Question about Oreck XL Shield Power Scrubber Floor And Carpet Cleaner
Detergent not spraying
Cleaner installed, machine operating but not cleaner spraying from the nozzles
How do I get my carpet shampooer to spray wate
If your machine was designed to spray hot water, detergent cleaner or a combination of both, chances are the filter/strainer inside the reservoir may have become clogged, the feed tube may be twisted and pinched closed or the spray nozzle may be clogged from various contaminants. Try and get a look down inside the container where you fill it with fluids and see what you can determine, also check the spray tip or nozzle where the fluids are supposed to be expelled for a clog. If the small service pump is the culprit, servicing or replacing the pump will be a bit more involved and parts are available from most manufacturers websites these days. Hope this is helpful :)
Aug 27, 2014 | Dirt Devil 1700912044 Carpet & Rug...
I have the Bissell 9400 ProHeat 2X and it will not dispense cleaning fluid. Is there anything I can check?
YES! And it was amazingly simple. The soap dispenser has a red washer/gasket thing that fits over the nozzle. For clarity, it can be viewed here: http://www.vacpartswarehouse.com/Products-p/2036677.htm
The red part can come loose and remain inside the receiver where it fits snugly and looks like it belongs there. In this configuration, the tank cannot insert far enough into the receiver to open the spring valve and no detergent will flow. Simply remove the red piece from the receiver (I used small pliers), replace it on the tank nozzle, and the detergent will flow again!
Sep 07, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Have a bissell 9400-E and it doesnt spray cleaning fluid from underneath the machine, the hand tool works. have trie purging the machine with hot water in fluid tank and continuously hollding button with...
This may be caused because the pump belt has stretched or broken or the pump is seized and will not turn. Remove the pump belt and turn the pump rotor with your fingers to see it turns freely. If it does then the pump should be OK but the belt may be stretched and will need replacing. If the unit does not spray after changing the belt then clean the spray nozzles at the front of the machine and make sure that water flows to the nozzles OK. You can check this by temporarily disconnecting the nozzles from the plastic pipes.
Main causes for no spray.
Bladder may be empty.
SmartMix Bottle may be empty.
The Filter may be clogged.
Tanks may not be seated properly.
Pump may have lost prime.
The Pump Belt may be broken.
2 front jets are blocked. This is a common problem. When the machine is standing for a while the detergent turns to a gel causing the blockage Lay the Bissell on its side then where the water comes out of the jets at the bottom of the machine unblock them using a pin to poke through the hole in the centre.
Try running hot water through the system with no detergent to empty out all the residual detergent. Keep running hot water through the system by pressing the button you press for it to spray the water do this for about 5 mins and keep swapping the water for hotter water as it starts to cool doing this 4 or 5 times might solve your problem if not get the tools out and start looking for the blockage. Do this once a month to ensure that the pipes and jets are kept clean and free of any detergent gel build up.
Nov 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell cleaner bottom brushes are not turning and the big tank of water is not working only the small stain tank is working. it is still sucking up the water
Check the brush drive belt has not broken by inspecting from underneath. See the manual pages 21 & 22 for removal instructions. Download a copy from the following link
http://uk.bissell.com/images/UserGuides/9500E.pdf
Nov 13, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The unit sprays for the first few seconds after I turn the unit on and then stops spraying any water or solution. I turn it off, wait a few minutes and the same thing happens. What is going on and how...
This sounds as though the pump belt is slipping. This may be caused because the pump belt has stretched slightly or the pump is seized and will not turn. Remove the pump belt and turn the pump rotor with your fingers to see it turns freely. If it does then the pump should be OK but the belt may be stretched and will need replacing. If the unit does not spray after changing the belt then clean the spray nozzles at the front of the machine and make sure that water flows to the nozzles OK. You can check this by temporarily disconnecting the nozzles from the plastic pipes.
Pump may have lost prime. Check all the fluid tubes / hoses for leaks or blockage (see below).
Oct 30, 2009 | Bissell 7901-R Clearview Proheat Plus...
My bissell proheat will not spray water or cleaner and the filter does not turn;
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!!
Sep 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell proheat 7 will not spray water or cleaner
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Jun 05, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My carpet cleaner will not spray. Maybe a little thru the tool but not enough pressure to SPRAY
p.s. Make sure you do give it about a minute after you turn it on before you try spraying. If the pump is not allowed sufficient time to prime, you may not get proper flow.
May 26, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Stair and upholstery attachment
After tearing things down and inspecting the handle switch, etc., I found that my problem was detergent. It sets idle for a while or doesn't get used very much and the detergent dries and actually clogs the inside of the hose. I cleared it by fully extending the hose, pressing the button and allowing the clog to clear itself. The built in heater helped out a lot once the flow started again. I used a can of compressed air to provide a little blow back to get things moving but not too much or the pump would be damaged. Remove the tool and hold the nozzle into an empty cup while depressing the trigger. A warm vinegar solution clears things out nicely. It's kinda hard for this piece go defective but easy to overlook when wrapping up and storing the unit. Remember, clean water rinse with 1/4 cup white vinegar. There, I fixed it and wasn't even broke!
Apr 08, 2008 | Hoover F5881-900 Vacuum
No spray for my upholstery cleaner!
After tearing things down and inspecting the handle switch, etc., I found that my problem was detergent. It sets idle for a while or doesn't get used very much and the detergent dries and actually clogs the inside of the hose. I cleared it by fully extending the hose, pressing the button and allowing the clog to clear itself. The built in heater helped out a lot once the flow started again. I used a can of compressed air to provide a little blow back to get things moving but not too much or the pump would be damaged. Remove the tool and hold the nozzle into an empty cup while depressing the trigger. A warm vinegar solution clear things out nicely.
Jul 06, 2007 | Hoover F5881-900 Vacuum
Oreck XL Shield Power Scrubber Floor And Carpet Cleaner Logo
54 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
