Imuy p[rinter is printing photos pink I thought it was the ink cartridge I bought a new cartridge and it is still printing pink. \Could you help me
  • 2 more comments
  • SYoung7755 May 08, 2009
    The printer printed in pink on my photos I thought it needed a new cartridge so I bougt a new one and it also printed the photos in pink instead of the original color.
    My printer printed my photos in pink instead of its original color. I thought that I needed to replace the ink cartridge so I bought a new one and it is still printing the photos in pink with the new cartridge
    THE PRINTER IS HP PHOTOSMART 1000.
    Top Expert:
  • Office Equip... Master
  • 80,668 Answers
If u would please provide the manufacturer and the model number of the printer i am sure I can help u, but the usual cause of this this is the floating contact ribbon to the ink cartridge has an open circuit.
Posted on May 08, 2009
  • yadayada
    yadayada May 08, 2009
    I HAD THIS VERY SAME PRINTER AND THE SAME PROBLEM WITH MINE, IT WAS THE RIBBON THAT CONNECTS THE PRINT HEAD WHERE THE CARTRIDGE GOES WAS DEFECTIVE, I CHECKED ON THE PART AND IT WAS CHEAPER TO BUY A NEW PRINTER, IF U WANT TO GET THE RIBBON CONTACT PARTS IF IT IS STILL AVAILIBLE. USE THIS LINK.
    http://h20141.www2.hp.com/hpparts/?cc=US...
    President:
  • 1,383 Answers
Check on ink cartrdge there is no plastic strip.
Also check ink cartrdgei is fixed on correct position.
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge towards you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,
store the black print cartridge in the print cartridge protector or an airtight plastic
container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
electrical connections.
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
All my picture from my Epson Picturemate personal photo printer are coming out pink. I have brought a new cartridge and it is still coming out pink. Why??
Hi!
You need to run a Head Cleaning cycle so printer can get rid of the old ink from your previous cartridge. Try running it from maintenance for at least twice or try printing pictures in between cleaning cycles.
Hope this helps.
May 05, 2011 | Epson PictureMate (C11C556001) InkJet...
I have never used the Photo ink Cartridge #58. It intal pic shows putting it where the black one goes-does this mean I would use the color and the photo one at the same time instead of the black one?
Yes correct.The photo cartridge has to be inserted, where you install black cartridge.The photo cartridge gives finishing touch to the photos which you print.The actual photo comes from the color cartridge only, but for lightness and darkness, the color(ink) from photo cartridge gets used.In photo cartridge there are three color ink, that are light pink, light blue and grayish black.In color cartridge there are three color ink, that are pink(magenta), yellow and cyan( blue).------------- This are the details.Thank you for using fixya.
Mar 24, 2011 | HP Deskjet F340 All-In-One Printer
Brand New Edible ink cartridge not working on brand new Epson C90
Hmmm 4 this problem you can take the cartridge out and reinstall the software and then put the cartridge back
Jan 24, 2010 | Canon PIXMA IP3500 Photo Inkjet Printer
I bought new ink black and color but i try to print in pink and i can't how can i print in pink
Hi alexgallo01
Do you get other colours except pink?
If that is the case,reasons could be:
1. there is not enough RED or BLUE in the cartridge.
2. you haven't selected pink colour on the text or images you are trying to print.
If you are typing a document highlight the text you want in pink, and choose PINK color for the font.
Then print the document. The printer will use color closest to your choice, if it does not have the exact color.
Hope this will help.
If it help you, please give a rating
Cheers
luciana44
Sep 14, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Giant blobs of ink on every photo...
If you aren't currently, use the cartridge that the printer's manual says is for photos. Photo paper requires a different kind of ink.
Jun 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Brand new ink #60 just bought is making the photo all orange
http://welcome.hp.com/country/us/en/support.html  remove the old driver's and get the original one
Jan 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
Epson c90
did you remove protective strip from cartridge
Jul 24, 2008 | Computers & Internet
43 people viewed this question
k24674
jasbo
jasbo
