Question about Welding Tools
Ust gg5500 is new but causes lights to flicker on light loads
3 Suggested Answers
SOURCE: 5500 gas generator
I had the same problem. My problem was the oil sensor. Unplug the oil sensor wite and see if it starts. If it does the order a new one, they are about 12 bucks
Posted on Jan 11, 2009
Healeyman
  • 1198 Answers
SOURCE: UST GG5500 generator no A/C output when I first start
Plug something into the outlet and have the breaker on when you start the generator. If it has an automatic idle control, turn that on too. A load will energise the generator.
Posted on May 06, 2009
UST generator model # GG5500 runs fine no power output
Don't worry I'm sure you will get the solution of your problem, just check the link I attach Best Manuals
Sep 07, 2017 | Electrical Supplies
Does a UST 5500w generator has a AVR. And if yes where is it located? Thanks for the help.
The contact number for parts and service is 1-866-797-2738.
The manual with parts is here: http://www.searspartsdirect.com/partsdirect/user-manuals/GG5500-UST-GENERATOR-manual
And it does not look like it has an AVR
Oct 07, 2016 | Electrical Supplies
Periodic battery light flickers on my 2003 town car.if you just tap on brake or flicker headlights .is there a separate diode that could cause this?
You have a defective alternator, that what is most likely causing the flickering light. A voltage output test will not reveal this.
May 19, 2016 | 2003 Lincoln Town Car
My 60kva deutz diesel generator trying to run down when i put it on load,in which it has been carring same load before
It sounds like some thing is shorted internally which would caus the generator to draw more current and load down.
May 21, 2014 | UST GG2300 Portable Gas Powered Generator
I have a UST GG5500 portable generator and it will not produce electricity. The engine starts fine but it doesnt generate any power.
Check your circuit breakers to see if they are tripped or damaged. Then take a look in the end of alternator / generator at the field windings. Check for damage to the brushes, as well as the diode for continuity in 1 direction only. Look for damaged capacitor regulator. Replace as needed.
May 15, 2010 | Electrical Supplies
Ust gg5500 dc power
trace your DC outlets backwards...they go to a certain (device)like object...test the wires goint to that device for voltage..if there was voltage then that device is burnt...you can take it to a parts selling shop and buy a new one.
Jun 22, 2009 | Coleman Powermate Powermate 5000W...
May 02, 2009 | Northern Tool Dual Turbo Propane Torch Kit
5500 gas generator
Recently purchased UST 5500 from Pep Boys. Had same problem during engine break in period. Found that the carb will not draw gas when generator is on level surface. Mine has the wheel kit and it causes the fuel inlet to be at highest point in tank. If you block up the wheels and change the angle of the tank it will improve fuel line pickup. Also check gap on plug, mine was way off from factory. Also check the routing of the spark plug wire and make sure it is not getting forced off the plug by tension from breather hose. Once the engine starts make sure to push choke back in, it will run for a good while choked but it will eventually shut off if you don't push choke back in. Hope this helps. Took me awhile to discover the fuel feed issue.
Sep 22, 2008 | Welding Tools
Welding Tools Logo
48 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
