Tv white screen
My Phillips TV has a white screen and a message that say i must connect the correct usb device. I cannot turn the tv off or change the channels.
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
Troubleshooting to Philips TVs are actually a skilled work. Even an expereinced technician might have to spend some time to locate its faulty stage circuit. It will be best to contact the authorized service center for Philips in this case. The fault sounds to be to a firmware corruption. google.com/+GopakumarGopalan
Posted on Nov 27, 2013
3 Suggested Answers
Larrysito
  • 73 Answers
SOURCE: Phillips 19 TV screen will not work I can hear
there is a invertor problem ....first check the psu uni (power supply)
Posted on Aug 30, 2009
satavlad
  • 405 Answers
SOURCE: error message on my LCD
download proper firmware for your model from philips website and complete firmware upgrade. That should solve your problem.
Posted on Dec 04, 2009
My xperia m2 keeps saying connected to pc when connected to my tv trying to view photos
If you're connecting to your TV via a USB cable, then your phone can't differentiate between a TV usb connection and a PC usb connection.
Either way, when you connect it, it's basically just hosting its files to whichever device you're connecting it to.
Is your TV a smart TV? If so, there should be some way to access files on your phone, via the menu screen of the TV.
Aug 25, 2014 | Sony XPERIA M2 HSPA SS D2305 WHITE 4.8IN...
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
Hi i have a sansui sty1842 hd led but my ps2 is not working on it. i have plugged in the red, white and yellow cables and nothing
First of all make sure the cables are connected to the correct inputs, which you have probably already done. After that, I had the same problem with my sons tv when we got it. His is a phillips 42". I had to go to the phillips website and download a patch, copy it to a flash/thumb drive and plug that into the usb port on the tv and install the patch from the tv's menu. After that the Playstation worked fine.
Oct 05, 2012 | Sansui 42" Widescreen 120hz 1080p Led Hdtv
Our lcd phillips tv screen turns completely white after about an hour of use
The TV, most probably, the display circuit or the display itself has developed dry solder/components leaking and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Philips Televison & Video
When i connect my screenplay director to my tv the picture is in black and white, how can i fix this problem?
Confirm that the ScreenPlay Director is correctly connected to video input on your TV set.
Make sure the ScreenPlay Director is connected to power and turned on.
Make sure you have selected the correct video input on your TV to display output from the ScreenPlay Director.
The video output setting on the ScreenPlay might not be correct for your TV. Press the TV SYS button on the remote control repeatedly until the screen displays normally.
Try on a different TV, you TV may not be supported with this device.
Oct 25, 2010 | Iomega ScreenPlay Pro MP3 Player
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
I have a 19" phillips lcd tv and when i turn the tv on the phillips screen comes up but when it is going the show the channel it shut off by itself how can i fix this problem?
Hello. I may be able to assist you. If you are using a direct cable connection from the wall outlet;
  • Check the incoming cable or antenna signal connection to ensure that it is properly secured to the TV's antenna input.
  • If the connection is good, perform the automatic installation again to search for all available channels.
If you are using a coaxial connection from the Cable or Satellite box to the TV;
  • Set the TV to the channel specified by the service provider.
  • Change the channels at the Cable or Satellite box to view the program.
If you are using a video connection (CVBS, S-Video, YPbPr, HDMI) from the source (DVD, Cable or Satellite box) to the TV;
  • You do not need to perform automatic installation to search for the channels.
  • Press the 'SOURCE' 071218044349_22024.gif button on the remote control repeatedly to select the correct input source.
If you are using an HDMI connection from the source (DVD, Cable or Satellite box) to the TV;
  1. Reset the TV and source by unplugging it from the power outlet for 30 seconds.
  2. Turn on the TV and press the play button on your source device. If the source is HDMI CEC compliant, the TV will automatically switch to the HDMI input.
  3. If your source is not HDMI CEC compliant, turn on the TV and switch to the HDMI input.
  4. Turn on your source.
If you are sure you have selected the correct input or channel but still have no picture or sound;
  • Try resetting the TV by unplugging it from the power outlet for 30 seconds.
  • Press the 'SOURCE' 071218044349_22024.gif button to select the correct input source.
  • Check the connection cables.
  • Try the connected source with another TV.
  • Connect a different source on the same connection of your TV.
Dec 14, 2009 | Televison & Video
Error message on my LCD
Dec 03, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Phillips Projection TV
make sure you have the correct video input connected, play a movie in the dvd player do you get anything, can you use a different video input?
if all is correct go to the menu and see if the menu screen comes up.
Dec 02, 2007 | Philips Magnavox 51MP392H Rear Projection...
Magnavox hd2504
try turning the dvd player on,and
inserting a dvd,and then switching
to video the tv has to have a silgnal
when you switch to video the dvd
players splash screen should come
up,and then it will load the dvd
Nov 21, 2007 | Sanyo DS25390 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
