Question about Lenovo 3000 Y410 Laptop
MyLenova T420 not carging
My lenovo T420laptop battery is not getting charge by my laptop but it is getting charged by my friends laptop of same model. i have checked my power adopter cable, battery and found ok . i m afraid of getting some issue on motherboard. help me.
  • Lenovo Master
  • 27,725 Answers
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in themon that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Fix a Broken Laptop Charger
If your laptop charger seems broken, it's most likely because the battery will not charge.
You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly.
When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop.
It should fit firmly in the DC jack without wiggling.
If it is loose, use electrical tape to hold it in place so the charger can receive power.
This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury.
A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible.
Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open.
The battery should pop out; give it a tug if it doesn't.
Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors.
Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery.
Slide the latch to secure it and plug in the power cord to test it.
See if the laptop powers on with the charger only and battery removed.
If it does, the battery is the likely culprit and should be replaced.
If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number.
Call the laptop manufacturer for a replacement charger or search for the part number on eBay.
If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems.
TroubleshootMag Safe adaptors
http://support.apple.com/kb/ts1713
Posted on Nov 27, 2013
2 Suggested Answers
SOURCE: my lenovo y500 laptop battery is not getting
hi! just a tip probably there is a problem on the power board, just a suggestion if your still on warranty might as well call lenovo tech support so that they could replace the defective part. hopr this helps! goodluck!
Posted on Jun 06, 2010
How long does it take to charge the battery?
Depending on battery. I just replaced the battery on my laptop a ThinkPad T420 and it said it could take up to 12 hours to fully charge.
Feb 14, 2016 | Computers & Internet
How can i fix white screen in my lenovo T420
Can you plug a monitor into the external Video connector, and do you see a display there? If you see a display on the external monitor, then the LCD is most likely bad.
Feb 20, 2015 | Lenovo ThinkPad T420 Notebook
Keyboard is locked on lenovo t420 thinkpad
Try to restart the computer. Lenovo computers can be glitchy a lot, and restarting seems to help. If it's a touch screen, the computer can be "confused" on which mode of input you're using.
Oct 03, 2014 | Lenovo ThinkPad T420 Notebook
Factory restore using command prompt
http://www.google.com.ua/search?q=Lenovo+THINKPAD+T420&oq=Lenovo+THINKPAD+T420&sugexp=chrome,mod=8&sourceid=chrome&ie=UTF-8#hl=ru&tbo=d&sclient=psy-ab&q=Lenovo+THINKPAD+T420+recovery&oq=Lenovo+THINKPAD+T420+recovery&gs_l=serp.3..0l2.1216.3253.0.3714.9.5.0.4.4.0.223.701.0j4j1.5.0...0.0...1c.1.14pecXA4UK8&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.&fp=30f8933bc1ffddc8&bpcl=38625945&biw=1366&bih=643
Nov 14, 2012 | Lenovo ThinkPad T420 Notebook
My lenova thinkpad says plugged in not charging
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 12, 2012 | Lenovo ThinkPad T420 Notebook
I need a user manual for a Levono ThinkPad T420. Where can I download a free one?
For T420 model Lenovo doesn't call it "User Manual" instead calls it "Hardware Maintenance Manual".
Here's a link to that manual:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/0a60007.pdf
Sep 04, 2011 | Lenovo Computers & Internet
My lenovo y500 laptop battery is not getting
Jun 06, 2010 | Lenovo 3000 Y410 Laptop
Carging battery of a new computer
Dear, You will get battery full indication on the Laptop. And you can start using the laptop now itself but make sure its connected main supply while using. One its connected to main supply, it dont use battery and mean battery get charged.
Battery full indication you can see near the system clock or they will some LED on the laptop itself
Oct 16, 2009 | Sony Computers & Internet
Battery problem-plugged in, not charging. Lenovo 3000 N100.Type:0768.Model:24U.S.no:L3LA215. Please offer a solution.
Had the same problem with a manufactured refurb, would go to 79 %, if you go to power options, change plan settings, change advance power settings, then to the Lenovo energy management tab, press the big enable Lenovo energy management, click on the blue gear to the left of the question mark, if "Optimize for Battery lifespan" is selected it will only charge the battery to 80%, change this to "Optimize for Battery Runtime" and it will charge to 100%
Feb 26, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 Y410 Laptop Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
