be used to see on all but the newer TVs. TVs capable of displaying "progressive scan" video have a better looking picture when using these jacks. Incorrectly connecting the video from the DVD to the TV audio inputs (Left & Right) will likely result in noise or hiss from the TV speaker.
To recap - audio can only be played through the JVC system's speakers. Use the highest quality video jacks that BOTH your TV and the DVD player supports.
I hope this was Very Helpful and enjoy your DVD and TV!
http://www.retrevo.com/support/JVC-TH-M505C-Home-Theater-Systems-manual/id/318bh527/t/2/
Dec 21, 2009 | JVC TH-M505 System
Sound no picture, picture;no sound
a panasonic tv will shut down after a short time with no video input. it sounds like the setup menu in the receiver has defaulted and needs to be setup again to coordinate the audio and video signals. ive seen many yamaha menus default. dont let geeks in your house.
Nov 03, 2009 | Yamaha RX-V663 Receiver
No system configration display on AVR3300 since moving.
Make sure the S-video and the composite cable are not plugged in it the same time from the Denon of at the Plasma
Jan 19, 2009 | Denon AVR-3300 Receiver
Black and White Only
I had a similar problem when I first connected my son's xbox using the Audio/Video cable (red, white, & yellow connectors). I connected the cable to the TV correctly, but incorrectly selected "component" as the input on the TV setup. Result was black and white display. Switch your TV input mode to "AV" or "Audio/Video" and you will get color.
FYI, "component" TV mode is only used with devices that use the red, green, & blue connectors.
Jan 30, 2008 | Microsoft Xbox Console
Sony KP-53V75 53" Rear Projection Television Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
