Question about TTX Tech NXP3-050 Sony PS3 Wired USB Controller PC Compatible
Joystick driver drivers
I can not get it to work on any game, i have proper drivers installed "i think" and i tested it it says every button is working but still no game will pick it up, PLEASE HELP
JS282 PC Pro Flight 2 X axis isn't working
Software issue. Use a newer joystick and all will be fine.
Aug 24, 2017 | Saitek Video Game Consoles & Games
Tip
Installation, and testing the Logitech Extreme 3D Pro Joystick
The joy stick comes with a CD. Put the CD on the tray, and let the computer runs the software. On the CD there are driver for the joy stick itself, and driver for the USB . click on install joystick, after that, click on install the USB drive. that is it. Then a test screen will appear and asks you to check your joystick movements and buttons .push on the buttons,on the joystick, and you will see that they turn red on the computer screen each time you push a button, meaning your computer reads the commands from the joystick, You are set.
If you do not have the CD, then go to the Logitech site. and go to support, and from there you can download the drivers for the joystick.
on May 04, 2014 | Logitech Extreme 3D Pro Joystick
Why won't Microsoft Combat Flight Simulator for Windows 98 recognize my logitech joystick?
click on the joystick and then click on the properties tab
check and adjust compatibility
tick the box and move down the list to win 7 and click that ---apply and ok
it sound slike a compatibility fault or a missing driver for the joystick
Mar 15, 2017 | Logitech Extreme 3D Pro Joystick
Do I need a driver for wingman attack 2 on Windows XP, I can't get it to work. I'm very very new at this.
The drivers from Logitech help and can be downloaded from thier support site. The software they have lets you use profiles for all the games you play with the joystick, that way you don't have to constantly calibrate it for each game. The windows drivers will work the joystick....just have to go to control panel, game controllers and enable and calibrate the joystick.
Aug 31, 2009 | Logitech WingMan Attack 2 Joystick
Wingman extreme digital 3d not working.
you dont get any responds or recognition from windows other then in the deivce manager. it is working on the older joystick system so only the game has the capability of recognizing and making the button assignment if it supports joystick drivers.
in case your using driver that are too new here are the drivers for 15 pin logitech devices.
ftp://ftp.logitech.com/pub/techsupport/joystick/lgs460enu.exe
Jul 20, 2009 | Logitech WingMan Extreme Digital 3D...
Error message on driver install
Isn't this joystick about 10 years old? If so, the CD provided could be overwriting important OS files with older versions. If you can't update the drivers via control panel, I would call/email them for updated software or a fix.
support@avbusa.com
May 29, 2009 | American Anko AVB Force Feedback Pegasus...
Thrust in FSX won't reach higher than 55% even with lever at full
This is either a calibration error, or a faulty stick. Nothing else can cause this. make sure you have the latest drivers installed or one's that it came with. Some operating systems will see the stick and load generic drivers which sort of work, but not fully. Always use the manufacturers drivers and install it using the correct route as in the installation as there are ways to install drivers that do not register them properly and you think they are installed but are not. Good luck with it.
Apr 05, 2009 | Saitek X45 Mouse, Joystick
Joystick will not work with Combat Flight Simulator WWII Europe
Some joysticks are not compatible with certan games for expmple when i am using flight simulator and change to my combat flight simulator i have to change joysticks
the only other thing i would think is try deleting the currently installed driver for the joystick and then download a driver for a joystick that is surported, it wont work as well but at least it might accully work
Mar 22, 2009 | Logitech Attack 3 Joystick
It's probably an old joystick. Maybe since its so old, the Xbox 360 won't recognize it.
Mar 14, 2009 | American Anko AVB Force Feedback Pegasus...
Wingman light app. yrs old
Go to control panel double click game controllers Click add from the drop down list click 2 axis 2 button Joystick click ok and wait for it to show in the installed game controllers window highlight the entry and click on properties in the window that pops up click on the settings tab and then calibrate the joystick with the calibrate tab when you have done this your joystick will be working ok.
Oct 06, 2007 | Logitech WingMan Light Joystick
TTX Tech NXP3-050 Sony PS3 Wired USB Controller PC Compatible Logo
29 people viewed this question
Top TTX Tech Video Game Consoles & Games Experts
James Wishart
Are you a TTX Tech Video Game Console and Game Expert? Answer questions, earn points and help others
