Question about Kenmore Dryers
Kenmore 61202 pulley is off the belt - Kenmore Dryers
Kenmore sewing machine keeps squeaking how to stop it?
Hello Shirlene, If your Kenmore machine has two drive belts, a belt from the motor to an idler pulley and a belt from the idler pulley to the main shaft. I have found that the idler pulley needs some Teflon grease on the idler pulley shaft. On my machine, the squeak would go away for a while if I oiled this idler pulley shaft. But it was short lived. Only grease on the idler pulley shaft would silence the squeak.
Oct 23, 2015 | Kenmore Sewing Machines
Just bought a kenmore 61202 dryer. Hooked it up - everthing works but I have no heat? It is an electric dryer
I would check to see if you have the correct voltage to the dryer at the plug in point. Also check the cord to the dryer with a meter to assure it is the same as the wall connection. It seems something is missing there.
Good Luck
Aug 28, 2011 | Dryers
Dryer belt diagram how it goes on pulleys
usually 2 small pulleys one on tension-er spring push it in or you can not get belt on
belt makes an S on small pulleys one of the pulleys is the motor most belts are grooved flat side to dryer drum grooved to motor pulley flat to tensioner pulley do not flip belt
Jun 09, 2011 | Kenmore 98702 Stacked Washer/Dryer
The belt on my Kenmore washer model no. 110.45091401 is shredded. How do I replace it?
REMOVE BACK PANEL ON FRONT LOAD WASHER PUT BELT ON LARGE PULLEY AND TAPE BELT TO LARGE PULLEY TAKE OTHER SIDE OF BELT AND STRETCH TO MOTOR PULLEY WHILE ROATING LARGE PULLEY WALKING BELT ONTO SMALL PULLEY OR LOSEN MOTOR BRACKET PAY ATTENTION TO LOCATION OF MOTOR BRACKET ALIGNMENT PUT BELT ON BOTH PULLEYS PUSH MOTOR TILL BELT IS TIGHT AND RETIGHTEN BELT
Jan 26, 2011 | Kenmore Washing Machines
No tension on the tension pulley.
Check that the slide/rod /bracket is not jammed on the adjusting mechanism.
Jan 18, 2010 | Kenmore Elite HE4 Electric Dryer
Hey bud, i replaced my kenmore washer with a new coupler, but still it will not spin??
inspect under the washer. look at springs for broken or one that may have come loose. inspect drive belt for broken or off pulleys. the drive belt is not turning pulleys, belt maybe broke or outa pulley grooves. or belt tension springs are broken or unhooked. good luck!!
Jan 09, 2010 | Kenmore 24032\24036 Top Load Washer
Change the belt on the machine
Usually the easiest way is to put the belt on the smaller pulley first and then start it on the bigger pulley on one side and then turn it onto the bigger pulley by spinning the pulleys to get the belt to direct itself onto the larger pulley little by little. Using a flat-headed screwdriver can help pry the belt on and keep it from falling back off of the larger pulley while turning it to get the belt fully on. If you have any other questions about this, let me know.
Benjamin
Jun 15, 2009 | Kenmore 22422 Top Load Washer
My kenmore clothes dryer has stopped spinning and is just making
The pulley in question is likely a spring loaded idler pulley, used to keep tension on the belt. It likely hangs onto the dryer's frame, & is held in place by the belt. If you order a new belt from Sears, ask them for a belt path diagram, which should show the proper pulley position.
Apr 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore Elite Driver Belt
just remove back cover ..install belt on small motor pulley first then work around drum pulley while turning large pulley try spinning by hand first to verify belt is tracking in center or close to center of large pulley
Jul 22, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
