You need to connect the camera with a USB cable to the computer. Only then the USB connection screen appears on the camera's monitor. There you select computer and press the set button. The screen to select the connection mode appears Select "Card Reader" and press the select button. Now the camera is connected in the card reader mode. If the windows automatic playback screen appears on the computer monitor, close it. Double click on the desktop [Mediaimpression 2] icon to launch Mediaimpression 2. The Mediaimpression 2 home page appears Click the right top icon [Import] Then the files in the camera appear on the screen. From there you can chose the files you want to safe on your computer. You can chose or make folders where you want the files on your computer.
You can read this in the manual click the link http://www.central-manuals.com/instructions_manual_user_guide_camera/sanyo.php
Connect a camera to your computer by using the camera's USB cable, and then turn on the camera.
Connect a portable device that contains pictures or videos to your computer by using the device's USB cable, and then turn on the device.
Insert a removable flash memory card, such as a Secure Digital (SD) or CompactFlash memory card into a memory card reader.
Connect a scanner to your computer by using a USB cable, and then turn on the scanner.
Insert a data CD or DVD that contains pictures or videos into your CD/DVD drive.
In the AutoPlay dialog box that appears, click Import pictures and videos using Windows.
To change the settings that are used when importing pictures and videos, click Import settings in the Import Pictures and Videos dialog box.
Change one or more settings in the Import Settings dialog box, and then click OK.
Click OK to restart Import Pictures and Videos. Type a tag in the Tag these pictures (optional) box, and then clickImport to import your pictures and videos using the new settings.
For updates make sure that the time and date are correct, if it doesn't match what time it actually is , it wont update, and make sure your OS has been activated
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
1. Turn PC on. 2. Plug camera cable into Camera. 3. Plug camera cable USB end into computer USB port. 4. Turn on Camera... wait until camera show message 'USB, PC, Pictbridge'. 5. PC should be selected if not select by highlighting and press shutter button. 6. Press 'Shutter' button. 7. Window 'Autoplay' appears on PC. Select 'import' in Autoplay window. 8. Another window will ask you to name your picture folder. Give it a name. 9. The pictures download to the picture folder automatically. 10. Turn the camera off and disconnect cable from camera and from the PC 11. ENJOY!!
Simply remove the memory card from your camera before connecting the camera to your computer. The computer will then see the camera's internal memory instead of the card memory, and you can copy the pictures over.
If you have been accessing your pictures by removing the card from the camera and placing it in a card reader attached to your computer, then this won't work for pictures in the internal memory. You will need to use the other method, connecting the camera to the computer with the USB lead.
Insert the recording media containing the pictures into the camera.
Depending on your camera, set the USB Connection or Transfer mode setting in the menu to the Mass Storage , Normal , or PTP .
Use the USB cable supplied with the camera to connect the camera to the computer. IMPORTANT:
Connection
through a USB hub or other USB device -- such as a printer or keyboard
-- is not supported and cannot be guaranteed. Connect the camera
directly to a USB port on the computer.
If the USB connection
from the camera is not recognized by the computer, disconnect the USB
cable and repeat steps 4 and 5 using a different USB Connection or Transfer mode setting. If the connection is still not recognized, further troubleshooting is available.
NOTES:
The computer will automatically install the USB driver for the camera.
When the camera connection is established, an AutoPlay window will appear.
In the AutoPlay window, click Import pictures .
In the Importing Pictures and Videos window, click the Import button. NOTE: After the pictures have been imported, the Windows Photo Gallery window will appear and display thumbnails of the imported images.
If this doesn't work there is an updated driver available
Uninstall all old pc cam,mars software and do a fresh installation. Restart computer.Before plugging in usb cable,push the shutter button down and hold it.Shutter is the button that takes the pictures. Now plug in usb cable. Camera should say pc cam and installation of software should start and complete. If asked about newer reference files answer yes. Software should now be installed. To use as pc cam,Dbl Click pc cam,mars icon on the desktop.New screen will appear.click on right facing triangle and another screen will open. Camera will now show on monitor what it is aimed at.To shut off,close all screens,and click on icon tray and shut usb device if necessary. To use as camera and view pictures,connect usb cable without pushing any buttons,and camera will say usb,Dbl click my computer,dbl click removable disk D,E F whichever it has been assigned,dbl click DCIM folder,and there are your pics to do waht you want with,save,print etc.Do not delete pics using the computer,delete only by camera so you do not damage files necessary to store and take pictures.If you do camera may have to be reformatted.Disconnect from pc same way by clicking usb icon in tray and stopping device,then its safe to unplug cable.
