Question about Lexmark X1150 All-In-One InkJet Printer
How to print photos with Lexmark X1150 on photo paer ?
Hi
I can print pictures on normal paper with "normal" inks, but can't find any photo inks for Lexmark anywhere ...
Is it possible to use the "normal" inks on photo paer with Lexmark then ?
Any idea ?
Thanks
  • Chouchou2009 May 10, 2009
    Too cooooooooooool
    THANKS A MILLION jd21 ! I owe you !
  • 163 Answers
Yes that is fine.
Posted on May 08, 2009
Hi. my photo printing results is not so good on normal paper. plz tell me vat is the problem. i want to print photo in best resolution on ordinary paper.i.e (Double A paper)
Printing photos on ordinary paper do not come out well because the ink soaks into the paper like a blotter. I suggest you use semi-gloss or high gloss photo paper for best photo quality prints..
Feb 25, 2011 | Epson TM-T60 Printer
I want to know if I can use regualar paper
If it is a plain paer fax you can use ANY paper you would use in an injet printer.
Apr 07, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Printing is faded
You may be low on ink/toner. Does the unit have a supplies status monitor or configuration page?
Have you recently changed the ink cart?
May 06, 2009 | Lexmark X1150 All-In-One InkJet Printer
I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
May 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
Why did my cartridge run out of ink before the 100th picture?
If the picture resolution is high, you will be using more ink.    Was it really a good idea to put your name and address on here?? DUH
Dec 18, 2008 | Lexmark X75 All-In-One InkJet Printer
Dull pictures ,new ink ,deep cleaning done ,ink heads cleaned
Are you using photo paper to print your photos? If you print photos using regular paper, the ink will spread out in the paper fibers of non photo paper and make the photos appear dull. I would try using paper made to print photos and see if that helps
Nov 07, 2008 | Office Equipment & Supplies
Lexmak x2500 way to light
If the printing is too light, it is the printing quality issue. Just goto Printing Preferences>Quality/Copies tab, select the Quality/Speed to Normal or Photo, and the Paper Type to Plain or Photo, then it may help your problem.
YBC (/\)
Sep 16, 2008 | Lexmark X2500 All-In-One Printer
Brother 350c
First printing a photo takes lots of ink , it depends on the color of the photo , cyan is blue which maybe consumed more in the printing or there changes that the ink may have dried in the cart hence your getting this error ,remove cart take damp paper towel and hold the paper on the place where ink comes out gently for 20 second ,make it does not touch copper contact it may damage the cart ,make sure you check the place where ink with dry paper its usually bottom of the cart and repeat the above step with dry paper towel and try to print if you get the same error then you need to replace the cart or you can contact brother support and get cart replaced , once cart is used you need print once in week to keep cart from drying, you can use any photo paper which is compatible with printer .
Good luck....
Good luck....
Aug 24, 2008 | Brother Office Equipment & Supplies
Pictures coming out yellow
The "Print Head" needs cleaning or replacement. It's the part that delivers the ink from the cartridge tank to the paper itself.Mostly caused by air entering the lines and making any residual ink cure.
Most newer printers only ever use 95% of the available ink before reporting tank is empty,and will not allow any printing to resume, preventing air being introduced to empty lines in the head.
Without Removing Anything
There's commercial products available, I guess a bit like using a head cleaning cassette in your VCR - I Have not tried any of these yet.
Use an empty ink cartridge Refilled with hot water and run the print head cleaning function.
( Dont worry , The paper will absorb the minute amount of water being dispersed.)
If that fails you should remove the print head cartridge most are pretty easy ,
LexMark X1150 X1185 and other similar models with the sensor strip running through the cartridge instructions are located at the following FixYA topic
http://www.fixya.com/support/t181337-piece_fallen_out_printer
Immerse it in warm-to hot water for a while or try using rubbing alcohol or similar Non-solvent based liquid.
Inspect the small rectangle shaped metal print head & surrounding copper track for dried ink , remove any with very gentle wiping taking care not to damage anything.
If it's beyond cleaning it will have to be replaced .Try ebay or the local print shop.
May 12, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark x1150 everything works great but....
use this link ::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:386:0:0&framed=&docid=ENUS23202&relevance=1
Feb 21, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
