Question about Samsung Front Load Washer WF361BVBEWR
Wf 361 samsung front loader, detergent tray is full of water after washing clothes
  • 43 Answers
SOURCE: Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Posted on Nov 10, 2008
SOURCE: mildew smell in front loader
Yup! I have the same issue with a WE206BNW (Canadian model). Did the same thing - dried the water off the door and leave the door open when not using it. Sort of helped, but then I ran an empty light load with bleach through it - no clothes, just water. Helped a lot.
Henkfish
Posted on Jun 08, 2009
  • 1531 Answers
SOURCE: I own a Samsung WF338 Front loader washer. Water
you need to set this up for service
Posted on Sep 19, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: The washer leaves water remaining in drum after
Hello
Check the drain tube,it needs to be 30 inches above the floor.
Also if the drain tube from the washer is too far into the drain the washer will not drain completly.The drain tube should be 1 inch into the wall drain.
Also check for kinks or obstructions in the washer drain tube.
Posted on May 13, 2010
Water backing up in detergent trays Samsung vrt Steam front loader
In some machines, the detergent tray is flushed to empty completely.
Feb 02, 2017 | Samsung Washing Machines
Where to put washing detergent in Whirlpool AWM8121?
Simply place detergent into wash ball and place inside drum on top of clothes,,,,fabric softener goes in smallest compartment in tray
Jun 20, 2013 | Whirlpool Washing Machines
I have a Samsung Silver Care front loader washing machine. When I turn it on water comes out the detergent dispenser drawer and a little oozes out of the main front door. Any ideas? Thanks, Kelly
Remove the dispensing tray (look for an under side spring clip or release) and check the fluid exit point--the machine washes the detergent into the drum along with other washing compounds. You may be better off using a liquid detergent rather than a powder. This may also fix the main door leakage too. Hope this helps!
Aug 15, 2010 | Samsung WF328AA Front Load Washer
Water is pouring out of the detergent dispensing drawer from my 1 year old Samsung clothes washer model WF328AAW. When I opened the drawer, it was full of water. Something must be plugged. Is there...
Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
Apr 17, 2010 | Samsung WF203ANW Front Load Washer
Water in the detergent cup
Yes. There will be a bit of water in the tray. The best thing to do is empty the water out either into the washer or a sink. Then leave the tray drawer open as well as the washer door open. Mold can develop on front load washers just like it can with top loaders. Leaving the drawer and door open to dry will help to prevent this.
Apr 03, 2010 | Samsung WF448AAW 4.5 cu. ft. Front Load...
There is water left in the detergent tray after the wash is over
This seems to be normal for ALL front loaders
I just leave mine open along with the front door to dry out
Nov 06, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
After washing clothes, water stays in the detergent tray.
Best plan is probably to take the detergent tray right out of the machine, then take it to bits before washing it out with hot running water and a toothbrush.
The problem with these things is that the bit that blocks up is pretty well hidden until you dismantle the tray.
A.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking Water
Nov 10, 2008 | Samsung WF337AA Front Load Washer
Water levels
Probably the nivauchamber is clogged of lime or something. Or you are overloading the machine
Jan 31, 2008 | Zanussi ZWC1300W Front Load Washer
Samsung Front Load Washer WF361BVBEWR Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
