Question about Projection Televisions
Apex tv 46 inch
It seems when you turn it off , because I always leave it on, that it starts getting different colored waves and shapes, it won't show a picture
2 Suggested Answers
SOURCE: Apex projecter
Buy a new one! Mine won't even make a noise.
Posted on Mar 18, 2008
  • 65 Answers
SOURCE: I can't turn my tv off or it will not come back on for days.
your projector light may be blew
Posted on Jun 07, 2009
0 characters
1 Points
TV won't come on
unplug it for 10 minutes then turn it on at the console(not the remore) and hold the power button in for 15 seconds. this resets most apex tv's
Oct 06, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Hi...No need for a different jumper or different color wheel. It's an easy fix. Make sure your TV is turned off and remove the jumper with a pair of needle nose pliers. Just keep it in case you may need it in the future. I will post a picture to show you where the jumper is located.
Apr 09, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arching
Same thing happened to me. I had to get it fixed. They said it was a "tube".
Now, my problem (7 months after getting it fixed) is that it suddenly seems a lot dimmer. I'm not 100% sure, and was wondering if there was some kind of diagnostic to run to find out for sure.
Mar 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Convergence issues
di you check the resistors right next to the s these usually go out with the ICS
Feb 02, 2008 | Sony KP-46WT500 46" Rear Projection...
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Toshiba dlp
The light engine part number is 234054 and cost $456.00
Dec 20, 2007 | Toshiba 46HM95 46" HDTV
Very noisy when turned on, then shuts down, Samsung 61 inch
Color wheel defective. Replace it with the new designed color wheel. The lamp is ok.
Dec 10, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
APEX TV problems
need flyback transformer #030531-5283
Nov 05, 2006 | Apex Digital GB5108 51" Rear Projection...
Projection Televisions Logo
180 people viewed this question
Top Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Projection Television Expert? Answer questions, earn points and help others
