Question about Aspire Digital AD-900 DVD Player
Aspire Digital AD-N820B DVD-R stuck in Progressive Scan ( PSCAN )
My AD-N820B is stuck in Progressive Scan. I moved it with a DVD in the drawer, the DVD slipped out, and I had to open the case to retrieve it. Since then it is PSCAN and I can get it out. There is no button anywhere to toggle PSCAN and I've tried holding down the Stop button both on the case and the remote. Naturally, I tossed the manual the minute I set it up.
  • eddie1545 May 12, 2008
    i doesnt read my dvd's, i hear e beep i tried to use the steps to reset it, but it doesn't work.
    it stopped working all of a sudden.
    thank you.
  • pohlley Jan 09, 2009
    how do I get pcan split screen off tv without original remote, I have a universal
I just had the same problem with the same model but I was able to figure it out after a while.
From the remote control:
SETUP
Scroll left or right to the PREFERNCES menu.
Scroll down to the bottom until DEFAULT is highlighted.
HIt the PLAY button in the remote while RESTORE or RESET is highlighted.
The DVD player was reset back to factory settings within 10 seconds.
Posted on Jan 01, 2008
Hi could anyone help with my problem. my remote its broke. and i want to use a universal remote. but none seems to control it. i use a radio shack 5 in 1 model, and a RCA systemlink3. but i can manage to work. can you help me
Posted on Sep 28, 2008
SOURCE:
We see a yellow anouncement that says PSCAN and it splits the image
Hello
PSCAN; means Progressive Scan. To get the splitted picture together you have to change the scan system of your tV to progressive scan. Now it runs on Interlace Scan. If your TV has Progressive Scan function; refer to its user manual; set it to progressive scan. An other way is to change the scan system with DVD. Try either. OK.
Jun 20, 2011 | Memorex MVD-2045 DVD Player
PSCAN
try unplugging it overnight.
Thanks,
Lee
Jun 24, 2008 | Aspire Digital AD-8091 DVD Recorder
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
Devide the tv screen in 2 and have PSCAN written
Pscan is progressive scan, go into the menu and turn PSCAN off
Mar 21, 2010 | Televison & Video
Stuck in pscan, no book, help
By "pscan", I'll assume you mean progressive scan mode?
disconnect unit from A/C power. Hold in power button, plug unit into wall whilst holding in power button for 10-15 seconds.
If that doesn't reset unit, then simply hold power button in for 30 seconds whilst power is already applied to the unit. That not work?
Toss unit into the garbage.
Feb 21, 2009 | Coby DVD-224 DVD Player
Dvd player not showing color
you are only having porblem with your color system. if you are using a multi system DVD player then see if it is properly selected to your region. in USA it should be NTSC 3.59, if you're in Europe it should be PAL. if you're using your DVD via a DSP or audio systems, check also the color system of the amplifier, it should be adjusted to your color system.
Mar 31, 2008 | Aspire Digital AD-900 DVD Player
Pscan mode
I had the same problem. Here's what I did to reset the progressive mishap...
  1. Turn on the player (without a disc inserted)
  2. Wait for the "no disc" message
  3. Press 1, 6, 7, 1, 9 slowly
  4. A menu comes up
  5. Select "Configuraton"
  6. Select region (0 = codefree)
Feb 26, 2008 | Oritron DAV3101 PROGRESSIVE SCAN DVD
PSCAN shows up on my tv screen when I try to watch movies. How do I delete this?
The solution to the PSCAN! (half screen cut image) is just as suggested, turn off the progressive scan switch in the back of the DVD player to get the full image and enjoy your movie.
Dec 26, 2007 | Memorex MVD2040 DVD Player
Aspire dvd player model #N820B
your remote control should have a button showing "display" that enables/disables on screen display
Oct 22, 2007 | Aspire Digital AD-900 DVD Player
Aspire Digital AD-900 DVD Player Logo
695 people viewed this question
Top Aspire Digital Televison & Video Experts
Ekse
Are you an Aspire Digital Televison and Video Expert? Answer questions, earn points and help others
