Question about Dishwashers
Water is not getting out from the dishwasher. What could be the problem? Thanks. David Volf
  • 10,865 Answers
Hello David - actually there are several possible reasons for your problem
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on May 08, 2009
Water is setting in the bottom of the dish washer at the end of the cycle. The dishes look clean but feel alittle funny. When I push the cancel button the water then drains out. I don,t hear the water swishing around during the cycle?
Posted on May 26, 2009
Whirlpool adp 951
I have nardi dishwasher model LSFHLX IT SHOW E2 error after completing the programe what problem plz help
Dec 15, 2013 | Dishwashers
My dishlex dx103sk won't start at all. How do I fix it?
Hi Daniel,
model dx103sk Electrolux
I am getting water hammer through copper pipes
every time dishwasher water valve opens and closes
I have changed 3 types of anti hammer washers on supply tap.
also changed the one way water valve at hot water service
next I am looking at changing the pressure valve next to the dishwasher as this problem really on happen when I changed brands of dishwasher.
? kpa rating do you think I should use?
Am I going down the right path here?
thanks David Desira
Jul 19, 2012 | Dishwashers
How do i reset a fisher and paykel dishwasher model dw920. Code F1 appeard found out i had a blocked drain, fixed it but still beeps and flashes F1. Have also disconnected power from mains but still the...
Hi
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You’ll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 07, 2010 | Dishwashers
We have a model SN-3125. Water stays in the
I had a similar problem. Found the drain pump impeller had a crack causing it to slip on the motor shaft when engaged. Had to replace the entire pump. Model #DW-5470-11
Mar 05, 2010 | Frigidaire Dishwashers
Dishlex Global 450 flashes ''oF'' - Continues to drain
I also had the oF error message just today, tilted the dishwasher back 45degrees and message dissappeared and all sweet as now. Put old towel under legs to catch overflow Thanks to david
Dec 29, 2008 | Dishwashers
Bosch dishwasher will not cycle. Water in base
First...make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Dec 22, 2008 | Dishwashers
Bosch SHV 4303 Dishwasher not draining
change your water pump or belt . Also make sure that no one just changed the garbage disposal and did not take the plug out of the disposal housing before installing the washer drain.
Good Luck
TEETERMAN
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Hobart lxih
E4 indicates water level has not reached top water sensor. Check for proper flow-water pressure to machine (15-25psi) and clean sensor in wash tank
Jul 16, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwasher
Wash water isn't hot even after we run hot water in sink before turning on dish water. However rinse water is hot. It appears the heating element is not working on wash but is on rinse?
Dec 19, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
143 people viewed this question
Top Dishwashers Experts
Owen Barnes
